[postgis-tickets] r17991 - Fix typos in docs
Regina Obe
lr at pcorp.us
Fri Oct 25 04:49:01 PDT 2019
Author: robe
Date: 2019-10-25 16:48:59 -0700 (Fri, 25 Oct 2019)
New Revision: 17991
trunk/doc/reference_lrs.xml
trunk/doc/reference_trajectory.xml
Fix typos in docs
Modified: trunk/doc/reference_lrs.xml
--- trunk/doc/reference_lrs.xml 2019-10-25 14:17:07 UTC (rev 17990)
+++ trunk/doc/reference_lrs.xml 2019-10-25 23:48:59 UTC (rev 17991)
@@ -105,7 +105,7 @@
<refsynopsisdiv>
<funcsynopsis>
<funcprototype>
- <funcdef>geometry <function>ST_LineInterpolatePoint</function></funcdef>
+ <funcdef>geometry <function>ST_3DLineInterpolatePoint</function></funcdef>
<paramdef><type>geometry </type> <parameter>a_linestring</parameter></paramdef>
<paramdef><type>float8 </type> <parameter>a_fraction</parameter></paramdef>
</funcprototype>
@@ -126,7 +126,7 @@
</note>
<para>Availability: 3.0.0</para>
- </refsection>
+ </refsection>
<refsection>
Modified: trunk/doc/reference_trajectory.xml
--- trunk/doc/reference_trajectory.xml 2019-10-25 14:17:07 UTC (rev 17990)
+++ trunk/doc/reference_trajectory.xml 2019-10-25 23:48:59 UTC (rev 17991)
@@ -239,7 +239,7 @@
<refsynopsisdiv>
<funcsynopsis>
<funcprototype>
- <funcdef>float8 <function>ST_CPAWithin</function></funcdef>
+ <funcdef>boolean <function>ST_CPAWithin</function></funcdef>
<paramdef><type>geometry </type> <parameter>track1</parameter></paramdef>
<paramdef><type>geometry </type> <parameter>track2</parameter></paramdef>
<paramdef><type>float8 </type> <parameter>maxdist</parameter></paramdef>
