[postgis-tickets] r17805 - Make ST_Simplify(TRIANGLE) collapse if requested
Raul raul at rmr.ninja
Thu Sep 5 10:11:29 PDT 2019
Author: algunenano
Date: 2019-09-05 10:11:29 -0700 (Thu, 05 Sep 2019)
New Revision: 17805
   branches/2.5/NEWS
   branches/2.5/liblwgeom/lwgeom.c
   branches/2.5/regress/simplify.sql
   branches/2.5/regress/simplify_expected
Closes #4496
Modified: branches/2.5/NEWS
--- branches/2.5/NEWS	2019-09-05 17:10:57 UTC (rev 17804)
+++ branches/2.5/NEWS	2019-09-05 17:11:29 UTC (rev 17805)
@@ -10,6 +10,7 @@
   - #4494, Fix ST_Simplify output having an outdated bbox (Raúl Marín)
   - #4493, Fix ST_RemoveRepeatedPoints output having an outdated bbox (Raúl Marín)
   - #4495, Fix ST_SnapToGrid output having an outdated bbox (Raúl Marín)
+  - #4496, Make ST_Simplify(TRIANGLE) collapse if requested (Raúl Marín)
 PostGIS 2.5.3
 2019/08/11
Modified: branches/2.5/liblwgeom/lwgeom.c
--- branches/2.5/liblwgeom/lwgeom.c	2019-09-05 17:10:57 UTC (rev 17804)
+++ branches/2.5/liblwgeom/lwgeom.c	2019-09-05 17:11:29 UTC (rev 17805)
@@ -1753,8 +1753,19 @@
 		/* No-op! Cannot simplify points or triangles */
 		case POINTTYPE:
+			return;
 		case TRIANGLETYPE:
-			return;
+			if (preserve_collapsed)
+				return;
+			LWTRIANGLE *t = lwgeom_as_lwtriangle(geom);
+			POINTARRAY *pa = t->points;
+			ptarray_simplify_in_place(pa, epsilon, 0);
+			if (pa->npoints < 3)
+				pa->npoints = 0;
 		case LINETYPE:
 			LWLINE *g = (LWLINE*)(geom);
Modified: branches/2.5/regress/simplify.sql
--- branches/2.5/regress/simplify.sql	2019-09-05 17:10:57 UTC (rev 17804)
+++ branches/2.5/regress/simplify.sql	2019-09-05 17:11:29 UTC (rev 17805)
@@ -21,4 +21,8 @@
     SELECT ST_Simplify('POLYGON((0 0, 10 0, 10 10, 10.6 10, 10.5 10.5, 10 10, 0 10, 0 0))', 1) as g
-Select '15', ST_AsText(g) as geometry, postgis_getbbox(g) AS box from geom;
\ No newline at end of file
+Select '15', ST_AsText(g) as geometry, postgis_getbbox(g) AS box from geom;
+-- Triangle should collapse if requested
+SELECT '16', ST_AsText(ST_Simplify('TRIANGLE ((0 0, 0 9, 9 0, 0 0))', 10, true));
+SELECT '17', ST_AsText(ST_Simplify('TRIANGLE ((0 0, 0 9, 9 0, 0 0))', 10, false));
Modified: branches/2.5/regress/simplify_expected
--- branches/2.5/regress/simplify_expected	2019-09-05 17:10:57 UTC (rev 17804)
+++ branches/2.5/regress/simplify_expected	2019-09-05 17:11:29 UTC (rev 17805)
@@ -13,3 +13,5 @@
 13|
 14|POLYGON((0 0,10 0,10 10,0 0))
 15|POLYGON((0 0,10 0,10.5 10.5,0 10,0 0))|BOX(0 0,10.5 10.5)
+16|TRIANGLE((0 0,0 9,9 0,0 0))
+17|
