[postgis-tickets] [PostGIS] #4553: tickets.sql fail with --schema postgis (UpdateGeometrySRID?)
PostGIS trac at osgeo.org
Fri Oct 18 08:20:29 PDT 2019
  Reporter:  strk     |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  medium   |  Milestone:  PostGIS 3.0.0
 Component:  postgis  |    Version:  trunk
Resolution:           |   Keywords:
Comment (by strk):
 Note that the bug only occurs when NOT running in EXTENSION mode (just add
 --extension to the run and the test will pass)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4553#comment:1>
