[postgis-tickets] r17958 - Fix schema qualification of internal types
Raul
raul at rmr.ninja
Fri Oct 18 05:23:45 PDT 2019
Author: algunenano
Date: 2019-10-18 05:23:44 -0700 (Fri, 18 Oct 2019)
New Revision: 17958
branches/2.5/NEWS
branches/2.5/postgis/lwgeom_dump.c
branches/2.5/postgis/lwgeom_geos.c
branches/2.5/regress/dump.sql
branches/2.5/regress/dump_expected
branches/2.5/regress/isvaliddetail.sql
branches/2.5/regress/isvaliddetail_expected
branches/2.5/regress/run_test.pl
References #4549
Modified: branches/2.5/NEWS
--- branches/2.5/NEWS 2019-10-18 12:22:22 UTC (rev 17957)
+++ branches/2.5/NEWS 2019-10-18 12:23:44 UTC (rev 17958)
@@ -19,6 +19,7 @@
- #4536, Fix leak in lwcollection_from_wkb_state (Raúl Marín)
- #4537, Fix leak in WKT collection parser (Raúl Marín)
- #4547, Fix AddRasterConstraints handling of empty tables (Sandro Santilli)
+ - #4549, Fix schema qualification of internal types (Raúl Marín)
PostGIS 2.5.3
Modified: branches/2.5/postgis/lwgeom_dump.c
--- branches/2.5/postgis/lwgeom_dump.c 2019-10-18 12:22:22 UTC (rev 17957)
+++ branches/2.5/postgis/lwgeom_dump.c 2019-10-18 12:23:44 UTC (rev 17958)
@@ -118,7 +118,8 @@
* Build a tuple description for an
* geometry_dump tuple
- tupdesc = RelationNameGetTupleDesc("geometry_dump");
+ get_call_result_type(fcinfo, 0, &tupdesc);
+ BlessTupleDesc(tupdesc);
* generate attribute metadata needed later to produce
@@ -256,7 +257,8 @@
Modified: branches/2.5/postgis/lwgeom_geos.c
--- branches/2.5/postgis/lwgeom_geos.c 2019-10-18 12:22:22 UTC (rev 17957)
+++ branches/2.5/postgis/lwgeom_geos.c 2019-10-18 12:23:44 UTC (rev 17958)
@@ -1489,12 +1489,8 @@
* valid_detail tuple
- tupdesc = RelationNameGetTupleDesc("valid_detail");
- if ( ! tupdesc )
- lwpgerror("TYPE valid_detail not found");
- PG_RETURN_NULL();
Modified: branches/2.5/regress/dump.sql
--- branches/2.5/regress/dump.sql 2019-10-18 12:22:22 UTC (rev 17957)
+++ branches/2.5/regress/dump.sql 2019-10-18 12:23:44 UTC (rev 17958)
@@ -178,3 +178,15 @@
+-- Check that it works without the extension schema being available
+BEGIN;
+SET search_path TO pg_catalog;
+WITH data AS
+ SELECT 'POLYGON((0 0, 0 1, 1 1, 1 0, 0 0))':: :schema geometry as geom
+SELECT 't12',
+ :schema ST_AsText((public.ST_Dump(geom)).geom),
+ :schema ST_AsText((public.ST_DumpRings(geom)).geom) FROM data;
+ROLLBACK;
Modified: branches/2.5/regress/dump_expected
--- branches/2.5/regress/dump_expected 2019-10-18 12:22:22 UTC (rev 17957)
+++ branches/2.5/regress/dump_expected 2019-10-18 12:23:44 UTC (rev 17958)
@@ -16,3 +16,4 @@
t9|{5,1}|POLYGON((0 0,0 9,9 9,9 0,0 0),(5 5,5 6,6 6,5 5))
t10|0
t11|0
+t12|POLYGON((0 0,0 1,1 1,1 0,0 0))|POLYGON((0 0,0 1,1 1,1 0,0 0))
Modified: branches/2.5/regress/isvaliddetail.sql
--- branches/2.5/regress/isvaliddetail.sql 2019-10-18 12:22:22 UTC (rev 17957)
+++ branches/2.5/regress/isvaliddetail.sql 2019-10-18 12:23:44 UTC (rev 17958)
@@ -48,3 +48,13 @@
select '5r', ST_IsValidReason(
'POLYGON ((70 250, 40 500, 100 400, 70 250, 80 350, 60 350, 70 250))' , 1);
+BEGIN;
+select 7, valid, reason, :schema st_astext(location) FROM (
+ SELECT (:schema ST_IsValidDetail(
+ 'POLYGON ((70 250, 70 500, 80 400, 40 400, 70 250))':: :schema geometry
+) foo;
+ROLLBACK;
Modified: branches/2.5/regress/isvaliddetail_expected
--- branches/2.5/regress/isvaliddetail_expected 2019-10-18 12:22:22 UTC (rev 17957)
+++ branches/2.5/regress/isvaliddetail_expected 2019-10-18 12:23:44 UTC (rev 17958)
@@ -8,3 +8,4 @@
6|t||
6s|t
5r|Valid Geometry
+7|f|Self-intersection|POINT(70 400)
Modified: branches/2.5/regress/run_test.pl
--- branches/2.5/regress/run_test.pl 2019-10-18 12:22:22 UTC (rev 17957)
+++ branches/2.5/regress/run_test.pl 2019-10-18 12:23:44 UTC (rev 17958)
@@ -70,6 +70,7 @@
our $OPT_UPGRADE_FROM = '';
my $OPT_UPGRADE_TO = '';
my $VERBOSE = 0;
+my $OPT_SCHEMA = 'public';
GetOptions (
'verbose' => \$VERBOSE,
@@ -83,7 +84,8 @@
'raster' => \$OPT_WITH_RASTER,
'sfcgal' => \$OPT_WITH_SFCGAL,
'expect' => \$OPT_EXPECT,
- 'extensions' => \$OPT_EXTENSIONS
+ 'extensions' => \$OPT_EXTENSIONS,
+ 'schema=s' => \$OPT_SCHEMA
if ( @ARGV < 1 )
@@ -726,7 +728,8 @@
. " -v \"tmpfile='$tmpfile'\""
. " -v \"scriptdir=$scriptdir\""
. " -v \"regdir=$REGDIR\""
- . " -tXA $DB < $sql > $outfile 2>&1";
+ . " -v \"schema=$OPT_SCHEMA.\""
+ . " -tXAq $DB < $sql > $outfile 2>&1";
my $rv = system($cmd);
# Check for ERROR lines
