[postgis-tickets] r17950 - Prep 3.0.0 release notes, purge alpha/beta/rc notes
Regina Obe lr at pcorp.us
Thu Oct 17 07:18:52 PDT 2019
Author: robe
Date: 2019-10-17 19:18:50 -0700 (Thu, 17 Oct 2019)
New Revision: 17950
   trunk/NEWS
   trunk/doc/release_notes.xml
Modified: trunk/NEWS
--- trunk/NEWS	2019-10-17 18:09:19 UTC (rev 17949)
+++ trunk/NEWS	2019-10-18 02:18:50 UTC (rev 17950)
@@ -11,183 +11,12 @@
   - #4544, Fix leak when parsing a WKT geometry_list (Raúl Marín)
   - #4545, Fix leak in wkt_parser_triangle_new (Raúl Marín)
-PostGIS 3.0.0rc2
-2019/10/13
-For full changes and enhancements, refer to PostGIS 3.0.0.
-This version requires PostgreSQL 9.5+-12 and GEOS >= 3.6+
-Additional features enabled if you are running Proj6+ and PostgreSQL 12
-Additional performance enhancements if running GEOS 3.8+
-* Major highlights *
-  - #4534, Fix leak in lwcurvepoly_from_wkb_state (Raúl Marín)
-  - #4536, Fix leak in lwcollection_from_wkb_state (Raúl Marín)
-  - #4537, Fix leak in WKT collection parser (Raúl Marín)
-  - #4535, WKB: Avoid buffer overflow (Raúl Marín)
-PostGIS 3.0.0rc1
-2019/10/08
-  - #4519, Fix getSRIDbySRS crash (Raúl Marín)
-  - #4520, Use a clean environment when detecting C++ libraries (Raúl Marín)
-  - Restore ST_Union() aggregate signature so drop agg not required and re-work
-    performance/size enhancement to continue to avoid
-    using Array type during ST_Union(), hopefully
-    avoiding Array size limitations. (Paul Ramsey)
-PostGIS 3.0.0beta1
-2019/09/28
-  - #4492, Fix ST_Simplify ignoring the value of the 3rd parameter (Raúl Marín)
-  - #4494, Fix ST_Simplify output having an outdated bbox (Raúl Marín)
-  - #4493, Fix ST_RemoveRepeatedPoints output having an outdated bbox (Raúl Marín)
-  - #4495, Fix ST_SnapToGrid output having an outdated bbox (Raúl Marín)
-  - #4496, Make ST_Simplify(TRIANGLE) collapse if requested (Raúl Marín)
-  - #4501, Allow postgis_tiger_geocoder to be installable by non-super users (Regina Obe)
-  - #4503, Speed up the calculation of cartesian bbox (Raúl Marín)
-  - #4504, shp2pgsql -D not working with schema qualified tables (Regina Obe)
-  - #4505, Speed up conversion of geometries to/from GEOS (Dan Baston)
-  - #4507, Use GEOSMakeValid and GEOSBuildArea for GEOS 3.8+ (Dan Baston)
-  - #4491, Speed up ST_RemoveRepeatedPoints (Raúl Marín)
-  - #4509, Update geocoder for tiger 2019 (Regina Obe)
-  - #4338, Census block level data (tabblock table) not loading (Regina Obe)
-PostGIS 3.0.0alpha4
-2019/08/10
-  - #4433, 32-bit hash fix (requires reindexing hash(geometry) indexes) (Raúl Marín)
-  - #4445, Fix a bug in geometry_le (Raúl Marín)
-  - #4451, Fix the calculation of gserialized_max_header_size (Raúl Marín)
-  - #4450, Speed up ST_GeometryType (Raúl Marín)
-  - #4452, Add ST_TileEnvelope() (Paul Ramsey)
-  - #4403, Support for shp2pgsql ability to reproject with copy mode (-D) (Regina Obe)
-  - #4417, Update spatial_ref_sys with new entries (Paul Ramsey)
-  - #4449, Speed up ST_X, ST_Y, ST_Z and ST_M (Raúl Marín)
-  - #4454, Speed up _ST_OrderingEquals (Raúl Marín)
-  - #4453, Speed up ST_IsEmpty (Raúl Marín)
-  - #4271, postgis_extensions_upgrade() also updates after pg_upgrade (Raúl Marín)
