[postgis-tickets] [PostGIS] #4568: Oversimplification of polygon inner rings in ST_Simplify
trac at osgeo.org
Thu Oct 31 05:39:06 PDT 2019
Reporter: Algunenano | Owner: Algunenano
Type: defect | Status: closed
Priority: high | Milestone: PostGIS 3.0.1
Component: postgis | Version: 3.0.x
Resolution: fixed | Keywords:
Changes (by Raul Marin <git@…>):
* status: new => closed
* resolution: => fixed
Comment:
In [changeset:"570fbdb10de728e56957f3b7b449ac9532a53a47/git" 570fbdb/git]:
#!CommitTicketReference repository="git"
revision="570fbdb10de728e56957f3b7b449ac9532a53a47"
Fix oversimplification of polygon inner rings
This also adapts a MVT test which is checking whether it crashes with an
input or not. Since the exact output depends on the backend
(GEOS vs wagyu), we just ensure the input passes through the function.
Closes #4568
Closes #4556
Closes https://github.com/postgis/postgis/pull/504
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4568#comment:2>
