[postgis-tickets] [PostGIS] #4551: Regress: Use --schema= option to change were the extension is installed
PostGIS trac at osgeo.org
Fri Oct 18 08:05:42 PDT 2019
  Reporter:  Algunenano   |      Owner:  pramsey
      Type:  enhancement  |     Status:  closed
  Priority:  medium       |  Milestone:  PostGIS 3.1.0
 Component:  postgis      |    Version:  trunk
Resolution:  fixed        |   Keywords:
Changes (by strk):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 In [changeset:"17971" 17971]:
 #!CommitTicketReference repository="" revision="17971"
 [run_test] Use --schema as target for creating and finding postgis
 Closes #4551
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4551#comment:2>
