[postgis-tickets] [PostGIS] #4568: Oversimplification of polygon inner rings in ST_Simplify
trac at osgeo.org
Thu Oct 31 02:56:13 PDT 2019
Reporter: Algunenano | Owner: pramsey
Type: defect | Status: new
Priority: high | Milestone: PostGIS 3.0.1
Component: postgis | Version: 3.0.x
Keywords: |
Initially reported by Komzpa
I went to far when dropping inner rings of polygons in my optimization of
inner rings, you can only drop all inner rings when the outer ring
collapse, not when any of them collapse.
Bug example:
Select ST_AsText(ST_Simplify('POLYGON((0 0, 100 0, 100 100, 0 100, 0 0),
(20 20, 20 40, 40 40, 40 20, 20 20), (1 1, 1 5, 5 5, 5 1, 1
1))'::geometry, 10));
st_astext
POLYGON((0 0,100 0,100 100,0 100,0 0),(20 20,20 40,40 40,40 20,20 20))
Same polygon but with the smaller inner ring first:
(1 1, 1 5, 5 5, 5 1, 1 1), (20 20, 20 40, 40 40, 40 20, 20
20))'::geometry, 10));
st_astext
POLYGON((0 0,100 0,100 100,0 100,0 0))
(1 row)
PR: https://github.com/postgis/postgis/pull/504
Affected 3.0 and master
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4568>
