[postgis-tickets] [SCM] PostGIS; Spatial objects for PostgreSQL. branch master updated. 910d8c93e51ce0d688d255e35a5cf4712b4fd6d7
Wed Oct 30 06:22:40 PDT 2019
the project "PostGIS; Spatial objects for PostgreSQL.".
       via  910d8c93e51ce0d688d255e35a5cf4712b4fd6d7 (commit)
      from  171a8876bc0e2774bc3a76851e9da7fccc5c4822 (commit)
revisions in full, below.
commit 910d8c93e51ce0d688d255e35a5cf4712b4fd6d7
Author: Regina Obe <lr at pcorp.us>
Date:   Wed Oct 30 09:20:36 2019 -0400
    Revert "Revert "Merge branch 'master' of https://git.osgeo.org/gitea/postgis/postgis""
    This reverts commit 171a8876bc0e2774bc3a76851e9da7fccc5c4822.
diff --git a/ci/dronie/postgis_regress.sh b/ci/dronie/postgis_regress.sh
index a5d13c2..ef75397 100644
--- a/ci/dronie/postgis_regress.sh
+++ b/ci/dronie/postgis_regress.sh
@@ -8,7 +8,7 @@ export PGPORT=`grep ^port /etc/postgresql/$PGVER/main/postgresql.conf | awk '{pr
 export PATH=/usr/lib/postgresql/$PGVER/bin:$PATH
 psql --version
 ./autogen.sh
-./configure CFLAGS="-O0 -Wall -fno-omit-frame-pointer -Werror" --without-interrupt-tests
+./configure CFLAGS="-O2 -Wall -fno-omit-frame-pointer -Werror" --without-interrupt-tests
 make clean
 make -j
 # we should maybe wait for postgresql service to startup here...
diff --git a/ci/winnie/package_postgis.sh b/ci/winnie/package_postgis.sh
index 0b31ae6..3113e66 100644
--- a/ci/winnie/package_postgis.sh
+++ b/ci/winnie/package_postgis.sh
@@ -74,7 +74,7 @@ export PATHOLD=$PATH
 WEB=/home/www/postgis/htdocs
 DWN=${WEB}/download
-export PATHOLD="/mingw/bin:/mingw/include:/c/Windows/system32:/c/Windows:.:/bin:/include:/usr/local/bin:/c/ming${OS_BUILD}}${GCC_TYPE}/svn"
+export PATHOLD="/mingw/bin:/mingw/include:/c/Windows/system32:/c/Windows:.:/bin:/include:/usr/local/bin"
 #export PG_VER=9.2beta2
 echo PATH BEFORE: $PATH
@@ -100,13 +100,12 @@ export REL_PGVER=${PG_VER//./} #strip the period
 export RELDIR=${PROJECTS}/postgis/builds/${POSTGIS_MINOR_VER}
 export RELVERDIR=postgis-pg${REL_PGVER}-binaries-${POSTGIS_MICRO_VER}w${OS_BUILD}${GCC_TYPE}
 export PATH="${PATHOLD}:${PGPATH}/bin:${PGPATH}/lib"
-export PCRE_VER=8.33
+export PCRE_VER=8.33
 #PATH="${PGPATH}/bin:${PGPATH}/lib:${PROJECTS}/xsltproc:${PROJECTS}/gtkw${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/gtkw${OS_BUILD}/bin:${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/include:${PROJECTS}/rel-libiconv-1.13.1w${OS_BUILD}${GCC_TYPE}/bin:${PATH}"
 #echo PATH AFTER: $PATH
 outdir="${RELDIR}/${RELVERDIR}"
 package="${RELDIR}/${RELVERDIR}.zip"
 verfile="${RELDIR}/${RELVERDIR}/version.txt"
-#svnurl="http://svn.osgeo.org/postgis/trunk"
 rm -rf $outdir
 rm $package
 mkdir -p $outdir
@@ -206,10 +205,6 @@ cp doc/*_comments.sql ${RELDIR}/${RELVERDIR}/share/contrib/postgis-${POSTGIS_MIN
 cp postgis/*.sql ${RELDIR}/${RELVERDIR}/share/contrib/postgis-${POSTGIS_MINOR_VER}
 cp raster/rt_pg/*.sql ${RELDIR}/${RELVERDIR}/share/contrib/postgis-${POSTGIS_MINOR_VER}
 cp utils/*.pl ${RELDIR}/${RELVERDIR}/utils
-#add extras
-#svn export "${svnurl}/extras" ${RELDIR}/${RELVERDIR}/share/contrib/postgis-${POSTGIS_MINOR_VER}/extras
-#cp raster/rt_pg/rtpostgis.sql ${RELDIR}/${RELVERDIR}/share/contrib/postgis-${POSTGIS_MINOR_VER}
-#cp raster/rt_pg/rtpostgis_upgrade_20_minor.sql ${RELDIR}/${RELVERDIR}/share/contrib/postgis-${POSTGIS_MINOR_VER}
 cp raster/loader/.libs/raster2pgsql.exe ${RELDIR}/${RELVERDIR}/bin
 cp liblwgeom/.libs/*.dll ${RELDIR}/${RELVERDIR}/bin
@@ -254,4 +249,4 @@ cd ${RELDIR}
 zip -r $package ${RELVERDIR}
 #scp $package robe at www.refractions.net:${DWN}/${REL_PGVER}/buildbot/${RELVERDIR}.zip
 cp $package ${PROJECTS}/postgis/win_web/download/windows/pg${REL_PGVER}/buildbot
-cd ${POSTGIS_SRC}
\ No newline at end of file
+cd ${POSTGIS_SRC}
diff --git a/doc/geography.txt b/doc/geography.txt
index 976e6f0..0342683 100644
--- a/doc/geography.txt
+++ b/doc/geography.txt
@@ -1,7 +1,7 @@
 Introduction to the Geography Type
-The geography type provides native support for spatial features represented on "geographic" coordinates (sometimes called "geodetic" coordinates, or "lat/lon", or "lon/lat"). Geographic coordinates are spherical coordinates expressed in angular units (degrees).
