[postgis-tickets] [PostGIS] #4498: PostGIS 2.3 should not allow configure for > PG 9.6
trac at osgeo.org
Mon Sep 2 20:57:03 PDT 2019
Reporter: robe | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.3.11
Component: build/upgrade/install | Version: trunk
Keywords: |
I just put bessie back on the line (newly formatted with FreeBSD 12) which
in the repo is PostgreSQL 11.
The configure for 2.3 seems to go thru but it should error out with an
error that says:
Only supported for PostgreSQL 9.2 - 9.6
From https://git.osgeo.org/gitea/postgis/postgis
23:47:54 * branch svn-2.3 -> FETCH_HEAD
23:47:54 * [new branch] svn-2.3 -> origin/svn-2.3
3:49:12 -------------- Dependencies --------------
23:49:12 GEOS config: /usr/local/bin/geos-config
23:49:12 GEOS version: 3.7.2
23:49:12 GDAL config: /usr/local/bin/gdal-config
23:49:12 GDAL version: 2.4.1
23:49:12 SFCGAL config: /usr/local/bin/sfcgal-config
23:49:12 SFCGAL version: 1.3.6
23:49:12 PostgreSQL config: /usr/local/bin/pg_config
23:49:12 PostgreSQL version: PostgreSQL 11.4
23:49:12 PROJ4 version: 61
23:49:12 Libxml2 config: /usr/local/bin/xml2-config
23:49:12 Libxml2 version: 2.9.9
23:49:12 JSON-C support: no
23:49:12 PCRE support: no
23:49:12 PostGIS debug level: 0
23:49:12 Perl: /usr/local/bin/perl
23:49:12
23:49:12 --------------- Extensions ---------------
23:49:12 PostGIS Raster: enabled
23:49:12 PostGIS Topology: enabled
23:49:12 SFCGAL support: enabled
23:49:12 Address Standardizer support: disabled
23:49:12
but fails in compile:
23:50:25 cc -I../liblwgeom -g -O2 -I/usr/local/include/postgresql/server
-I/usr/local/include -DACCEPT_USE_OF_DEPRECATED_PROJ_API_H=1 -fPIC -DPIC
-Wall -Wmissing-prototypes -c -o lwgeom_transform.o lwgeom_transform.c
23:50:26 lwgeom_transform.c:124:2: warning: incompatible pointer types
initializing 'Size (*)(MemoryContext, void *)' (aka 'unsigned long
(*)(struct MemoryContextData *, void *)') with an expression of type 'void
(MemoryContext)' (aka 'void (struct MemoryContextData *)')
[-Wincompatible-pointer-types]
23:50:26 PROJ4SRSCacheDelete,
23:50:26 ^~~~~~~~~~~~~~~~~~~
23:50:26 lwgeom_transform.c:126:2: warning: incompatible pointer types
initializing 'void (*)(MemoryContext, MemoryStatsPrintFunc, void *,
MemoryContextCounters *)' (aka 'void (*)(struct MemoryContextData *, void
(*)(struct MemoryContextData *, void *, const char *), void *, struct
MemoryContextCounters *)') with an expression of type 'bool
(MemoryContext)' (aka 'bool (struct MemoryContextData *)')
23:50:26 PROJ4SRSCacheIsEmpty,
23:50:26 ^~~~~~~~~~~~~~~~~~~~
23:50:26 lwgeom_transform.c:127:2: warning: excess elements in struct
initializer
23:50:26 PROJ4SRSCacheStats
23:50:26 lwgeom_transform.c:179:9: error: use of undeclared identifier
'FALSE'
23:50:26 return FALSE;
23:50:26 ^
23:50:26 lwgeom_transform.c:575:40: warning: incompatible integer to
pointer conversion passing 'int' to parameter of type 'MemoryContext' (aka
'struct MemoryContextData *') [-Wint-conversion]
23:50:26 PJMemoryContext = MemoryContextCreate(T_AllocSetContext,
8192,
23:50:26 /usr/local/include/postgresql/server/utils/memutils.h:140:47:
note: passing argument to parameter 'node' here
23:50:26 extern void MemoryContextCreate(MemoryContext node,
23:50:26 ^
23:50:26 lwgeom_transform.c:575:18: error: assigning to 'MemoryContext'
(aka 'struct MemoryContextData *') from incompatible type 'void'
8192,
23:50:26 ^
23:50:26 4 warnings and 2 errors generated.
23:50:26 gmake[2]: *** [Makefile:61: lwgeom_transform.o] Error 1
23:50:26 gmake[2]: Leaving directory
'/usr/home/jenkins/workspace/PostGIS_Worker_Run/label/bessie/2e38060fe6f8ca28dd0241ca2655872be37cef25/libpgcommon'
23:50:26 gmake[1]: *** [GNUmakefile:16: all] Error 1
23:50:26 gmake[1]: Leaving directory
'/usr/home/jenkins/workspace/PostGIS_Worker_Run/label/bessie/2e38060fe6f8ca28dd0241ca2655872be37cef25'
23:50:26 *** Error code 2
23:50:26
23:50:26 Stop.
23:50:26 make: stopped in
23:50:26 Build step 'Execute shell' marked build as failure
23:50:26 Finished: FAILURE
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4498>
