[postgis-tickets] [PostGIS] #4549: ST_Dump* results in geometry_dump does not exists when postgis schema not in search_path
PostGIS trac at osgeo.org
Fri Oct 18 05:21:26 PDT 2019
in search_path
  Reporter:  robe     |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  medium   |  Milestone:  PostGIS 2.5.4
 Component:  postgis  |    Version:  2.5.x
Resolution:           |   Keywords:
Comment (by Raul Marin):
 In [changeset:"17956" 17956]:
 #!CommitTicketReference repository="" revision="17956"
 Fix schema qualification of internal types
 References #4549
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4549#comment:4>
