[postgis-tickets] [PostGIS] #4499: raster gdalwarp regress failure on FreeBSD 64 /proj 6.1 (bessie)
PostGIS trac at osgeo.org
Mon Sep 2 21:40:37 PDT 2019
 Reporter:  robe     |      Owner:  pramsey
     Type:  defect   |     Status:  new
 Priority:  medium   |  Milestone:  PostGIS 2.4.9
Component:  postgis  |    Version:  2.5.x
 Keywords:           |
 Might be a rounding issue
 23:58:34   GEOS config:          /usr/local/bin/geos-config
 23:58:34   GEOS version:         3.7.2
 23:58:34   GDAL config:          /usr/local/bin/gdal-config
 23:58:34   GDAL version:         2.4.1
 23:58:34   SFCGAL config:        /usr/local/bin/sfcgal-config
 23:58:34   SFCGAL version:       1.3.6
 23:58:34   PostgreSQL config:    /usr/local/bin/pg_config
 23:58:34   PostgreSQL version:   PostgreSQL 11.4
 23:58:34   PROJ4 version:        61
 23:58:34   Libxml2 config:       /usr/local/bin/xml2-config
 23:58:34   Libxml2 version:      2.9.9
 23:58:34   JSON-C support:       no
 23:58:34   protobuf-c support:   yes
 23:58:34   protobuf-c version:   1003002
 23:58:34   PCRE support:         no
 23:58:34   Perl:                 /usr/local/bin/perl
 23:58:34
 23:58:34  --------------- Extensions ---------------
 23:58:34   PostGIS Raster:       enabled
 23:58:34   PostGIS Topology:     enabled
 23:58:34   SFCGAL support:       enabled
 23:58:34   Address Standardizer support:       disabled
 23:58:34
 23:58:34  -------- Documentation Generation --------
 23:58:34   xsltproc:             /usr/local/bin/xsltproc
 23:58:34   xsl style sheets:
 23:58:34   dblatex:
 23:58:34   convert:              /usr/local/bin/convert
 23:58:34   mathml2.dtd:
 http://www.w3.org/Math/DTD/mathml2/mathml2.dtd
 00:17:17  rt_gdalwarp .. failed (diff expected obtained:
 /home/jenkins/tmp/pgis_reg_99dd55c8cbcc1a636d678af1a992499212c6cb92/test_50_diff)
 00:17:18
 00:17:18 --- rt_gdalwarp_expected       2019-09-02 23:56:58.273975000
 +0000
 00:17:18 +++
 /home/jenkins/tmp/pgis_reg_99dd55c8cbcc1a636d678af1a992499212c6cb92/test_50_out
 2019-09-03 00:16:23.140463000 +0000
 00:17:18 @@ -19,8 +19,8 @@
 00:17:18
 0.17|993309|243|243|1|50.000|50.000|0.000|0.000|950760.000|1396957.000|t|t|t
 00:17:18
 0.18|992163|10|10|1|1000.000|-1000.000|3.000|3.000|-500030.000|600000.000|t|t|t
 00:17:18
 0.19|993310|12|12|1|1009.894|-1009.894|3.000|3.000|950691.792|1409281.783|t|t|t
 00:17:18
 -0.2|993309|12|12|1|1009.916|-1009.916|0.000|0.000|950762.305|1409088.896|t|t|t
 00:17:18
 -0.20|993309|12|12|1|1009.916|-1009.916|1.000|3.000|950742.107|1409088.896|t|t|t
 00:17:18
 +0.2|993309|12|12|1|1009.885|-1009.885|0.000|0.000|950809.226|1409091.831|t|t|t
 00:17:18
 +0.20|993309|12|12|1|1009.885|-1009.885|1.000|3.000|950789.029|1409091.831|t|t|t
 00:17:18
 0.21|993310|24|24|1|500.000|500.000|3.000|3.000|950657.188|1397356.783|t|t|t
 00:17:18
 0.22|993310|26|26|1|500.000|500.000|0.000|6.000|950452.000|1396632.000|t|t|t
 00:17:18
 0.23|984269|12|8|1|0.012|-0.012|0.000|0.000|-107.029|50.206|t|t|t
 00:17:18 @@ -63,12 +63,12 @@
 00:17:18
 1.9|992163|11|10|1|1000.000|-1000.000|0.000|0.000|-500001.000|600000.000|t|t|t
 00:17:18
 2.1|993310|12|12|1|1009.894|-1009.894|0.000|0.000|950732.188|1409281.783|t|t|t
 00:17:18
 2.10|993310|24|24|1|500.000|500.000|0.000|0.000|950732.188|1397281.783|t|t|t
 00:17:18
 -2.11|993309|121|121|1|100.000|100.000|0.000|0.000|950762.305|1396988.896|t|t|t
 00:17:18
 +2.11|993309|121|121|1|100.000|100.000|0.000|0.000|950809.226|1396991.831|t|t|t
 00:17:18
 2.12|993310|6|6|1|2000.000|2000.000|0.000|0.000|950732.188|1397281.783|t|t|t
 00:17:18
 2.13|993310|8|8|1|1500.000|1500.000|0.000|0.000|950732.188|1397281.783|t|t|t
 00:17:18
 2.14|993310|24|24|1|500.000|500.000|0.000|0.000|950732.188|1397281.783|t|t|t
 00:17:18
 2.15|993310|16|16|1|750.000|750.000|0.000|0.000|950732.188|1397281.783|t|t|t
 00:17:18
 -2.2|993309|12|12|1|1009.916|-1009.916|0.000|0.000|950762.305|1409088.896|t|t|t
 00:17:18
 +2.2|993309|12|12|1|1009.885|-1009.885|0.000|0.000|950809.226|1409091.831|t|t|t
 00:17:18  2.3|994269|12|8|1|0.012|-0.012|0.000|0.000|-107.029|50.206|t|t|t
 00:17:18  2.4|||||||||||||
 00:17:18
 2.5|993310|12|12|1|1009.894|-1009.894|0.000|0.000|950732.188|1409281.783|t|t|t
 00:17:18
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4499>