+The geography type provides native support for spatial features represented on "geographic" coordinates (sometimes called "geodetic" coordinates, or "lat/lon", or "lon/lat"). Geographic coordinates are spherical coordinates expressed in angular units (degrees).
 The basis for the PostGIS geometry type is a plane. The shortest path between two points on the plane is a straight line. That means calculations on geometries (areas, distances, lengths, intersections, etc) can be calculated using cartesian mathematics and straight line vectors.
@@ -29,7 +29,7 @@ The text representations for geography objects are the same as for geometries:
 * POINT(0 0)
 * LINESTRING(0 0, 1 1)
-* POLYGON((0 0, 1 0, 1 1, 1 0, 0 0))
+* POLYGON((0 0, 1 0, 1 1, 1 0, 0 0))
 * ..etc..
 The coordinates for geography objects are expected to be in decimal degrees, with longitude as the first ordinate and latitude as the second:
@@ -39,34 +39,6 @@ The coordinates for geography objects are expected to be in decimal degrees, wit
 The geography implementation currently assumes that all coordinates are relative to the WGS84 spheroid (using an SRID of 4326), and does not allow any other SRID values to be used. Future enhancements may allow multiple spheroids to be supported and transformations between spheroids. An SRID value of 0 (undefined) will be treated as implicitly using WGS84 (4326).
-Installing the Geography Extension
-* Pull the source from the geography sandbox.
-  svn checkout http://svn.osgeo.org/postgis/spike/pramsey/geodetic postgis-geodetic-svn
-* Compile and install PostGIS as usual.
-  cd postgis-geodetic-svn
-  ./configure
-  make
-  make install
-* Then, create a database and install PostGIS into that database. (Assuming your PostgreSQL is installed in /usr/local/pgsql.)
-  createdb geography
-  psql geography < /usr/local/pgsql/share/contrib/postgis.sql
-  psql geography < /usr/local/pgsql/share/contrib/spatial_ref_sys
-* Then, install the geography extension.
-  psql geography < /usr/local/pgsql/share/contrib/geography.sql
-* That's it!
 Creating a Geography Table
@@ -77,31 +49,31 @@ You can create a geography-enabled table using the CREATE TABLE statement as fol
 Check out the contents of "gtable":
   \d gtable
        Table "public.gtable"
-   Column |   Type    | Modifiers
+   Column |   Type    | Modifiers
    id     | integer   | not null
-   geog   | geography |
+   geog   | geography |
   Indexes:
       "gtable_pkey" PRIMARY KEY, btree (id)
 Now, check the "geography_columns" view and see that your table is listed:
   SELECT * FROM geography_columns;
 Note that "geography_columns" metadata is a view against the system tables and kept up to date automatically. This is a big improvement on the manually maintained "geometry_columns" table.
