[postgis-tickets] [PostGIS] #4546: ST_ConcaveHull fails to execute through FDW
trac at osgeo.org
Thu Oct 17 11:06:22 PDT 2019
Reporter: Algunenano | Owner: pramsey
Type: defect | Status: reopened
Priority: medium | Milestone: PostGIS 2.4.9
Component: postgis | Version: trunk
Resolution: | Keywords:
Changes (by Algunenano):
* status: closed => reopened
* resolution: fixed =>
Comment:
Reopening to remove the search_path and use a proper solution instead.
First I'll revert all commits, then push the C fix and then qualify all
variables using extension types.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4546#comment:8>
