[postgis-tickets] [PostGIS] #4546: ST_ConcaveHull fails to execute through FDW
trac at osgeo.org
Wed Oct 16 07:19:44 PDT 2019
Reporter: Algunenano | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.4.9
Component: postgis | Version: trunk
Keywords: |
Source server: PG12 + Postgis 3
Remove server: Tested both PG12 with Postgis 3 and PG11 with Postgis 2.5,
same result.
The FDW server is created with `extensions: 'postgis'` so the function can
be shipped to the remote, e.g.:
CREATE server remote_server foreign data wrapper postgres_fdw options
(host '127.0.0.1', port '5432', dbname
'cartodb_dev_user_3e4a6fc6-4137-4c59-bc63-066f80efb90e_db', extensions
'postgis', fetch_size '10000', use_remote_estimate 'true');
Example plan:
explain (verbose) Select ST_ConcaveHull(ST_Collect(the_geom), 0.7, true)
from remote_local.populated;
QUERY PLAN
Foreign Scan (cost=594.53..594.83 rows=1 width=32)
Output: (st_concavehull(st_collect(the_geom), '0.7'::double precision,
true))
Relations: Aggregate on (remote_local.populated)
Remote SQL: SELECT public.st_concavehull(public.st_collect(the_geom),
0.7::double precision, true) FROM public.populated
(4 rows)
Error:
ERROR: type "geometry" does not exist
CONTEXT: compilation of PL/pgSQL function "_st_concavehull" near line 3
PL/pgSQL function public.st_concavehull(public.geometry,double
precision,boolean) line 152 at assignment
SQL statement "SELECT
public.ST_Buffer(public.ST_ConcaveHull(var_geoms[1],least(param_pctconvex
+ param_pctconvex/var_div),true),var_buf, 'quad_segs=2')"
precision,boolean) line 114 at assignment
remote SQL command: SELECT
public.st_concavehull(public.st_collect(the_geom), 0.7::double precision,
true) FROM public.all_month
This is happening because postgres_fdw removes all schemas from the
search_path, and although we qualify function calls using @extschema@, we
don't do it for types.
If I then qualified all geometry usages, the following error arises:
explain (analyze, verbose) Select ST_ConcaveHull(ST_Collect(the_geom),
0.7, true) from remote_local.all_month;
ERROR: relation "geometry_dump" does not exist
CONTEXT: SQL statement "SELECT public.ST_MakeLine(geom)
FROM public.ST_Dump(cavering) As foo"
PL/pgSQL function public._st_concavehull(public.geometry) line 49 at
assignment
As far as I know, FDW doesn't have an options to add extra schema to the
search_path (https://www.postgresql.org/docs/12/postgres-
fdw.html#id-1.11.7.42.10.4) so we can either find a way to qualify all
types used in SQL/PLPGSQL functions, even the implicit ones like
`geometry_dump` above, or we add `SET search_path = @extschema@;` to those
functions which would ensure that we use the types and functions created
by the function.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4546>
