[postgis-tickets] [PostGIS] #4555: Can't repackage postgis_raster with postgis_extensions_upgrade when postgis not installed in public
PostGIS trac at osgeo.org
Sun Oct 20 17:14:51 PDT 2019
 Reporter:  robe                   |      Owner:  strk
     Type:  defect                 |     Status:  new
 Priority:  blocker                |  Milestone:  PostGIS 3.0.1
Component:  build/upgrade/install  |    Version:  3.0.x
 Keywords:                         |
 CREATE SCHEMA postgis;
 ALTER DATABASE test SET search_path=public, contrib, postgis, tiger,
 utility;
 -- reconnect
 CREATE EXTENSION postgis SCHEMA postgis VERSION "2.5.3";
 -- disconnect
 -- reconnect
 SELECT postgis_full_version(); --is at 2.5.3
 SELECT postgis_extensions_upgrade();
 -- outputs
 POSTGIS="3.0.0 r17983" [EXTENSION] PGSQL="110" GEOS="3.8.0-CAPI-1.13.1 "
 PROJ="Rel. 5.2.0, September 15th, 2018" GDAL="GDAL 2.4.2, released
 2019/06/28" LIBXML="2.9.9" LIBJSON="0.12" LIBPROTOBUF="1.2.1" WAGYU="0.4.3
 (Internal)" RASTER (raster lib from "2.5.3 r17699" need upgrade)
 [UNPACKAGED!] (raster procs from "2.5.3 r17699" need upgrade)
 Repeat again
 Gives error:
 NOTICE:  Packaging extension postgis_raster
 WARNING:  'postgis.gdal_datapath' is already set and cannot be changed
 until you reconnect
 WARNING:  'postgis.gdal_enabled_drivers' is already set and cannot be
 changed until you reconnect
 WARNING:  'postgis.enable_outdb_rasters' is already set and cannot be
 ERROR:  function public.st_srid(geometry) does not exist
 LINE 1: ..._makeemptyraster($1, $2, $3, $4, $5, -($5), 0, 0, public.ST_...
 HINT:  No function matches the given name and argument types. You might
 need to add explicit type casts.
 QUERY:   SELECT  public.ST_makeemptyraster($1, $2, $3, $4, $5, -($5), 0,
 0, public.ST_SRID('POINT(0 0)'::geometry))
 CONTEXT:  SQL statement "CREATE EXTENSION postgis_raster FROM unpackaged"
 PL/pgSQL function postgis_extensions_upgrade() line 48 at EXECUTE
 SQL state: 42883
 To force repackaging I had to do this:
 CREATE EXTENSION postgis_raster FROM unpackaged VERSION "3.0.0" SCHEMA
 postgis;
 I thought I had tested this already, but I've always been doing
 ALTER EXTENSION postgis UPDATE;
 So perhaps this only happens if you don't do ALTER EXTENSION postgis
 UPDATE because the 2.5.3 is incomplet.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4555>
