[postgis-tickets] [SCM] PostGIS; Spatial objects for PostgreSQL. branch master updated. dee727fc3919a36083ad688280ec99d6cda177d4
Tue Oct 29 08:09:18 PDT 2019
the project "PostGIS; Spatial objects for PostgreSQL.".
       via  dee727fc3919a36083ad688280ec99d6cda177d4 (commit)
      from  3e7036e0ac47834cdac6f02672b3ce4c6967183d (commit)
revisions in full, below.
commit dee727fc3919a36083ad688280ec99d6cda177d4
Author: Sandro Santilli <strk at kbt.io>
Date:   Tue Oct 29 16:08:55 2019 +0100
    Update repo URL in extensions metadata
    [ci skip]
diff --git a/extensions/postgis/META.json b/extensions/postgis/META.json
index 4dfc8b0..f874251 100644
--- a/extensions/postgis/META.json
+++ b/extensions/postgis/META.json
@@ -10,9 +10,9 @@
          "web" : "http://trac.osgeo.org/postgis"
       "repository" : {
-         "type" : "svn",
+         "type" : "git",
          "web" : "http://postgis.net",
-         "url" : "svn://svn.osgeo.org/postgis/"
+         "url" : "https://git.osgeo.org/gitea/postgis/postgis.git"
    "tags" : [
diff --git a/extensions/postgis_tiger_geocoder/META.json b/extensions/postgis_tiger_geocoder/META.json
index f5add01..d60af8f 100644
--- a/extensions/postgis_tiger_geocoder/META.json
+++ b/extensions/postgis_tiger_geocoder/META.json
@@ -1,47 +1,47 @@
-	"name": "postgis_tiger_geocoder",
-	"abstract": "PostGIS Tiger Geocoder",
-	"description": "This module provides loader, geocoder, and reverse geocoder utilizing US Census Tiger data",
-	"version": "2.1.0",
-	"release_status": "unstable",
-	"maintainer": "Leo Hsu and Regina Obe",
-	"license": "gpl_2",
-	"provides": {
-		"postgis_tiger_geocoder": {
-			"abstract": "PostGIS Geocoder functions",
-			"file": "sql/postgis_tiger_geocoder.sql",
-			"docfile": "doc/postgis_tiger_geocoder.md"
-	"prereqs": {
-      "runtime": {
-         "requires": {
-            "plpgsql": 0,
-            "PostgreSQL": "8.4.0",
-            "postgis": "2.0.0", "fuzzystrmatch": 0
-    "generated_by": "Regina O. Obe",
-	"resources": {
-		"bugtracker": {
-			"web": "http://trac.osgeo.org/postgis"
-		"repository": {
-			"url": "svn://svn.osgeo.org/postgis/",
-			"web": "http://postgis.net",
-			"type": "svn"
-	"meta-spec": {
-		"version": "1.0.0",
-		"url": "http://pgxn.org/meta/spec.txt"
-	"tags": [
-		"gis",
-		"spatial",
-		"geometry",
-		"location", "tiger", "geocoder", "reverse geocoder"
+	"name": "postgis_tiger_geocoder",
+	"abstract": "PostGIS Tiger Geocoder",
+	"description": "This module provides loader, geocoder, and reverse geocoder utilizing US Census Tiger data",
+	"version": "2.1.0",
+	"release_status": "unstable",
+	"maintainer": "Leo Hsu and Regina Obe",
+	"license": "gpl_2",
+	"provides": {
+		"postgis_tiger_geocoder": {
+			"abstract": "PostGIS Geocoder functions",
+			"file": "sql/postgis_tiger_geocoder.sql",
+			"docfile": "doc/postgis_tiger_geocoder.md"
+	"prereqs": {
+      "runtime": {
+         "requires": {
+            "plpgsql": 0,
+            "PostgreSQL": "8.4.0",
+            "postgis": "2.0.0", "fuzzystrmatch": 0
+    "generated_by": "Regina O. Obe",
+	"resources": {
+		"bugtracker": {
+			"web": "http://trac.osgeo.org/postgis"
+		"repository": {
+			"url": "https://git.osgeo.org/gitea/postgis/postgis.git",
+			"web": "http://postgis.net",
+			"type": "git"
+	"meta-spec": {
+		"version": "1.0.0",
+		"url": "http://pgxn.org/meta/spec.txt"
+	"tags": [
+		"gis",
+		"spatial",
+		"geometry",
+		"location", "tiger", "geocoder", "reverse geocoder"
diff --git a/extensions/postgis_topology/META.json b/extensions/postgis_topology/META.json
index ea28bd4..89d90ec 100644
--- a/extensions/postgis_topology/META.json
+++ b/extensions/postgis_topology/META.json
@@ -1,47 +1,47 @@
-	"name": "postgis_topology",
-	"abstract": "PostGIS 2.0 Topology OGC/SQL-MM compliant spatial extender for PostgreSQL",
-	"description": "This module provides GIS Topology geometry types and functions",
-	"version": "2.0.0",
-	"maintainer": "PostGIS Steering Committee",
-	"provides": {
-		"postgis_raster": {
-			"abstract": "PostGIS SQL/MM Topology types and functions",
-			"file": "sql/postgis_topology.sql",
-			"docfile": "doc/postgis.md"
-	"prereqs": {
-      "runtime": {
-         "requires": {
-            "plpgsql": 0,
-            "postgis_core": "2.0.0"
-	"resources": {
-		"bugtracker": {
-		"repository": {
-			"type": "svn"
-	"meta-spec": {
-	"tags": [
-		"gis",
-		"spatial",
-		"geometry",
-		"location", "topology", "sql/mm"
+	"name": "postgis_topology",
+	"abstract": "PostGIS 2.0 Topology OGC/SQL-MM compliant spatial extender for PostgreSQL",
+	"description": "This module provides GIS Topology geometry types and functions",
+	"version": "2.0.0",
+	"maintainer": "PostGIS Steering Committee",
+	"provides": {
+		"postgis_raster": {
+			"abstract": "PostGIS SQL/MM Topology types and functions",
+			"file": "sql/postgis_topology.sql",
+			"docfile": "doc/postgis.md"
+	"prereqs": {
+      "runtime": {
+         "requires": {
+            "plpgsql": 0,
+            "postgis_core": "2.0.0"
+	"resources": {
+		"bugtracker": {
+		"repository": {
+			"type": "git"
+	"meta-spec": {
+	"tags": [
+		"gis",
+		"spatial",
+		"geometry",
+		"location", "topology", "sql/mm"
Summary of changes:
 extensions/postgis/META.json                |  4 +-
 extensions/postgis_tiger_geocoder/META.json | 94 ++++++++++++++---------------
 extensions/postgis_topology/META.json       | 94 ++++++++++++++---------------
 3 files changed, 96 insertions(+), 96 deletions(-)
hooks/post-receive
