[postgis-tickets] r17808 - Speed up the calculation of cartesian bbox
Raul
raul at rmr.ninja
Fri Sep 13 08:40:41 PDT 2019
Author: algunenano
Date: 2019-09-13 08:40:41 -0700 (Fri, 13 Sep 2019)
New Revision: 17808
trunk/NEWS
trunk/liblwgeom/gbox.c
trunk/liblwgeom/liblwgeom.h.in
trunk/liblwgeom/lwgeom_api.c
trunk/liblwgeom/lwgeom_geos.c
trunk/liblwgeom/lwinline.h
trunk/liblwgeom/lwout_geojson.c
trunk/liblwgeom/lwout_gml.c
Closes https://github.com/postgis/postgis/pull/475
Closes https://trac.osgeo.org/postgis/ticket/4503
Modified: trunk/NEWS
--- trunk/NEWS 2019-09-12 17:47:47 UTC (rev 17807)
+++ trunk/NEWS 2019-09-13 15:40:41 UTC (rev 17808)
@@ -11,6 +11,7 @@
- #4495, Fix ST_SnapToGrid output having an outdated bbox (Raúl Marín)
- #4496, Make ST_Simplify(TRIANGLE) collapse if requested (Raúl Marín)
- #4501, Allow postgis_tiger_geocoder to be installable by non-super users (Regina Obe)
+ - #4503, Speed up the calculation of cartesian bbox (Raúl Marín)
PostGIS 3.0.0alpha4
2019/08/10
Modified: trunk/liblwgeom/gbox.c
--- trunk/liblwgeom/gbox.c 2019-09-12 17:47:47 UTC (rev 17807)
+++ trunk/liblwgeom/gbox.c 2019-09-13 15:40:41 UTC (rev 17808)
@@ -533,47 +533,115 @@
return rv;
-int ptarray_calculate_gbox_cartesian(const POINTARRAY *pa, GBOX *gbox )
+static void
+ptarray_calculate_gbox_cartesian_2d(const POINTARRAY *pa, GBOX *gbox)
- uint32_t i;
- POINT4D p;
- int has_z, has_m;
+ const POINT2D *p = getPoint2d_cp(pa, 0);
- if ( ! pa ) return LW_FAILURE;
- if ( ! gbox ) return LW_FAILURE;
- if ( pa->npoints < 1 ) return LW_FAILURE;
+ gbox->xmax = gbox->xmin = p->x;
+ gbox->ymax = gbox->ymin = p->y;
- has_z = FLAGS_GET_Z(pa->flags);
- has_m = FLAGS_GET_M(pa->flags);
+ for (uint32_t i = 1; i < pa->npoints; i++)
+ p = getPoint2d_cp(pa, i);
+ gbox->xmin = FP_MIN(gbox->xmin, p->x);
+ gbox->xmax = FP_MAX(gbox->xmax, p->x);
+ gbox->ymin = FP_MIN(gbox->ymin, p->y);
+ gbox->ymax = FP_MAX(gbox->ymax, p->y);
+/* Works with X/Y/Z. Needs to be adjusted after if X/Y/M was required */
+static void
+ptarray_calculate_gbox_cartesian_3d(const POINTARRAY *pa, GBOX *gbox)
+ const POINT3D *p = getPoint3d_cp(pa, 0);
+ gbox->zmax = gbox->zmin = p->z;
+ p = getPoint3d_cp(pa, i);
+ gbox->zmin = FP_MIN(gbox->zmin, p->z);
+ gbox->zmax = FP_MAX(gbox->zmax, p->z);
+static void
+ptarray_calculate_gbox_cartesian_4d(const POINTARRAY *pa, GBOX *gbox)
+ const POINT4D *p = getPoint4d_cp(pa, 0);
+ gbox->mmax = gbox->mmin = p->m;
+ p = getPoint4d_cp(pa, i);
+ gbox->mmin = FP_MIN(gbox->mmin, p->m);
+ gbox->mmax = FP_MAX(gbox->mmax, p->m);
+int
+ptarray_calculate_gbox_cartesian(const POINTARRAY *pa, GBOX *gbox)
+ if (!pa || pa->npoints == 0)
+ return LW_FAILURE;
+ if (!gbox)
+ int has_z = FLAGS_GET_Z(pa->flags);
+ int has_m = FLAGS_GET_M(pa->flags);
gbox->flags = lwflags(has_z, has_m, 0);
LWDEBUGF(4, "ptarray_calculate_gbox Z: %d M: %d", has_z, has_m);
+ int coordinates = 2 + has_z + has_m;
- getPoint4d_p(pa, 0, &p);
- gbox->xmin = gbox->xmax = p.x;
- gbox->ymin = gbox->ymax = p.y;
- if ( has_z )
- gbox->zmin = gbox->zmax = p.z;
- if ( has_m )
- gbox->mmin = gbox->mmax = p.m;
- for ( i = 1 ; i < pa->npoints; i++ )
+ switch (coordinates)
- getPoint4d_p(pa, i, &p);
- gbox->xmin = FP_MIN(gbox->xmin, p.x);
- gbox->xmax = FP_MAX(gbox->xmax, p.x);
- gbox->ymin = FP_MIN(gbox->ymin, p.y);
- gbox->ymax = FP_MAX(gbox->ymax, p.y);
- if ( has_z )
+ case 2:
+ ptarray_calculate_gbox_cartesian_2d(pa, gbox);
+ break;
+ case 3:
+ if (has_z)
- gbox->zmin = FP_MIN(gbox->zmin, p.z);
- gbox->zmax = FP_MAX(gbox->zmax, p.z);
+ ptarray_calculate_gbox_cartesian_3d(pa, gbox);
- if ( has_m )
+ else
- gbox->mmin = FP_MIN(gbox->mmin, p.m);
- gbox->mmax = FP_MAX(gbox->mmax, p.m);
+ double zmin = gbox->zmin;
+ double zmax = gbox->zmax;
+ gbox->mmin = gbox->zmin;
+ gbox->mmax = gbox->zmax;
+ gbox->zmin = zmin;
+ gbox->zmax = zmax;
+ break;
+ default:
+ ptarray_calculate_gbox_cartesian_4d(pa, gbox);
+ break;
return LW_SUCCESS;
Modified: trunk/liblwgeom/liblwgeom.h.in
--- trunk/liblwgeom/liblwgeom.h.in 2019-09-12 17:47:47 UTC (rev 17807)
+++ trunk/liblwgeom/liblwgeom.h.in 2019-09-13 15:40:41 UTC (rev 17808)
@@ -953,22 +953,6 @@
extern int getPoint2d_p(const POINTARRAY *pa, uint32_t n, POINT2D *point);
-* Returns a POINT3DZ pointer into the POINTARRAY serialized_ptlist,
-* suitable for reading from. This is very high performance
-* and declared const because you aren't allowed to muck with the
-* values, only read them.
