[postgis-tickets] [SCM] PostGIS; Spatial objects for PostgreSQL. branch master updated. 997896338035a0264566dde529ce28b0b69c9f63
git at osgeo.org
git at osgeo.org
Mon Oct 28 03:14:13 PDT 2019
the project "PostGIS; Spatial objects for PostgreSQL.".
via 997896338035a0264566dde529ce28b0b69c9f63 (commit)
from 306a09dbc0251a7acb7bcba261c48891df458fcd (commit)
revisions in full, below.
commit 997896338035a0264566dde529ce28b0b69c9f63
Author: Jorge Gustavo Rocha <jgr at di.uminho.pt>
Date: Mon Oct 28 09:29:42 2019 +0000
Tiny fix to the GUC documentation
diff --git a/doc/reference_guc.xml b/doc/reference_guc.xml
index f27ff53..17009f1 100644
--- a/doc/reference_guc.xml
+++ b/doc/reference_guc.xml
@@ -155,7 +155,7 @@ SET postgis.gdal_datapath = 'C:/Program Files/PostgreSQL/9.3/gdal-data';</progra
<programlisting>ALTER DATABASE mygisdb SET postgis.gdal_enabled_drivers TO 'GTiff PNG JPEG';</programlisting>
<para>Sets default enabled drivers for all new connections to server. Requires super user access and PostgreSQL 9.4+.
- Also not that database, session, and user settings override this.</para>
+ Also note that database, session, and user settings override this.</para>
<programlisting>ALTER SYSTEM SET postgis.gdal_enabled_drivers TO 'GTiff PNG JPEG';
SELECT pg_reload_conf();
</programlisting>
@@ -209,7 +209,7 @@ SET postgis.gdal_enabled_drivers = 'DISABLE_ALL';
<note>
<para>
- Even if <varname>postgis.enable_outdb_rasters</varname> is True, the GUC <varname>postgis.enable_outdb_rasters</varname> determines the accessible raster formats.
+ Even if <varname>postgis.enable_outdb_rasters</varname> is True, the GUC <varname>postgis.gdal_enabled_drivers</varname> determines the accessible raster formats.
</para>
</note>
Summary of changes:
doc/reference_guc.xml | 4 ++--
1 file changed, 2 insertions(+), 2 deletions(-)
hooks/post-receive