 Insert some data into the table and then pull it out:
   INSERT INTO gtable1 VALUES (1, 'POINT(0 0)');
   SELECT id,ST_AsText(geog) FROM gtable2;
 Try inserting some invalid geography data and see the database complain:
   INSERT INTO gtable1 values (1, 'POINT(1000 0)');
 Using Type Restrictions
@@ -109,32 +81,32 @@ Using Type Restrictions
 You can restrict the geography types allowed in a column by adding a type restriction when you create the table:
   CREATE TABLE gtable2 ( id integer, geog geography(linestring) );
   \d gtable2
              Table "public.gtable2"
-   id     | integer               |
-   geog   | geography(LineString) |
+   id     | integer               |
+   geog   | geography(LineString) |
 Now, if you try to insert a point, the database will complain:
   INSERT INTO gtable2 VALUES (1, 'POINT(0 0)');
 You can also add SRID restrictions to a column, though at this point (with only one SRID supported) there is not a lot of utility to the feature:
   CREATE TABLE gtable3 ( id integer, geog geography(polygon, 4326) );
   \d gtable3
               Table "public.gtable3"
-   id     | integer                 |
-   geog   | geography(Polygon,4326) |
+   id     | integer                 |
+   geog   | geography(Polygon,4326) |
 Using Input/Output Functions
@@ -150,7 +122,7 @@ There are only four input/output functions at this time supporting the OGC well-
 You can test that they are bi-directional by stringing them together:
   SELECT ST_AsText(ST_GeographyFromBinary(ST_AsBinary(ST_GeographyFromText('LINESTRING(0 0, 1 1)'))));
 Casting from Geometry
@@ -161,5 +133,5 @@ There is currently a simple cast from geometry to geography, which can be useful
   INSERT INTO geomtable VALUES ( 2, 'POINT(0 0)' );
   CREATE TABLE geogtable AS SELECT id, geom::geography AS geog FROM geomtable;
   SELECT ST_AsText(geog), id FROM geogtable;
diff --git a/liblwgeom/cunit/README b/liblwgeom/cunit/README
index 978653c..dc6bbca 100644
--- a/liblwgeom/cunit/README
+++ b/liblwgeom/cunit/README
@@ -80,7 +80,7 @@ Add a new line for your test:
 	PG_ADD_TEST(<your test function name>);
-The tests will be run in the order they appear in the list.
+The tests will be run in the order they appear in the list.
 CU_TEST_INFO_NULL must always be the last entry.
 2.3 Add any necessary init / cleanup code.
@@ -102,8 +102,8 @@ Do the following steps to create a whole new test suite (new .c file).
 3.1 Create the file.
-Create the new file (remember to add to svn as well).  The naming convention
-is cu_<suite name>.c.
+Create the new file (remember to add to repository as well).
+The naming convention is cu_<suite name>.c.
 Make sure to import:
diff --git a/regress/run_test.pl b/regress/run_test.pl
index ccbfea2..5bf3227 100755
--- a/regress/run_test.pl
+++ b/regress/run_test.pl
@@ -416,14 +416,15 @@ if ( $OPT_DUMPRESTORE )
 my $geosver =  sql("select postgis_geos_version()");
 my $projver = sql("select postgis_proj_version()");
-# TODO: call postgis_lib_revision() instead of postgis_svn_version
-#       if $libver >= 3.1.0
-my $librev = sql("select postgis_svn_version()");
 my $libbuilddate = sql("select postgis_lib_build_date()");
 my $pgsqlver = sql("select version()");
 my $gdalver = sql("select postgis_gdal_version()") if $OPT_WITH_RASTER;
 my $sfcgalver = sql("select postgis_sfcgal_version()") if $OPT_WITH_SFCGAL;
 my $scriptver = sql("select postgis_scripts_installed()");
+# postgis_lib_revision was introduced in 3.1.0
+my $librev = semver_lessthan($scriptver, "3.1.0") ?
+							sql("select postgis_svn_version()") :
+							sql("select postgis_lib_revision()");
 my $raster_scriptver = sql("select postgis_raster_scripts_installed()")
   if ( $OPT_WITH_RASTER );
diff --git a/utils/repo_revision.pl b/utils/repo_revision.pl
index cceeb2e..4d4f243 100755
--- a/utils/repo_revision.pl
+++ b/utils/repo_revision.pl
@@ -11,7 +11,7 @@ my $rev_file = $top_srcdir.'/postgis_revision.h';
 my $target = 'local';
 $target = $ARGV[0] if $ARGV[0];
-# Read the svn revision number
+# Read the revision number
 my $rev = &read_rev($target);
 # Write it
@@ -31,7 +31,7 @@ sub read_rev_git {
   # TODO: test on old systems, I think I saw some `which`
   #       implementations returning "nothing found" or something
-  #       like that, making the later if ( ! $svn_exe ) always false
+  #       like that, making the later if ( ! $git_exe ) always false
   my $git_exe = `which git`;
   if ( ! $git_exe ) {
Summary of changes:
 ci/dronie/postgis_regress.sh |  2 +-
 ci/winnie/package_postgis.sh | 11 ++-----
 doc/geography.txt            | 78 ++++++++++++++------------------------------
 liblwgeom/cunit/README       |  6 ++--
 regress/run_test.pl          |  7 ++--
 utils/repo_revision.pl       |  4 +--
 6 files changed, 38 insertions(+), 70 deletions(-)
hooks/post-receive
