[postgis-tickets] [PostGIS] #4551: Regress: Use --schema= option to change were the extension is installed
PostGIS trac at osgeo.org
Fri Oct 18 05:05:04 PDT 2019
 Reporter:  Algunenano   |      Owner:  pramsey
     Type:  enhancement  |     Status:  new
 Priority:  medium       |  Milestone:  PostGIS 3.1.0
Component:  postgis      |    Version:  trunk
 Keywords:               |
 Currently the "--schema" option is used to check functions that might
 access objects or relations in the extension. We should extend it and use
 it also to install the extension into that schema.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4551>
