[postgis-tickets] [SCM] PostGIS; Spatial objects for PostgreSQL. branch master updated. 4ae90beb56b677a8497ea2cdc26d1226933c8e4d
git at osgeo.org
git at osgeo.org
Tue Oct 29 01:11:29 PDT 2019
the project "PostGIS; Spatial objects for PostgreSQL.".
via 4ae90beb56b677a8497ea2cdc26d1226933c8e4d (commit)
from 6d0b491212882cbc8bc968b1a0e2bcec9d186ae7 (commit)
revisions in full, below.
commit 4ae90beb56b677a8497ea2cdc26d1226933c8e4d
Author: Sandro Santilli <strk at kbt.io>
Date: Tue Oct 29 09:07:13 2019 +0100
Drop "svn" from revision header and generating script
NOTE: we still have postgis_svn_version() function to deal with
diff --git a/.gitignore b/.gitignore
index 6a4e8d7..5213c3b 100644
--- a/.gitignore
+++ b/.gitignore
@@ -11,7 +11,7 @@
*.gcda
*.gcno
gmon.out
-postgis_svn_revision.h
+postgis_revision.h
aclocal.m4
autom4te.cache/
build-aux/
diff --git a/GNUmakefile.in b/GNUmakefile.in
index 4eb21d4..96d3097 100644
--- a/GNUmakefile.in
+++ b/GNUmakefile.in
@@ -25,7 +25,7 @@ all install uninstall noop clean distclean check-unit check-regress:
echo "PostGIS was built successfully. Ready to install."; \
fi
-all: postgis_svn_revision.h
+all: postgis_revision.h
ifeq (@LIBLWGEOM_ONLY@,no)
install: all comments-install
@@ -175,7 +175,7 @@ authors.git: authors.svn
svnrebase: authors.git
git svn rebase --authors-file authors.git
-postgis_svn_revision.h:
- $(PERL) utils/svn_repo_revision.pl
+postgis_revision.h:
+ $(PERL) utils/repo_revision.pl
-.PHONY: utils liblwgeom ChangeLog raster postgis_svn_revision.h
+.PHONY: utils liblwgeom ChangeLog raster postgis_revision.h
diff --git a/ci/debbie/postgis_release_docs.sh b/ci/debbie/postgis_release_docs.sh
index e0107e1..8398b08 100644
--- a/ci/debbie/postgis_release_docs.sh
+++ b/ci/debbie/postgis_release_docs.sh
@@ -38,12 +38,12 @@ LDFLAGS="-L${PGPATH}/lib" ./configure \
--without-raster --without-wagyu
make clean
-# generating postgis_svn_revision.h in case hasn't been generated
-if test -f utils/svn_repo_revision.pl; then
- echo "Generating postgis_svn_revision.h"
- perl utils/svn_repo_revision.pl
+# generating postgis_revision.h in case hasn't been generated
+if test -f utils/repo_revision.pl; then
+ echo "Generating postgis_revision.h"
+ perl utils/repo_revision.pl
fi
-export VREV="`cat postgis_svn_revision.h | awk '{print $3}'`"
+export VREV="`cat postgis_revision.h | awk '{print $3}'`"
echo "SVN is ${VREV}"
cd doc
diff --git a/liblwgeom/Makefile.in b/liblwgeom/Makefile.in
index b306621..5fe4cb2 100644
--- a/liblwgeom/Makefile.in
+++ b/liblwgeom/Makefile.in
@@ -167,11 +167,11 @@ install:
uninstall:
-# Make all objects depend upon postgis_config.h and postgis_svn_revision.h
-$(LT_OBJS): ../postgis_config.h ../postgis_svn_revision.h $(SA_HEADERS)
+# Make all objects depend upon postgis_config.h and postgis_revision.h
+$(LT_OBJS): ../postgis_config.h ../postgis_revision.h $(SA_HEADERS)
-../postgis_svn_revision.h:
- $(MAKE) -C .. postgis_svn_revision.h
