[postgis-tickets] r17990 - Unify how libm is added to the LDFLAGS
Raul
raul at rmr.ninja
Fri Oct 25 07:17:09 PDT 2019
Author: algunenano
Date: 2019-10-25 07:17:07 -0700 (Fri, 25 Oct 2019)
New Revision: 17990
trunk/NEWS
trunk/configure.ac
trunk/doc/html/image_src/Makefile.in
trunk/liblwgeom/Makefile.in
trunk/liblwgeom/cunit/Makefile.in
trunk/loader/cunit/Makefile.in
trunk/raster/loader/Makefile.in
trunk/raster/test/cunit/Makefile.in
Different objects or libraries where including it individually,
and some of them didn't which can caused issues depending on
the linker options
Closes https://github.com/postgis/postgis/pull/491/
Closes #4539
Modified: trunk/NEWS
--- trunk/NEWS 2019-10-23 22:46:02 UTC (rev 17989)
+++ trunk/NEWS 2019-10-25 14:17:07 UTC (rev 17990)
@@ -5,7 +5,7 @@
* New features *
+ - #4539, Unify libm includes (Raúl Marín)
* Bug fixes *
- #4544, Fix leak when parsing a WKT geometry_list (Raúl Marín)
Modified: trunk/configure.ac
--- trunk/configure.ac 2019-10-23 22:46:02 UTC (rev 17989)
+++ trunk/configure.ac 2019-10-25 14:17:07 UTC (rev 17990)
@@ -80,6 +80,11 @@
AC_SUBST([NUMERICFLAGS])
dnl
+dnl Add libm to LDFLAGS so we don't need to add it everywhere manually
+dnl
+LDFLAGS="$LDFLAGS -lm"
+dnl
dnl Exporting used library symbols in the module is a source of issues,
dnl see https://trac.osgeo.org/postgis/ticket/3281
dnl
@@ -1619,6 +1624,7 @@
AC_MSG_RESULT([ C++ compiler (Wagyu): ${WAGYU_CXX} ${CXXFLAGS}])
fi
AC_MSG_RESULT([ CPPFLAGS: $CPPFLAGS])
+AC_MSG_RESULT([ LDFLAGS: $LDFLAGS])
AC_MSG_RESULT([ SQL preprocessor: ${SQLPP}])
AC_MSG_RESULT()
AC_MSG_RESULT([ -------------- Additional Info ------------- ])
Modified: trunk/doc/html/image_src/Makefile.in
--- trunk/doc/html/image_src/Makefile.in 2019-10-23 22:46:02 UTC (rev 17989)
+++ trunk/doc/html/image_src/Makefile.in 2019-10-25 14:17:07 UTC (rev 17990)
@@ -189,7 +189,7 @@
# Build the main executable
generator: ../../../liblwgeom/.libs/liblwgeom.a $(OBJS)
$(LIBTOOL) --mode=link \
- $(CC) -o $@ $(OBJS) ../../../liblwgeom/liblwgeom.la -lm $(CUNIT_LDFLAGS)
+ $(CC) -o $@ $(OBJS) ../../../liblwgeom/liblwgeom.la $(CUNIT_LDFLAGS)
# Build liblwgeom
../../../liblwgeom/.libs/liblwgeom.a:
Modified: trunk/liblwgeom/Makefile.in
--- trunk/liblwgeom/Makefile.in 2019-10-23 22:46:02 UTC (rev 17989)
+++ trunk/liblwgeom/Makefile.in 2019-10-25 14:17:07 UTC (rev 17990)
@@ -25,7 +25,7 @@
CC = @CC@
CPPFLAGS = @CPPFLAGS@
CFLAGS = @WARNFLAGS@ @CFLAGS@ @PICFLAGS@
-LDFLAGS = @LDFLAGS@ @GEOS_LDFLAGS@ @PROJ_LDFLAGS@ @JSON_LDFLAGS@ -lm
+LDFLAGS = @LDFLAGS@ @GEOS_LDFLAGS@ @PROJ_LDFLAGS@ @JSON_LDFLAGS@
NUMERICFLAGS = @NUMERICFLAGS@
top_builddir = @top_builddir@
prefix = @prefix@
Modified: trunk/liblwgeom/cunit/Makefile.in
--- trunk/liblwgeom/cunit/Makefile.in 2019-10-23 22:46:02 UTC (rev 17989)
+++ trunk/liblwgeom/cunit/Makefile.in 2019-10-25 14:17:07 UTC (rev 17990)
@@ -17,7 +17,7 @@
CUNIT_LDFLAGS=@CUNIT_LDFLAGS@
CUNIT_CPPFLAGS=@CUNIT_CPPFLAGS@ -I.. @CPPFLAGS@
CFLAGS=$(CUNIT_CPPFLAGS) @WARNFLAGS@ @CFLAGS@
-LDFLAGS = @GEOS_LDFLAGS@ $(CUNIT_LDFLAGS) -lm
+LDFLAGS = @GEOS_LDFLAGS@ $(CUNIT_LDFLAGS)
ifeq ($(CUNIT_WITH_VALGRIND), YES)
LIBTOOL_VALGRIND := valgrind $(CUNIT_VALGRIND_FLAGS)
Modified: trunk/loader/cunit/Makefile.in
--- trunk/loader/cunit/Makefile.in 2019-10-23 22:46:02 UTC (rev 17989)
+++ trunk/loader/cunit/Makefile.in 2019-10-25 14:17:07 UTC (rev 17990)
@@ -46,7 +46,7 @@
CFLAGS += $(GETTEXT_CFLAGS) $(ICONV_CFLAGS) $(PROJ_CFLAGS)
# Build full linking line
-LDFLAGS = -lm $(GEOS_LDFLAGS) $(GETTEXT_LDFLAGS) $(PGSQL_FE_LDFLAGS) $(ICONV_LDFLAGS) $(CUNIT_LDFLAGS) $(PROJ_LDFLAGS)
+LDFLAGS = $(GEOS_LDFLAGS) $(GETTEXT_LDFLAGS) $(PGSQL_FE_LDFLAGS) $(ICONV_LDFLAGS) $(CUNIT_LDFLAGS) $(PROJ_LDFLAGS)
# Object files
OBJS= \
Modified: trunk/raster/loader/Makefile.in
--- trunk/raster/loader/Makefile.in 2019-10-23 22:46:02 UTC (rev 17989)
+++ trunk/raster/loader/Makefile.in 2019-10-25 14:17:07 UTC (rev 17990)
@@ -73,8 +73,7 @@
$(LIBGDAL_DEPLIBS_LDFLAGS) \
$(GEOS_LDFLAGS) \
$(GETTEXT_LDFLAGS) \
- $(ICONV_LDFLAGS) \
- -lm
+ $(ICONV_LDFLAGS)
all: $(RASTER2PGSQL)
Modified: trunk/raster/test/cunit/Makefile.in
--- trunk/raster/test/cunit/Makefile.in 2019-10-23 22:46:02 UTC (rev 17989)
+++ trunk/raster/test/cunit/Makefile.in 2019-10-25 14:17:07 UTC (rev 17990)
@@ -42,8 +42,7 @@
$(LIBLWGEOM_LDFLAGS) \
$(LIBGDAL_LDFLAGS) \
$(GEOS_LDFLAGS) \
- $(PROJ_LDFLAGS) \
- -lm \
+ $(PROJ_LDFLAGS)