-  - #4466, Fix undefined behaviour in _postgis_gserialized_stats (Raúl Marín)
-  - #4209, Handle NULL geometry values in pgsql2shp (Paul Ramsey)
-  - #4419, Use protobuf version to enable/disable mvt/geobuf (Paul Ramsey)
-  - #4437, Handle POINT EMPTY in shape loader/dumper (Paul Ramsey)
-  - #4456, add Rasbery Pi 32-bit jenkins bot for testing (Bruce Rindahl,Regina Obe)
-  - #4420, update path does not exists for address_standardizer extension (Regina Obe)
-PostGIS 3.0.0alpha3
-2019/07/01
-  - #4414, Include version number in address_standardizer lib (Raúl Marín)
-  - #4352, Use CREATE OR REPLACE AGGREGATE for PG12+ (Raúl Marín)
-  - #4334, Fix upgrade issues related to renamed parameters (Raúl Marín)
-  - #4388, AddRasterConstraints: Ignore NULLs when generating constraints (Raúl Marín)
-  - #4327, Avoid pfree'ing the result of getenv (Raúl Marín)
-  - #4406, Throw on invalid characters when decoding geohash (Raúl Marín)
-  - #4429, Avoid resource leaks with PROJ6 (Raúl Marín)
-  - #4372, PROJ6: Speed improvements (Raúl Marín)
-  - #3437, Speed up ST_Intersects with Points (Raúl Marín)
-  - #4438, Update serialization to support extended flags area (Paul Ramsey)
-  - #4443, Fix wagyu configure dropping CPPFLAGS (Raúl Marín)
-  - #4440, Type lookups in FDW fail (Paul Ramsey)
-  - #4442, raster2pgsql now skips NODATA tiles. Use -k option if you still want
-           them in database for some reason. (Darafei Praliaskouski)
-  - #4441, Make GiST penalty friendly to multi-column indexes and build single-column
-           ones faster. (Darafei Praliaskouski)
-PostGIS 3.0.0alpha2
-2019/06/02
-  - #4404, Fix selectivity issue with support functions (Paul Ramsey)
-  - #4311, Make wagyu the default option to validate polygons.
-          This option requires a C++11 compiler and will use CXXFLAGS (not CFLAGS).
-          It only enabled if built with MVT support (protobuf)
-          Add `--without-wagyu` to disable this option and keep the behaviour
-          from 2.5 (Raúl Marín)
-  - #4198, Add ST_ConstrainedDelaunayTriangles SFCGAL function (Darafei
-           Praliaskouski)
-PostGIS 3.0.0alpha1
-2019/05/26
-  - #4341, Using "support function" API in PgSQL 12+ to replace SQL inlining
-           as the mechanism for providing index support under ST_Intersects, et al
-           (Paul Ramsey)
-  - #3888, Raster support now packaged as a separate extension - postgis_raster
-           (Sandro Santilli)
-  - #3807, Extension library files no longer include the minor version.
-           Use New configure switch --with-library-minor-version
-           if you need the old behavior (Regina Obe)
-  - #4322, Support for Proj 6+ API, bringing more accurate datum transforms
-           and support for WKT projections
-  - #4260, liblwgeom headers are not installed anymore.
-           If your project depends on them available, please use
-           librttopo instead. (Darafei Praliaskouski)
-  - #4311, Introduce `--with-wagyu` as an option for MVT polygons (Raúl Marín)
-  - #4258, #4278 Enhance postgis functions ST_Area, ST_Distance, ST_Intersection,
-           ST_Difference, ST_Union, ST_Intersects, ST_3DIntersects, ST_3DDistance
-           to handle types (Solid PolyhedralSurface, TINS) that were only available in SFCGAL.
