[postgis-tickets] r17939 - Fix AddRasterConstraints in presence of null geoms in table
Sandro Santilli
strk at kbt.io
Thu Oct 17 07:42:36 PDT 2019
Author: strk
Date: 2019-10-17 07:42:35 -0700 (Thu, 17 Oct 2019)
New Revision: 17939
branches/3.0/raster/rt_pg/rtpostgis.sql.in
branches/3.0/raster/test/regress/tickets.sql
branches/3.0/raster/test/regress/tickets_expected
References #4547 in 3.0 branch
Modified: branches/3.0/raster/rt_pg/rtpostgis.sql.in
--- branches/3.0/raster/rt_pg/rtpostgis.sql.in 2019-10-17 14:36:24 UTC (rev 17938)
+++ branches/3.0/raster/rt_pg/rtpostgis.sql.in 2019-10-17 14:42:35 UTC (rev 17939)
@@ -7476,24 +7476,28 @@
attr text; srid integer;
BEGIN
fqtn := '';
- IF length($1) > 0 THEN
- fqtn := quote_ident($1) || '.';
+ IF length(rastschema) > 0 THEN
+ fqtn := quote_ident(rastschema) || '.';
END IF;
- fqtn := fqtn || quote_ident($2);
+ fqtn := fqtn || quote_ident(rasttable);
sql := 'SELECT @extschema at .ST_SRID('
- || quote_ident($3)
+ || quote_ident(rastcolumn)
|| ') FROM '
|| fqtn
|| ' WHERE '
|| ' IS NOT NULL LIMIT 1;';
EXECUTE sql INTO srid;
- cn := 'enforce_max_extent_' || $3;
+ IF srid IS NULL THEN
+ RETURN false;
+ END IF;
+ cn := 'enforce_max_extent_' || rastcolumn;
sql := 'SELECT @extschema at .st_ashexewkb( @extschema at .st_setsrid( @extschema at .st_extent( @extschema at .st_envelope('
|| ')), ' || srid || ')) FROM '
|| fqtn;
EXECUTE sql INTO attr;
@@ -7502,7 +7506,7 @@
sql := 'ALTER TABLE ' || fqtn
|| ' ADD CONSTRAINT ' || quote_ident(cn)
|| ' CHECK ( @extschema at .st_envelope('
|| ') @ ''' || attr || '''::geometry) NOT VALID';
RETURN @extschema at ._add_raster_constraint(cn, sql);
END;
Modified: branches/3.0/raster/test/regress/tickets.sql
--- branches/3.0/raster/test/regress/tickets.sql 2019-10-17 14:36:24 UTC (rev 17938)
+++ branches/3.0/raster/test/regress/tickets.sql 2019-10-17 14:42:35 UTC (rev 17939)
@@ -133,4 +133,12 @@
INSERT INTO table_4308(r) values (NULL);
INSERT INTO table_4308(r) SELECT ST_AddBand(ST_MakeEmptyRaster(10, 10, 1, 1, 2, 2, 0, 0,4326), 1, '8BSI'::text, -129, NULL);;
SELECT AddRasterConstraints('table_4308', 'r');
-DROP TABLE table_4308;
\ No newline at end of file
+DROP TABLE table_4308;
+-- #4547
+CREATE TABLE ticket_4547(r raster);
+SELECT '#4547.1', AddRasterConstraints('ticket_4547', 'r');
+INSERT INTO ticket_4547 VALUES (null);
+INSERT INTO ticket_4547 SELECT ST_AddBand(ST_MakeEmptyRaster(10, 10, 1, 1, 2, 2, 0, 0,4326), 1, '8BSI'::text, -129, NULL);
+SELECT '#4547.2', AddRasterConstraints('ticket_4547', 'r');
+DROP TABLE ticket_4547;
Modified: branches/3.0/raster/test/regress/tickets_expected
--- branches/3.0/raster/test/regress/tickets_expected 2019-10-17 14:36:24 UTC (rev 17938)
+++ branches/3.0/raster/test/regress/tickets_expected 2019-10-17 14:42:35 UTC (rev 17939)
@@ -30,3 +30,42 @@
NOTICE: Adding out-of-database constraint
NOTICE: Adding maximum extent constraint
t
+NOTICE: Adding SRID constraint
+NOTICE: Adding scale-X constraint
+NOTICE: Adding scale-Y constraint
+NOTICE: Adding blocksize-X constraint
+NOTICE: Unable to add constraint: enforce_width_r
+NOTICE: SQL used for failed constraint: ALTER TABLE public.ticket_4547 ADD CONSTRAINT enforce_width_r CHECK (st_width(r) IN ())
+NOTICE: Returned error message: syntax error at or near ")" (42601)
+WARNING: Unable to add constraint: 'blocksize_x'. Skipping
+NOTICE: Adding blocksize-Y constraint
+NOTICE: Unable to add constraint: enforce_height_r
+NOTICE: SQL used for failed constraint: ALTER TABLE public.ticket_4547 ADD CONSTRAINT enforce_height_r CHECK (st_height(r) IN ())
+WARNING: Unable to add constraint: 'blocksize_y'. Skipping
+NOTICE: Adding alignment constraint
+NOTICE: Adding number of bands constraint
+NOTICE: Adding pixel type constraint
+NOTICE: Unable to get the pixel types of a sample raster (max < 1 or null)
+WARNING: Unable to add constraint: 'pixel_types'. Skipping
+NOTICE: Adding nodata value constraint
+NOTICE: Unable to get the nodata values of a sample raster (max < 1 or null)
+WARNING: Unable to add constraint: 'nodata_values'. Skipping
+NOTICE: Adding out-of-database constraint
+NOTICE: Unable to get the out-of-database bands of a sample raster (max < 1 or null)
+WARNING: Unable to add constraint: 'out_db'. Skipping
+NOTICE: Adding maximum extent constraint
+WARNING: Unable to add constraint: 'extent'. Skipping
+#4547.1|t
+#4547.2|t
