[postgis-tickets] [PostGIS] #4549: ST_Dump* results in geometry_dump does not exists when postgis schema not in search_path
PostGIS trac at osgeo.org
Fri Oct 18 01:42:35 PDT 2019
in search_path
  Reporter:  robe     |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  medium   |  Milestone:  PostGIS 2.5.4
 Component:  postgis  |    Version:  2.5.x
Resolution:           |   Keywords:
Comment (by Raul Marin):
 In [changeset:"17951" 17951]:
 #!CommitTicketReference repository="" revision="17951"
 Use get_call_result_type to retrieve tuple descriptions
 Closes #499
 References #4549
 References #4546
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4549#comment:2>