-           Remove postgis.backend switch. (Darafei Praliaskouski)
-  - #4230, SP-GiST and GiST support for ND box operators overlaps, contains,
-           within, equals (Esteban Zimányi and Arthur Lesuisse from Université
-           Libre de Bruxelles (ULB), Darafei Praliaskouski)
 PostGIS 3.0.0
-2019/xx/xx
+2019/10/xx
+Additional features enabled if you are running Proj6+, PostgreSQL 12, and GEOS 3.8.0
-* Breaking Changes *
-  - #4267, Bump minimum GEOS version to 3.6 (Regina Obe, Darafei Praliaskouski)
-  - #3888, Raster support now available as a separate extension
-           (Sandro Santilli)
-  - #4230, ND box operators (overlaps, contains, within, equals) now don't look on
-           dimensions that aren't present in both operands.
-           Please REINDEX your ND indexes after upgrade. (Darafei Praliaskouski)
-  - #4229, Dropped support for PostgreSQL < 9.5. (Darafei Praliaskouski)
-  - #4258, Remove SFCGAL support for ST_Area, ST_Distance, ST_Intersection,
-           and postgis.backend switch (Darafei Praliaskouski)
-  - #4267, Enable Proj 6 deprecated APIs (Darafei Praliaskouski, Raúl Marín)
-  - #4268, Bump minimum SFCGAL version to 1.3.1 (Darafei Praliaskouski)
-  - #4331, ST_3DMakeBox now returns error instead of a miniscule box (Regina Obe)
-  - #4342, Removed "versioned" variants of ST_AsGeoJSON and ST_AsKML (Paul Ramsey)
-  - #4356, ST_Accum removed. Use array_agg instead. (Darafei Praliaskouski)
-  - #4334, Fix upgrade issues related to renamed function parameters (Raúl Marín)
-  - #3383, Sorting now uses Hilbert curve and Postgres Abbreviated Compare.
-           You need to REINDEX your btree indexes if you had them.
-           (Darafei Praliaskouski)
 * New Features *
   - #2902, postgis_geos_noop (Sandro Santilli)
   - #4128, ST_AsMVT support for Feature ID (Stepan Kuzmin)
@@ -274,35 +103,37 @@
   - #4328, ST_3DIntersects for 2D TINs. (Darafei Praliaskouski)
-* Fixes *
-  - #4342, Move deprecated functions into legacy.sql file
-  - #4189, Fix undefined behaviour in SADFWrite (Raúl Marín)
-  - #4191, Fix undefined behaviour in ptarray_clone_deep (Raúl Marín)
-  - #4211, Fix ST_Subdivide for minimal exterior ring with minimal hole (Darafei
-           Praliaskouski)
-  - #4326, Allocate enough memory in gidx_to_string (Raúl Marín)
-  - #4190, Avoid undefined behaviour in gserialized_estimate (Raúl Marín)
-  - #4233, Fix undefined behaviour in gserialized_spgist_picksplit_nd (Raúl Marín)
-  - #4247, Avoid undefined behaviour in next_float functions (Raúl Marín)
-  - #4249, Fix undefined behaviour in raster intersection (Raúl Marín)
-  - #4246, Fix undefined behaviour in ST_3DDistance (Raúl Marín)
-  - #4188, Avoid division by zero in KMeans (Raúl Marín)
-  - #3457, Fix raster envelope shortcut in ST_Clip (Sai-bot)
-  - #4361, Fix postgis_type_name with (GEOMETRYM,3) (Matt Bretl)
-  - #4275, Avoid passing a NULL pointer to GEOSisEmpty (Raúl Marín)
-  - #4296, Use `server_version_num` instead of parsing `version()` (Raúl Marín)
-  - #4314, ST_ClipByBox2D: Do not throw when the geometry is invalid (Raúl Marín)
-  - #4383, Fix undefined behaviour in implicit conversions (Raúl Marín)
+* Breaking Changes *
+  - #4267, Bump minimum GEOS version to 3.6 (Regina Obe, Darafei Praliaskouski)
+  - #3888, Raster support now available as a separate extension
+           (Sandro Santilli)
+  - #3807, Extension library files no longer include the minor version.
+           Use New configure switch --with-library-minor-version
+           if you need the old behavior (Regina Obe)
+  - #4230, ND box operators (overlaps, contains, within, equals) now don't look on
+           dimensions that aren't present in both operands.