+../postgis_revision.h:
+ $(MAKE) -C .. postgis_revision.h
liblwgeom.la: $(LT_OBJS)
$(LIBTOOL) --tag=CC --mode=link $(CC) -rpath $(libdir) $(LT_OBJS) \
diff --git a/liblwgeom/lwgeom_api.c b/liblwgeom/lwgeom_api.c
index 90e7a99..161060e 100644
--- a/liblwgeom/lwgeom_api.c
+++ b/liblwgeom/lwgeom_api.c
@@ -30,7 +30,7 @@
#include <stdio.h>
#include <assert.h>
-#include "../postgis_svn_revision.h"
+#include "../postgis_revision.h"
const char *
lwgeom_version()
diff --git a/make_dist.sh b/make_dist.sh
index 91f1ccb..d0d62f2 100755
--- a/make_dist.sh
+++ b/make_dist.sh
@@ -92,10 +92,10 @@ owd="$PWD"
cd "$outdir"
./autogen.sh
./configure ${CONFIGURE_ARGS}
-# generating postgis_svn_revision.h for >= 2.0.0 tags
- perl utils/svn_repo_revision.pl $svnurl
+# generating postgis_revision.h for >= 2.0.0 tags
+ perl utils/repo_revision.pl $svnurl
fi
#make
cd "$owd"
@@ -129,7 +129,7 @@ if test "$version" = "dev"; then
VMAJ=`grep ^POSTGIS_MAJOR_VERSION "$outdir"/Version.config | cut -d= -f2`
VMIN=`grep ^POSTGIS_MINOR_VERSION "$outdir"/Version.config | cut -d= -f2`
VMIC=`grep ^POSTGIS_MICRO_VERSION "$outdir"/Version.config | cut -d= -f2`
- VREV=`cat "$outdir"/postgis_svn_revision.h | awk '{print $3}'`
+ VREV=`cat "$outdir"/postgis_revision.h | awk '{print $3}'`
version="${VMAJ}.${VMIN}.${VMIC}-r${VREV}"
#if newoutdir is not already set, then set it
if test "x$newoutdir" = "x"; then
diff --git a/postgis/Makefile.in b/postgis/Makefile.in
index 76a2c01..5293e0c 100644
--- a/postgis/Makefile.in
+++ b/postgis/Makefile.in
@@ -194,12 +194,12 @@ endif
# change is made, a PostGIS rebuild is triggered.
# Also they are all dependent on postgis_config.h
-# and thus postgis_svn_revision.h
+# and thus postgis_revision.h
-$(PG_OBJS): ../liblwgeom/.libs/liblwgeom.a ../libpgcommon/libpgcommon.a ../postgis_config.h ../postgis_svn_revision.h $(WAGYU_DEP)
+$(PG_OBJS): ../liblwgeom/.libs/liblwgeom.a ../libpgcommon/libpgcommon.a ../postgis_config.h ../postgis_revision.h $(WAGYU_DEP)
../liblwgeom/.libs/liblwgeom.a:
$(MAKE) -C ../liblwgeom liblwgeom.la
@@ -256,7 +256,7 @@ sfcgal_upgrade.sql: sfcgal_upgrade.sql.in postgis_after_upgrade.sql
cat $^ > $@
# SQL objects are also dependent on postgis_config.h for PostgreSQL version
-$(SQL_OBJS): ../postgis_config.h ../postgis_svn_revision.h
+$(SQL_OBJS): ../postgis_config.h ../postgis_revision.h
#postgis.sql.in: sqldefines.h long_xact.sql.in.c geography.sql.in.c
diff --git a/postgis/sqldefines.h.in b/postgis/sqldefines.h.in
index 3a474a0..058b2b1 100644
--- a/postgis/sqldefines.h.in
+++ b/postgis/sqldefines.h.in
@@ -1,7 +1,7 @@
#ifndef _LWPGIS_DEFINES
#define _LWPGIS_DEFINES
* Define just the version numbers; otherwise we get some strange substitutions in postgis.sql.in
diff --git a/postgis_config.h.in b/postgis_config.h.in
index abb6f3f..9046281 100644
--- a/postgis_config.h.in
+++ b/postgis_config.h.in
@@ -1,7 +1,7 @@
#ifndef POSTGIS_CONFIG_H
