[postgis-tickets] [PostGIS] #4554: winnie failing with role "-f" does not exist
PostGIS trac at osgeo.org
Sun Oct 20 02:01:00 PDT 2019
  Reporter:  robe       |      Owner:  robe
      Type:  defect     |     Status:  closed
  Priority:  blocker    |  Milestone:  PostGIS 3.1.0
 Component:  buildbots  |    Version:  trunk
Resolution:  fixed      |   Keywords:
Changes (by strk):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 In [changeset:"17985" 17985]:
 #!CommitTicketReference repository="" revision="17985"
 [run_test] Use -f _before_ DB argument
 Windows version of psql might be picky about it
 Hopefully closes #4554
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4554#comment:1>