+           Please REINDEX your ND indexes after upgrade. (Darafei Praliaskouski)
+  - #4229, Dropped support for PostgreSQL < 9.5. (Darafei Praliaskouski)
+  - #4260, liblwgeom headers are not installed anymore.
+           If your project depends on them available, please use
+           librttopo instead. (Darafei Praliaskouski)
+  - #4258, Remove SFCGAL support for ST_Area, ST_Distance, ST_Intersection,
+           ST_Difference, ST_Union, ST_Intersects, ST_3DIntersects, ST_3DDistance
+           and postgis.backend switch (Darafei Praliaskouski)
+  - #4267, Enable Proj 6 deprecated APIs (Darafei Praliaskouski, Raúl Marín)
+  - #4268, Bump minimum SFCGAL version to 1.3.1 (Darafei Praliaskouski)
+  - #4331, ST_3DMakeBox now returns error instead of a miniscule box (Regina Obe)
+  - #4342, Removed "versioned" variants of ST_AsGeoJSON and ST_AsKML (Paul Ramsey)
+  - #4356, ST_Accum removed. Use array_agg instead. (Darafei Praliaskouski)
+  - #4414, Include version number in address_standardizer lib (Raúl Marín)
-  - #4459, Fix ST_Subdivide crash on intermediate EMPTY (Darafei Praliaskouski)
-  - #4470, ST_GeomFromGeoJSON crash on empty rings (Darafei Praliaskouski)
-  - #4387, Re-enable OSS Fuzz and fuzz geojson parser (Darafei Praliaskouski)
+  - #4442, raster2pgsql now skips NODATA tiles. Use -k option if you still want
+           them in database for some reason. (Darafei Praliaskouski)
+  - #4433, 32-bit hash fix (requires reindexing hash(geometry) indexes) (Raúl Marín)
+  - #3383, Sorting now uses Hilbert curve and Postgres Abbreviated Compare.
+           You need to REINDEX your btree indexes if you had them.
+           (Darafei Praliaskouski)
 PostGIS 2.5.0
 2018/09/23
 WARNING: If compiling with PostgreSQL+JIT, LLVM >= 6 is required
Modified: trunk/doc/release_notes.xml
--- trunk/doc/release_notes.xml	2019-10-17 18:09:19 UTC (rev 17949)
+++ trunk/doc/release_notes.xml	2019-10-18 02:18:50 UTC (rev 17950)
@@ -2,7 +2,136 @@
 <appendix id="release_notes">
   <title>Appendix</title>
     <subtitle>Release Notes</subtitle>
     <sect1>
+        <title>Release 3.0.0</title>
+        <para>Release date: 2019/10/20</para>
+        <para>This version requires PostgreSQL 9.5+-12 and GEOS >= 3.6+
+              Additional features and enhancements enabled if you are running Proj6+, PostgreSQL 12, and GEOS 3.8.0</para>
+      <simplesect>
+        <title>New Features</title>
+          <para>2902, postgis_geos_noop (Sandro Santilli)</para>
+          <para>4128, ST_AsMVT support for Feature ID (Stepan Kuzmin)</para>
+          <para>4230, SP-GiST and GiST support for ND box operators overlaps, contains,
+                    within, equals (Esteban Zimányi and Arthur Lesuisse from Université
+                    Libre de Bruxelles (ULB), Darafei Praliaskouski)</para>
+          <para>4171, ST_3DLineInterpolatePoint (Julien Cabieces, Vincent Mora)</para>
+          <para>4311, Introduce WAGYU to validate MVT polygons. This option requires a C++11
+                    compiler and will use CXXFLAGS (not CFLAGS). Add `--without-wagyu`
+                    to disable this option and keep the behaviour from 2.5 (Raúl Marín)</para>
+          <para>1833, ST_AsGeoJSON(row) generates full GeoJSON Features (Joe Conway)</para>
+          <para>3687, Casts json(geometry) and jsonb(geometry) for implicit GeoJSON
+                    generation (Paul Ramsey)</para>
+          <para>4198, Add ST_ConstrainedDelaunayTriangles SFCGAL function (Darafei
+                    Praliaskouski)</para>
+        </simplesect>
+      <simplesect>
+        <title>Breaking Changes</title>
+          <para>4267, Bump minimum GEOS version to 3.6 (Regina Obe, Darafei Praliaskouski)</para>
+          <para>3888, Raster support now available as a separate extension
+                    (Sandro Santilli)</para>
+          <para>3807, Extension library files no longer include the minor version.
