[postgis-tickets] [PostGIS] #4501: postgis_tiger_geocoder extension needs super_user=false
trac at osgeo.org
Thu Sep 5 18:12:18 PDT 2019
Reporter: robe | Owner: robe
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 2.5.4
Component: tiger geocoder | Version: 2.5.x
Keywords: |
I had assumed that extensions could be installed by non-superusers if they
are pure sql/plpsql. evidentally in extension control file it also needs
to be marked as such as noted by RhodiumToad on IRC
00:30:15 robe2: RhodiumToad but if postgis_tiger_geocoder is all
plpgsql shouldn't that be allowed?
00:30:59 RhodiumToad: ... is it?
00:32:32 RhodiumToad: the extension control file is responsible
for having superuser=false if the extension is successfully installable by
non-superusers
00:37:23 robe2: yes it's all sql and plpgsql
00:38:24 robe2: it relies on PostGIS but it has no C functions
just uses the postgis geometry type
00:45:56 localhorse: RhodiumToad, robe2: is heroku's whitelist
visible somewhere?
00:56:21 RhodiumToad: robe2: does it have a superuser=false
declaration in the control file?
00:56:30 RhodiumToad: localhorse: presumably in their docs
01:07:45 robe2: no
01:07:50 robe2: should I add one?
01:08:32 RhodiumToad: if all the commands in the extension sql
file can be executed by a non-superuser, even in the upgrade case (i.e. no
hacking on system catalogs allowed), then yes
01:08:45 robe2: okay thanks :)
01:08:46 RhodiumToad: if not then no
01:08:58 RhodiumToad: test it out of course
01:09:19 robe2: yah no crazy hacking of catalog files is done
everything thru just sql or pgsql and no direct update of system catalogs
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4501>