#define POSTGIS_CONFIG_H 1
-#include "postgis_svn_revision.h"
+#include "postgis_revision.h"
/* Manually manipulate the POSTGIS_DEBUG_LEVEL, it is not affected by the
configure process */
diff --git a/raster/rt_pg/Makefile.in b/raster/rt_pg/Makefile.in
index 046fbb5..ef83534 100644
--- a/raster/rt_pg/Makefile.in
+++ b/raster/rt_pg/Makefile.in
@@ -128,10 +128,10 @@ endif
# Objects dependencies
# NOTE: the .a deps are really only link-time dependencies, but at this
# time I dunno how to wncode those
-$(OBJS): ../../liblwgeom/.libs/liblwgeom.a ../rt_core/librtcore.a ../../libpgcommon/libpgcommon.a ../../postgis_config.h ../../postgis_svn_revision.h
+$(OBJS): ../../liblwgeom/.libs/liblwgeom.a ../rt_core/librtcore.a ../../libpgcommon/libpgcommon.a ../../postgis_config.h ../../postgis_revision.h
# SQL objects deps here
-$(SQL_OBJS): ../../postgis/sqldefines.h ../../postgis_svn_revision.h
+$(SQL_OBJS): ../../postgis/sqldefines.h ../../postgis_revision.h
#this is redundant but trying to fold in with the other just hangs
rtpostgis_upgrade.sql.in: rtpostgis.sql ../../utils/postgis_proc_upgrade.pl
diff --git a/topology/Makefile.in b/topology/Makefile.in
index 7660b7a..e86fcf1 100644
--- a/topology/Makefile.in
+++ b/topology/Makefile.in
@@ -130,7 +130,7 @@ topology.sql: \
sql/topogeometry/simplify.sql.in \
sql/predicates.sql.in \
../postgis/sqldefines.h \
- ../postgis_svn_revision.h
+ ../postgis_revision.h
uninstall_topology.sql: topology.sql ../utils/create_undef.pl
$(PERL) ../utils/create_undef.pl $< $(POSTGIS_PGSQL_VERSION) > $@
diff --git a/utils/Makefile.in b/utils/Makefile.in
index 8a7e94e..8b22ff1 100644
--- a/utils/Makefile.in
+++ b/utils/Makefile.in
@@ -32,7 +32,7 @@ SCRIPTS_built = postgis_restore.pl
SCRIPTS = \
create_undef.pl \
- svn_repo_revision.pl \
+ repo_revision.pl \
postgis_proc_upgrade.pl \
profile_intersects.pl \
test_estimation.pl \
diff --git a/utils/svn_repo_revision.pl b/utils/repo_revision.pl
similarity index 98%
rename from utils/svn_repo_revision.pl
rename to utils/repo_revision.pl
index ed20f48..bc092a7 100755
--- a/utils/svn_repo_revision.pl
+++ b/utils/repo_revision.pl
@@ -6,7 +6,7 @@ use warnings;
use strict;
my $top_srcdir = ".";
-my $rev_file = $top_srcdir.'/postgis_svn_revision.h';
+my $rev_file = $top_srcdir.'/postgis_revision.h';
my $target = 'local';
$target = $ARGV[0] if $ARGV[0];
Summary of changes:
.gitignore | 2 +-
GNUmakefile.in | 8 ++++----
ci/debbie/postgis_release_docs.sh | 10 +++++-----
liblwgeom/Makefile.in | 8 ++++----
liblwgeom/lwgeom_api.c | 2 +-
make_dist.sh | 10 +++++-----
postgis/Makefile.in | 10 +++++-----
postgis/sqldefines.h.in | 2 +-
postgis_config.h.in | 2 +-
raster/rt_pg/Makefile.in | 4 ++--
topology/Makefile.in | 2 +-
utils/Makefile.in | 2 +-
utils/{svn_repo_revision.pl => repo_revision.pl} | 2 +-
13 files changed, 32 insertions(+), 32 deletions(-)
rename utils/{svn_repo_revision.pl => repo_revision.pl} (98%)
hooks/post-receive
