[postgis-tickets] r17947 - Revert r17927
Raul
raul at rmr.ninja
Thu Oct 17 11:08:04 PDT 2019
Author: algunenano
Date: 2019-10-17 11:08:03 -0700 (Thu, 17 Oct 2019)
New Revision: 17947
branches/2.5/NEWS
branches/2.5/postgis/Makefile.in
branches/2.5/postgis/postgis.sql.in
branches/2.5/raster/rt_pg/Makefile.in
branches/2.5/raster/rt_pg/rtpostgis.sql.in
Revert r17927
References #4546
Modified: branches/2.5/NEWS
--- branches/2.5/NEWS 2019-10-17 18:07:13 UTC (rev 17946)
+++ branches/2.5/NEWS 2019-10-17 18:08:03 UTC (rev 17947)
@@ -18,7 +18,6 @@
- #4534, Fix leak in lwcurvepoly_from_wkb_state (Raúl Marín)
- #4536, Fix leak in lwcollection_from_wkb_state (Raúl Marín)
- #4537, Fix leak in WKT collection parser (Raúl Marín)
- - #4546, Fix ST_ConcaveHull under FDW (Raúl Marín)
- #4547, Fix AddRasterConstraints handling of empty tables (Sandro Santilli)
Modified: branches/2.5/postgis/Makefile.in
--- branches/2.5/postgis/Makefile.in 2019-10-17 18:07:13 UTC (rev 17946)
+++ branches/2.5/postgis/Makefile.in 2019-10-17 18:08:03 UTC (rev 17947)
@@ -217,7 +217,7 @@
# replace @extschema at . with nothing, this is only used as placeholder for extension install
%.sql: %.sql.in
$(SQLPP) -I../libpgcommon $< | grep -v '^#' | \
- $(PERL) -lpe "s'MODULE_PATHNAME'\$$libdir/postgis- at POSTGIS_MAJOR_VERSION@. at POSTGIS_MINOR_VERSION@'g;s'@extschema@\.''g;s'SET search_path = @extschema@''g;" > $@
+ $(PERL) -lpe "s'MODULE_PATHNAME'\$$libdir/postgis- at POSTGIS_MAJOR_VERSION@. at POSTGIS_MINOR_VERSION@'g;s'@extschema@\.''g" > $@
postgis_upgrade_for_extension.sql: postgis_drop_before.sql postgis_upgrade_for_extension.sql.in postgis_drop_after.sql
cat $^ > $@
Modified: branches/2.5/postgis/postgis.sql.in
--- branches/2.5/postgis/postgis.sql.in 2019-10-17 18:07:13 UTC (rev 17946)
+++ branches/2.5/postgis/postgis.sql.in 2019-10-17 18:08:03 UTC (rev 17947)
@@ -5370,7 +5370,7 @@
geom := @extschema at .ST_BuildArea(mline);
- IF @extschema at .GeometryType(geom) != 'POLYGON'
+ IF GeometryType(geom) != 'POLYGON'
THEN
RAISE EXCEPTION 'Input returns more then a single polygon, try using BdMPolyFromText instead';
END IF;
@@ -5378,8 +5378,7 @@
RETURN geom;
END;
-LANGUAGE 'plpgsql' IMMUTABLE STRICT _PARALLEL
-SET search_path = @extschema@;
+LANGUAGE 'plpgsql' IMMUTABLE STRICT _PARALLEL;
-- SFSQL 1.1
@@ -5416,8 +5415,7 @@
RETURN geom;
END;
/* Should we include the .sql directly here ? */
#include "long_xact.sql.in"
@@ -5929,8 +5927,7 @@
END;
- LANGUAGE plpgsql IMMUTABLE STRICT _PARALLEL
- SET search_path = @extschema@;
+ LANGUAGE plpgsql IMMUTABLE STRICT _PARALLEL;
-- Availability: 2.0.0
-- Changed: 2.5.0
@@ -6093,7 +6090,6 @@
END;
-- ST_ConcaveHull and Helper functions end here --
Modified: branches/2.5/raster/rt_pg/Makefile.in
--- branches/2.5/raster/rt_pg/Makefile.in 2019-10-17 18:07:13 UTC (rev 17946)
+++ branches/2.5/raster/rt_pg/Makefile.in 2019-10-17 18:08:03 UTC (rev 17947)
@@ -103,7 +103,7 @@
%.sql: %.sql.in
$(SQLPP) -I../../postgis/ -I../../ $< | grep -v '^#' | \
- $(PERL) -lpe "s'MODULE_PATHNAME'\$$libdir/rtpostgis- at POSTGIS_MAJOR_VERSION@. at POSTGIS_MINOR_VERSION@'g;s'@extschema@\.''g;s'SET search_path = @extschema@''g;" > $@
+ $(PERL) -lpe "s'MODULE_PATHNAME'\$$libdir/rtpostgis- at POSTGIS_MAJOR_VERSION@. at POSTGIS_MINOR_VERSION@'g;s'@extschema@\.''g" > $@
rtpostgis_for_extension.sql: rtpostgis.sql.in
Modified: branches/2.5/raster/rt_pg/rtpostgis.sql.in
--- branches/2.5/raster/rt_pg/rtpostgis.sql.in 2019-10-17 18:07:13 UTC (rev 17946)
+++ branches/2.5/raster/rt_pg/rtpostgis.sql.in 2019-10-17 18:08:03 UTC (rev 17947)
@@ -2410,8 +2410,7 @@
RETURN @extschema at ._ST_asraster(g, scale_x, scale_y, NULL, NULL, $3, $4, $5, NULL, NULL, ul_x, ul_y, skew_x, skew_y, $6);
END;
- $$ LANGUAGE 'plpgsql' IMMUTABLE _PARALLEL
+ $$ LANGUAGE 'plpgsql' IMMUTABLE _PARALLEL;
CREATE OR REPLACE FUNCTION st_asraster(
geom geometry,
@@ -7736,8 +7735,7 @@
RETURN @extschema at ._add_raster_constraint(cn, sql);
END;
$$ LANGUAGE 'plpgsql' VOLATILE STRICT
- COST 100
+ COST 100;
CREATE OR REPLACE FUNCTION _drop_raster_constraint_coverage_tile(rastschema name, rasttable name, rastcolumn name)
RETURNS boolean AS
@@ -9099,8 +9097,7 @@
RETURN;
END;
-$$ LANGUAGE 'plpgsql' STABLE STRICT
+$$ LANGUAGE 'plpgsql' STABLE STRICT;
-- ST_CreateOverview