+                    if you need the old behavior (Regina Obe)</para>
+          <para>4230, ND box operators (overlaps, contains, within, equals) now don't look on
+                    Please REINDEX your ND indexes after upgrade. (Darafei Praliaskouski)</para>
+          <para>4229, Dropped support for PostgreSQL < 9.5. (Darafei Praliaskouski)</para>
+          <para>4260, liblwgeom headers are not installed anymore.
+                    librttopo instead. (Darafei Praliaskouski)</para>
+          <para>4258, Remove SFCGAL support for ST_Area, ST_Distance, ST_Intersection,
+                    and postgis.backend switch (Darafei Praliaskouski)</para>
+          <para>4267, Enable Proj 6 deprecated APIs (Darafei Praliaskouski, Raúl Marín)</para>
+          <para>4268, Bump minimum SFCGAL version to 1.3.1 (Darafei Praliaskouski)</para>
+          <para>4331, ST_3DMakeBox now returns error instead of a miniscule box (Regina Obe)</para>
+          <para>4342, Removed "versioned" variants of ST_AsGeoJSON and ST_AsKML (Paul Ramsey)</para>
+          <para>4356, ST_Accum removed. Use array_agg instead. (Darafei Praliaskouski)</para>
+          <para>4414, Include version number in address_standardizer lib (Raúl Marín)</para>
+          <para>4334, Fix upgrade issues related to renamed function parameters (Raúl Marín)</para>
+          <para>4442, raster2pgsql now skips NODATA tiles. Use -k option if you still want
+                    them in database for some reason. (Darafei Praliaskouski)</para>
+          <para>4433, 32-bit hash fix (requires reindexing hash(geometry) indexes) (Raúl Marín)</para>
+          <para>3383, Sorting now uses Hilbert curve and Postgres Abbreviated Compare.
+                    (Darafei Praliaskouski)</para>
+      </simplesect>
+      <simplesect>
+          <title>Enhancements</title>
+          <para>4341, Using "support function" API in PgSQL 12+ to replace SQL inlining
+           as the mechanism for providing index support under ST_Intersects, et al</para>
+          <para>4330, postgis_restore OOM when output piped to an intermediate process
+                    (Hugh Ranalli)</para>
+          <para>4322, Support for Proj 6+ API, bringing more accurate datum transforms
+                    and support for WKT projections</para>
+          <para>4153, ST_Segmentize now splits segments proportionally (Darafei
+                    Praliaskouski).</para>
+          <para>4162, ST_DWithin documentation examples for storing geometry and
+                    radius in table (Darafei Praliaskouski, github user Boscop).</para>
+          <para>4161 and #4294, ST_AsMVTGeom: Shortcut geometries smaller than the
+                    resolution (Raúl Marín)</para>
+          <para>4176, ST_Intersects supports GEOMETRYCOLLECTION (Darafei Praliaskouski)</para>
+          <para>4181, ST_AsMVTGeom: Avoid type changes due to validation (Raúl Marín)</para>
+          <para>4183, ST_AsMVTGeom: Drop invalid geometries after simplification (Raúl Marín)</para>
+          <para>4196, Have postgis_extensions_upgrade() package unpackaged extensions
+          <para>4215, Use floating point compare in ST_DumpAsPolygons (Darafei Praliaskouski)</para>
+          <para>4155, Support for GEOMETRYCOLLECTION, POLYGON, TIN, TRIANGLE in
+                    ST_LocateBetween and ST_LocateBetweenElevations (Darafei Praliaskouski)</para>
+          <para>2767, Documentation for AddRasterConstraint optional parameters (Sunveer Singh)</para>
+          <para>4244, Avoid unaligned memory access in BOX2D_out (Raúl Marín)</para>
+          <para>4139, Make mixed-dimension ND index build tree correctly (Darafei Praliaskouski,
