[postgis-tickets] [PostGIS] #4499: raster gdalwarp regress failure on FreeBSD 12 64bit /proj 6.1 (bessie)
PostGIS trac at osgeo.org
Wed Sep 4 14:37:54 PDT 2019
  Reporter:  robe    |      Owner:  Bborie Park
      Type:  defect  |     Status:  new
  Priority:  medium  |  Milestone:  PostGIS 2.4.9
 Component:  raster  |    Version:  2.5.x
Resolution:          |   Keywords:
Comment (by pramsey):
 This is just another reflection of #4500. If you reproject the points
 somewhere slightly different, the grid value you interpolate will also be
 slightly different. I'd copy test info to #4500 and close as a
 duplicate... either we figure out how to get identical behaviour out of
 proj or we switch the tests on proj version.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4499#comment:3>
