[postgis-tickets] [SCM] PostGIS; Spatial objects for PostgreSQL. branch stable-3.0 updated. c4aa7e22e5a50ae1a4d5960e9d1736231f7035d0
git at osgeo.org
git at osgeo.org
Thu Oct 31 06:00:25 PDT 2019
the project "PostGIS; Spatial objects for PostgreSQL.".
The branch, stable-3.0 has been updated
via c4aa7e22e5a50ae1a4d5960e9d1736231f7035d0 (commit)
from 74a8380236a8851ad2d330ad2d96ce1fd5dd460a (commit)
revisions in full, below.
commit c4aa7e22e5a50ae1a4d5960e9d1736231f7035d0
Author: Raul Marin <git at rmr.ninja>
Date: Thu Oct 31 10:48:44 2019 +0100
Fix oversimplification of polygon inner rings
This also adapts a MVT test which is checking whether it crashes with an
input or not. Since the exact output depends on the backend
(GEOS vs wagyu), we just ensure the input passes through the function.
Backports 570fbdb for 3.0
diff --git a/NEWS b/NEWS
index e89de84..6980476 100644
--- a/NEWS
+++ b/NEWS
@@ -1,3 +1,10 @@
+PostGIS 3.0.1
+XXXX/XX/XX
+* Bug Fixes and Enhancements
+ - #4558, Fix oversimplification of polygon inner rings (Raúl Marín)
PostGIS 3.0.0
2019/10/20
This version requires PostgreSQL 9.5+-12 and GEOS >= 3.6+
diff --git a/liblwgeom/cunit/cu_algorithm.c b/liblwgeom/cunit/cu_algorithm.c
index fe50148..a9bb846 100644
--- a/liblwgeom/cunit/cu_algorithm.c
+++ b/liblwgeom/cunit/cu_algorithm.c
@@ -1302,6 +1302,48 @@ static void test_lwgeom_simplify(void)
lwgeom_free(g);
lwgeom_free(l);
lwfree(ewkt);
+ /* POLYGON with multiple inner rings*/
+ g = lwgeom_from_wkt(
+ "POLYGON("
+ "(0 0, 100 0, 100 100, 0 100, 0 0),"
+ "(1 1, 1 5, 5 5, 5 1, 1 1),"
+ "(20 20, 20 40, 40 40, 40 20, 20 20)"
+ LW_PARSER_CHECK_NONE);
+ l = lwgeom_simplify(g, 10, LW_FALSE);
+ ewkt = lwgeom_to_ewkt(l);
+ ASSERT_STRING_EQUAL(ewkt, "POLYGON((0 0,100 0,100 100,0 100,0 0),(20 20,20 40,40 40,40 20,20 20))");
+ lwgeom_free(g);
+ lwgeom_free(l);
+ lwfree(ewkt);
+ /* Reorder inner rings: Same result */
+ "POLYGON("
+ "(20 20, 20 40, 40 40, 40 20, 20 20),"
+ "(1 1, 1 5, 5 5, 5 1, 1 1)"
+ lwgeom_free(g);
+ lwgeom_free(l);
+ lwfree(ewkt);
+ "POLYGON("
+ l = lwgeom_simplify(g, 100, LW_FALSE);
+ CU_ASSERT_EQUAL(l, NULL);
+ lwgeom_free(g);
+ lwgeom_free(l);
diff --git a/liblwgeom/lwgeom.c b/liblwgeom/lwgeom.c
index 854fa20..a9fbfd4 100644
--- a/liblwgeom/lwgeom.c
+++ b/liblwgeom/lwgeom.c
@@ -1782,14 +1782,22 @@ lwgeom_simplify_in_place(LWGEOM *geom, double epsilon, int preserve_collapsed)
/* Drop collapsed rings */
if(pa->npoints < 4)
- /* Any ring deeper than this one is, by OGR definition, smaller
- * so we drop them all */
- for (; i < g->nrings; i++)
+ if (i == 0)
- pa = g->rings[i];
+ /* If the outter ring is dropped, all can be dropped */
+ for (i = 0; i < g->nrings; i++)
+ pa = g->rings[i];
+ ptarray_free(pa);
+ break;
+ else
+ /* Drop this inner ring only */
ptarray_free(pa);
+ continue;
- break;
g->rings[j++] = pa;
diff --git a/regress/core/mvt.sql b/regress/core/mvt.sql
index 491a714..105f584 100644
--- a/regress/core/mvt.sql
+++ b/regress/core/mvt.sql
@@ -577,14 +577,14 @@ SELECT encode(ST_AsMVT(1, 'test', 4096, 'geom'), 'base64');
SELECT 'TU3', encode(ST_AsMVT(q, 'test', 4096, 'geom'), 'base64')
FROM (SELECT NULL::integer AS c1, NULL AS geom) AS q;
--- Ticket #3922
-SELECT '#3922', St_Area(ST_AsMVTGeom(
+-- Ticket #3922 (Check for crash)
+SELECT '#3922', St_GeometryType(ST_AsMVTGeom(
st_geomfromtwkb('\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'),
'SRID=3347;POLYGON((3658201 658873,3658201 5958872.97428571,8958201.49428571 5958872.97428571,8958201.49428571 658873,3658201 658873))'::geometry,
4096,
0,
true
- )) BETWEEN 4.5 AND 6.5;
SELECT '#4294_Horizontal', ST_AsText(ST_AsMVTGeom(
ST_GeomFromText('MULTILINESTRING((0 0, 0 5))'),
diff --git a/regress/core/mvt_expected b/regress/core/mvt_expected
index e88d4b0..bffbca4 100644
--- a/regress/core/mvt_expected
+++ b/regress/core/mvt_expected
@@ -121,7 +121,7 @@ D7|POINT(1 4094)
TU2
ERROR: pgis_asmvt_transfn: parameter row cannot be other than a rowtype
TU3|
-#3922|t
+#3922|ST_Polygon
#4294_Horizontal|LINESTRING(0 10,0 5)
#4294_Vertical|LINESTRING(0 10,5 10)
#4314|
Summary of changes:
NEWS | 7 +++++++
liblwgeom/cunit/cu_algorithm.c | 42 ++++++++++++++++++++++++++++++++++++++++++
liblwgeom/lwgeom.c | 18 +++++++++++++-----
regress/core/mvt.sql | 6 +++---
regress/core/mvt_expected | 2 +-
5 files changed, 66 insertions(+), 9 deletions(-)
hooks/post-receive
