[postgis-tickets] [PostGIS] #4556: st_asmvtgeom sometimes produces leaking polygons (postgis 3.0)
PostGIS trac at osgeo.org
Wed Oct 23 06:23:38 PDT 2019
  Reporter:  anneb    |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  medium   |  Milestone:  PostGIS 3.0.0
 Component:  postgis  |    Version:
Resolution:           |   Keywords:
Comment (by anneb):
 I believe just commenting out line:
 lwgeom_simplify_in_place(lwgeom, res, preserve_collapsed);
 is enough to solve the problem.
 After rebuilding, I tried this and several previous problematic polygons
 and they are now all output correctly.
 Commenting out only line
 lwgeom_remove_repeated_points_in_place
 does not solve the polygon-leak problem.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4556#comment:2>
