[postgis-tickets] r17987 - Remove unused .drone.yml file (we use .drone-1.0.yml now)
Sandro Santilli strk at kbt.io
Sun Oct 20 10:00:07 PDT 2019
Author: strk
Date: 2019-10-20 22:00:07 -0700 (Sun, 20 Oct 2019)
New Revision: 17987
Removed:
   branches/2.3/.drone.yml
Deleted: branches/2.3/.drone.yml
--- branches/2.3/.drone.yml	2019-10-21 04:59:57 UTC (rev 17986)
+++ branches/2.3/.drone.yml	2019-10-21 05:00:07 UTC (rev 17987)
@@ -1,34 +0,0 @@
-# See http://readme.drone.io/0.5/usage/overview
-# See https://git.osgeo.org/gitea/postgis/postgis-docker
-test-image: &test-image docker.kbt.io/postgis/build-test:trisquel2
-matrix:
-  PGVER:
-    - 9.3
-    - 9.4
-    - 9.5
-    - 9.6
-pipeline:
-  clone:
-    image: plugins/git
-    depth: 20
-    recursive: false
-  build:
-    image: *test-image
-    pull: true
-    commands:
-      - service postgresql start $PGVER
-      - export PGPORT=`grep ^port /etc/postgresql/$PGVER/main/postgresql.conf | awk '{print $3}'`
-      - export PATH=/usr/lib/postgresql/$PGVER/bin:$PATH
-      - psql --version
-      - ./autogen.sh
-      - ./configure CFLAGS="-O0 -Wall -fno-omit-frame-pointer" --without-interrupt-tests
-      - make
-      # we should maybe wait for postgresql service to startup here...
-      - psql -c "select version()" template1
-      - make check RUNTESTFLAGS=-v
-      - make install
-      - utils/check_all_upgrades.sh
-        `grep '^POSTGIS_' Version.config | cut -d= -f2 | paste -sd '.'`
