[postgis-tickets] [PostGIS] #4530: upgrade postgis 2.3 to postgis 3.0.0rc1 fails at raster
trac at osgeo.org
Wed Oct 16 09:20:28 PDT 2019
Reporter: robe | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.0.0
Component: build/upgrade/install | Version: trunk
Resolution: | Keywords:
Comment (by strk):
upgrades _FROM_ 2.3.6 have this bug, not _TO_, so the fix needs to be in
place for 3.0.0 so far.
I did NOT test to upgrade _TO_ 2.5, 2.4, 2.3 -- it may be a good idea to
do, to see if we also need a fix there.
Note that the problem is {{{ AddRasterConstraints }}} failing when called
against a table with some NULL and some not-NULL raster values (as
prepared by run_test.pl). We might avoid this case from run_test.pl as I
don't think it's something we need for testing.
What I mean is that it is NOT the upgrade itself that fails, just the
_testing_ of the upgrade.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4530#comment:13>