+                    Arthur Lesuisse, Andrew Gierth, Raúl Marín)</para>
+          <para>4262, Document MULTISURFACE compatibility of ST_LineToCurve (Steven Ottens)</para>
+          <para>4276, ST_AsGeoJSON documentation refresh (Darafei Praliaskouski)</para>
+          <para>4292, ST_AsMVT: parse JSON numeric values with decimals as doubles (Raúl Marín)</para>
+          <para>4300, ST_AsMVTGeom: Always return the simplest geometry (Raúl Marín)</para>
+          <para>4301, ST_Subdivide: fix endless loop on coordinates near coincident to bounds
+          <para>4289, ST_AsMVTGeom: Transform coordinates space before clipping (Raúl Marín)</para>
+          <para>4272, Improve notice message when unable to compute stats (Raúl Marín)</para>
+          <para>4313, #4307, PostgreSQL 12 compatibility (Laurenz Albe, Raúl Marín)</para>
+          <para>4299, #4304, ST_GeneratePoints is now VOLATILE. IMMUTABLE version with
+                    seed parameter added. (Mike Taves)</para>
+          <para>4278, ST_3DDistance and ST_3DIntersects now support Solid TIN and Solid
+                    POLYHEDRALSURFACE (Darafei Praliaskouski)</para>
+          <para>4348, ST_AsMVTGeom (GEOS): Enforce validation at all times (Raúl Marín)</para>
+          <para>4295, Allow GEOMETRYCOLLECTION in ST_Overlaps, ST_Contains, ST_ContainsProperly,
+                    ST_Covers, ST_CoveredBy, ST_Crosses, ST_Touches, ST_Disjoint, ST_Relate,
+                    ST_Equals (Esteban Zimányi)</para>
+          <para>4340, ST_Union aggregate now can handle more than 1 GB of geometries
+          <para>4378, Allow passing TINs as input to GEOS-backed functions (Darafei
+          <para>4368, Reorder LWGEOM struct members to minimize extra padding (Raúl Marín)</para>
+          <para>4141, Use uint64 to handle row counts in the topology extension (Raúl Marín)</para>
+          <para>4412, Support ingesting rasters with NODATA=NaN (Darafei Praliaskouski)</para>
+          <para>4413, Raster tile size follows GeoTIFF block size on raster2pgsql -t auto
+          <para>4422, Modernize Python 2 code to get ready for Python 3 (Christian Clauss)</para>
+          <para>4352, Use CREATE OR REPLACE AGGREGATE for PG12+ (Raúl Marín)</para>
+          <para>4394, Allow FULL OUTER JOIN on geometry equality operator (Darafei Praliaskouski)</para>
+          <para>4441, Make GiST penalty friendly to multi-column indexes and build single-column
+                    ones faster. (Darafei Praliaskouski)</para>
+          <para>4403, Support for shp2pgsql ability to reproject with copy mode (-D) (Regina Obe)</para>
+          <para>4410, More descriptive error messages about SRID mismatch (Darafei Praliaskouski)</para>
+          <para>4399, TIN and Triangle output support in all output functions (Darafei
+          <para>3719, Impose minimum number of segments per arc during linearization
+                    (Dan Baston / City of Helsinki, Raúl Marín)</para>
+          <para>4277, ST_GeomFromGeoJSON now marks SRID=4326 by default as per RFC7946,
+                    ST_AsGeoJSON sets SRID in JSON output if it differs from 4326.
+          <para>3979, postgis_sfcgal_noop() round trip function (Lucas C. Villa Real)</para>
+          <para>4328, ST_3DIntersects for 2D TINs. (Darafei Praliaskouski)</para>
+          <para>4509, Update geocoder for tiger 2019 (Regina Obe)</para>
+      </simplesect>
+    </sect1>
+    <sect1>
       <title>Release 3.0.0rc2</title>
       <para>Release date: 2019/10/13</para>
       <para>If compiling with PostgreSQL+JIT, LLVM >= 6 is required</para>
