[postgis-tickets] [SCM] PostGIS; Spatial objects for PostgreSQL. branch master updated. 2cb3e569b35145fe70950b4b56f6ef4ab3f09ed0
git at osgeo.org
git at osgeo.org
Sun Oct 27 12:34:30 PDT 2019
the project "PostGIS; Spatial objects for PostgreSQL.".
via 2cb3e569b35145fe70950b4b56f6ef4ab3f09ed0 (commit)
from 54399b9f6b0f02e8db9444f9f042b8d4ca6d4fa4 (commit)
revisions in full, below.
commit 2cb3e569b35145fe70950b4b56f6ef4ab3f09ed0
Author: Sandro Santilli <strk at kbt.io>
Date: Sun Oct 27 20:34:20 2019 +0100
Change SVN references to GIT
diff --git a/doc/installation.xml b/doc/installation.xml
index 9148a29..fe60ce9 100644
--- a/doc/installation.xml
+++ b/doc/installation.xml
@@ -307,21 +307,21 @@ tar -xvzf postgis-&last_release_version;.tar.gz</programlisting>
<para>
Alternatively, checkout the source from the
- <ulink url="http://subversion.apache.org/">
- svn
+ <ulink url="https://git-scm.com/">
+ git
</ulink>
repository
- <ulink url="https://svn.osgeo.org/postgis/trunk/">
- https://svn.osgeo.org/postgis/trunk/
+ <ulink url="https://git.osgeo.org/gitea/postgis/postgis/">
+ https://git.osgeo.org/gitea/postgis/postgis/
</ulink>
</para>
- <programlisting>svn checkout https://svn.osgeo.org/postgis/trunk/ postgis-&last_release_version;</programlisting>
+ <programlisting>git clone https://git.osgeo.org/gitea/postgis/postgis.git postgis</programlisting>
<para>
Change into the newly created
- <varname>postgis-&last_release_version;</varname> directory to continue
+ <varname>postgis</varname> directory to continue
the installation.
</para>
</sect1>
@@ -2483,33 +2483,33 @@ ALTER EXTENSION postgis_topology UPDATE TO "&last_release_version;next";</progra
<programlisting>ALTER TABLE spatial_ref_sys ADD CONSTRAINT spatial_ref_sys_srid_check check (srid > 0 AND srid < 999000 );</programlisting>
<programlisting>ALTER TABLE spatial_ref_sys ADD PRIMARY KEY(srid));</programlisting>
If you are upgrading an old database containing french <ulink url="https://en.wikipedia.org/wiki/Institut_g%C3%A9ographique_national">
IGN
- </ulink> cartography, you will have probably SRIDs out
+ </ulink> cartography, you will have probably SRIDs out
of range and you will see, when importing your database, issues like this :
<programlisting> WARNING: SRID 310642222 converted to 999175 (in reserved zone)</programlisting>
- In this case, you can try following steps : first throw
- out completely the IGN from the sql which is resulting
+ In this case, you can try following steps : first throw
+ out completely the IGN from the sql which is resulting
from postgis_restore.pl. So, after having run :
<programlisting>perl utils/postgis_restore.pl "/somepath/olddb.backup" > olddb.sql</programlisting>
run this command :
<programlisting>grep -v IGNF olddb.sql > olddb-without-IGN.sql</programlisting>
- Create then your newdb, activate the required Postgis extensions,
+ Create then your newdb, activate the required Postgis extensions,
and insert properly the french system IGN with :
<ulink url="https://raw.githubusercontent.com/Remi-C/IGN_spatial_ref_for_PostGIS/master/Put_IGN_SRS_into_Postgis.sql">
this script
</ulink>
After these operations, import your data :
<programlisting>psql -h localhost -p 5432 -U postgres -d newdb -f olddb-without-IGN.sql 2> errors.txt</programlisting>
</para>
diff --git a/doc/reporting.xml b/doc/reporting.xml
index 9784a2b..ddcc6f6 100644
--- a/doc/reporting.xml
+++ b/doc/reporting.xml
@@ -14,7 +14,7 @@
version()</code> [for postgresql].</para>
<para>If you aren't using the latest release, it's worth taking a look at
- its <ulink url="http://svn.osgeo.org/postgis/trunk/NEWS">release
+ its <ulink url="https://git.osgeo.org/gitea/postgis/postgis/raw/branch/master/NEWS">release
changelog</ulink> first, to find out if your bug has already been
fixed.</para>
@@ -51,20 +51,20 @@
<orderedlist>
<listitem>
- <para>Check out a copy of PostGIS' Subversion trunk. On Unix,
+ <para>Clone the PostGIS' git repository. On Unix,
type:</para>
- <para><command>svn checkout
- http://svn.osgeo.org/postgis/trunk/</command></para>
+ <para><command>git clone
+ https://git.osgeo.org/gitea/postgis/postgis.git</command></para>
- <para>This will be stored in the directory ./trunk</para>
+ <para>This will be stored in the directory postgis</para>
</listitem>
<listitem>
<para>Make your changes to the documentation with your favorite text
editor. On Unix, type (for example):</para>
- <para><command>vim trunk/doc/postgis.xml</command></para>
+ <para><command>vim doc/postgis.xml</command></para>
<para>Note that the documentation is written in DocBook XML rather than HTML,
so if you are not familiar with it please follow the example of the
@@ -75,7 +75,7 @@
<para>Make a patch file containing the differences from the master
copy of the documentation. On Unix, type:</para>
- <para><command>svn diff trunk/doc/postgis.xml >
+ <para><command>git diff doc/postgis.xml >
doc.patch</command></para>
</listitem>
Summary of changes:
doc/installation.xml | 38 +++++++++++++++++++-------------------
doc/reporting.xml | 14 +++++++-------
2 files changed, 26 insertions(+), 26 deletions(-)
hooks/post-receive
