[postgis-tickets] r17971 - [run_test] Use --schema as target for creating and finding postgis
Sandro Santilli
strk at kbt.io
Fri Oct 18 08:05:41 PDT 2019
Author: strk
Date: 2019-10-18 08:05:41 -0700 (Fri, 18 Oct 2019)
New Revision: 17971
trunk/regress/run_test.pl
Closes #4551
Modified: trunk/regress/run_test.pl
--- trunk/regress/run_test.pl 2019-10-18 15:01:56 UTC (rev 17970)
+++ trunk/regress/run_test.pl 2019-10-18 15:05:41 UTC (rev 17971)
@@ -69,8 +69,8 @@
my $OPT_UPGRADE_PATH = '';
our $OPT_UPGRADE_FROM = '';
my $OPT_UPGRADE_TO = '';
-my $VERBOSE = 0;
-my $OPT_SCHEMA = 'public';
+our $VERBOSE = 0;
+our $OPT_SCHEMA = 'public';
GetOptions (
'verbose' => \$VERBOSE,
@@ -590,6 +590,8 @@
if available.
--dumprestore dump and restore spatially-enabled db before running tests
--nodrop do not drop the regression database on exit
+ --schema where to install/find PostGIS (relocatable) PostGIS
+ (defaults to "public")
--raster load also raster extension
--topology load also topology extension
--sfcgal use also sfcgal backend
@@ -712,7 +714,7 @@
sub sql
my $sql = shift;
- my $result = `psql -tXA -d $DB -c "$sql"`;
+ my $result = `psql -qtXA -d $DB -c 'SET search_path TO public,$OPT_SCHEMA' -c "$sql"`;
$result =~ s/[\n\r]*$//;
$result;
@@ -773,7 +775,8 @@
. " -v \"scriptdir=$scriptdir\""
. " -v \"regdir=$REGDIR\""
. " -v \"schema=$OPT_SCHEMA.\""
- . " -tXAq $DB < $sql > $outfile 2>&1";
+ . " -c \"SET search_path TO public,$OPT_SCHEMA\""
+ . " -tXAq $DB -f $sql > $outfile 2>&1";
my $rv = system($cmd);
# Check for ERROR lines
@@ -1335,7 +1338,9 @@
# ON_ERROR_STOP is used by psql to return non-0 on an error
my $psql_opts = "--no-psqlrc --variable ON_ERROR_STOP=true";
- my $cmd = "psql $psql_opts -Xf $file $DB >> $REGRESS_LOG 2>&1";
+ my $cmd = "psql $psql_opts -c 'CREATE SCHEMA IF NOT EXISTS $OPT_SCHEMA' ";
+ $cmd .= "-c 'SET search_path TO $OPT_SCHEMA'";
+ $cmd .= " -Xf $file $DB >> $REGRESS_LOG 2>&1";
print " $file\n" if $VERBOSE;
if ( $rv )
@@ -1352,6 +1357,15 @@
+ my $sql = "CREATE SCHEMA IF NOT EXISTS ${OPT_SCHEMA}";
+ my $cmd = "psql $psql_opts -c \"". $sql . "\" $DB >> $REGRESS_LOG 2>&1";
+ my $rv = system($cmd);
+ if ( $rv ) {
+ fail "Error encountered creating target schema ${OPT_SCHEMA}", $REGRESS_LOG;
+ die;
my $sql = "CREATE EXTENSION postgis";
if ( $OPT_UPGRADE_FROM ) {
@@ -1362,6 +1376,8 @@
$sql .= " VERSION '" . $OPT_UPGRADE_FROM . "'";
+ $sql .= " SCHEMA " . $OPT_SCHEMA;
print "Preparing db '${DB}' using: ${sql}\n";
@@ -1401,6 +1417,8 @@
$cmd = "psql $psql_opts -c \"" . $sql . "\" $DB >> $REGRESS_LOG 2>&1";
@@ -1425,6 +1443,8 @@
