[postgis-tickets] [PostGIS] #4559: [raster] PG 13 / GDAL 3.1: rt_gdalwarp regress failing
trac at osgeo.org
Fri Oct 25 06:52:46 PDT 2019
Reporter: Algunenano | Owner: Bborie Park
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.1.0
Component: raster | Version: trunk
Keywords: |
Ther are a bunch of new notices in raster related to SRID values over
SRID_MAXIMUM:
rt_gdalwarp .. failed (diff expected obtained: /tmp/pgis_reg/test_52_diff)
--- rt_gdalwarp_expected 2019-10-25 13:40:29.000000000 +0000
+++ /tmp/pgis_reg/test_52_out 2019-10-25 13:46:31.848481999 +0000
@@ -7,27 +7,153 @@
NOTICE: Raster has default geotransform. Adjusting metadata for use of
GDAL Warp API
NOTICE: Values must be provided for both X and Y when specifying the
scale. Returning original raster
+NOTICE: SRID value 2139062143 > SRID_MAXIMUM converted to 999346
There are other failures too:
-1.10|993310|141|87|1|1000.000|-1000.000|0.000|0.000|-175453.086|114987.661|32BF|0.000|t|1.000|1.000|
+1.10|128|0|0|1|1000.000|0.000|0.000|1000.000|0.000|0.000|32BF|0.000|t|1.000|1.000|
Build example: https://travis-ci.org/postgis/postgis/jobs/602060439
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4559>
