[postgis-tickets] [PostGIS] #4559: [raster] PG 13 / GDAL 3.1: rt_gdalwarp regress failing
PostGIS trac at osgeo.org
Tue Oct 29 03:23:55 PDT 2019
  Reporter:  Algunenano  |      Owner:  Bborie Park
      Type:  defect      |     Status:  new
  Priority:  medium      |  Milestone:  PostGIS 3.1.0
 Component:  raster      |    Version:  trunk
Resolution:              |   Keywords:
Comment (by Algunenano):
 > wow we are already testing PostgreSQL 13. This only happens in 13?
 As far as I can see, yes.
 > I'm seeing it on debbie's dev runs for PG 13, this is with
 I was going to say that this might discard GDAL as responsible, but I see
 that Debbie is running 2.4/HEAD so it can either be some change applied in
 GDAL master and backported or a change in PG13.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4559#comment:3>