-extern const POINT3DZ* getPoint3dz_cp(const POINTARRAY *pa, uint32_t n);
-* Returns a POINT4D pointer into the POINTARRAY serialized_ptlist,
-extern const POINT4D* getPoint4d_cp(const POINTARRAY *pa, uint32_t n);
* set point N to the given value
* NOTE that the pointarray can be of any
Modified: trunk/liblwgeom/lwgeom_api.c
--- trunk/liblwgeom/lwgeom_api.c 2019-09-12 17:47:47 UTC (rev 17807)
+++ trunk/liblwgeom/lwgeom_api.c 2019-09-13 15:40:41 UTC (rev 17808)
@@ -362,46 +362,6 @@
return 1;
-const POINT3DZ*
-getPoint3dz_cp(const POINTARRAY *pa, uint32_t n)
- if ( ! pa ) return 0;
- if ( ! FLAGS_GET_Z(pa->flags) )
- lwerror("getPoint3dz_cp: no Z coordinates in point array");
- return 0; /*error */
- if ( n>=pa->npoints )
- lwerror("getPoint3dz_cp: point offset out of range");
- return (const POINT3DZ*)getPoint_internal(pa, n);
-const POINT4D*
-getPoint4d_cp(const POINTARRAY* pa, uint32_t n)
- if (!pa) return 0;
- if (!(FLAGS_GET_Z(pa->flags) && FLAGS_GET_M(pa->flags)))
- lwerror("getPoint4d_cp: no Z and M coordinates in point array");
- if (n >= pa->npoints)
- lwerror("getPoint4d_cp: point offset out of range");
- return (const POINT4D*)getPoint_internal(pa, n);
Modified: trunk/liblwgeom/lwgeom_geos.c
--- trunk/liblwgeom/lwgeom_geos.c 2019-09-12 17:47:47 UTC (rev 17807)
+++ trunk/liblwgeom/lwgeom_geos.c 2019-09-13 15:40:41 UTC (rev 17808)
@@ -243,7 +243,7 @@
uint32_t dims = 2;
uint32_t i;
int append_points = 0;
- const POINT3DZ* p3d = NULL;
+ const POINT3D *p3d = NULL;
const POINT2D* p2d = NULL;
GEOSCoordSeq sq;
@@ -273,7 +273,7 @@
if (dims == 3)
- p3d = getPoint3dz_cp(pa, i);
+ p3d = getPoint3d_cp(pa, i);
p2d = (const POINT2D*)p3d;
LWDEBUGF(4, "Point: %g,%g,%g", p3d->x, p3d->y, p3d->z);
@@ -293,7 +293,7 @@
if (dims == 3)
- p3d = getPoint3dz_cp(pa, 0);
+ p3d = getPoint3d_cp(pa, 0);
else
Modified: trunk/liblwgeom/lwinline.h
--- trunk/liblwgeom/lwinline.h 2019-09-12 17:47:47 UTC (rev 17807)
+++ trunk/liblwgeom/lwinline.h 2019-09-13 15:40:41 UTC (rev 17808)
@@ -90,12 +90,33 @@
static inline const POINT2D *
getPoint2d_cp(const POINTARRAY *pa, uint32_t n)
- if (!pa)
- return 0;
return (const POINT2D *)getPoint_internal(pa, n);
+ * Returns a POINT2D pointer into the POINTARRAY serialized_ptlist,
+ * suitable for reading from. This is very high performance
+ * and declared const because you aren't allowed to muck with the
+ * values, only read them.
+static inline const POINT3D *
+getPoint3d_cp(const POINTARRAY *pa, uint32_t n)
+ return (const POINT3D *)getPoint_internal(pa, n);
+static inline const POINT4D *
+getPoint4d_cp(const POINTARRAY *pa, uint32_t n)
+ return (const POINT4D *)getPoint_internal(pa, n);
static inline LWPOINT *
lwgeom_as_lwpoint(const LWGEOM *lwgeom)
Modified: trunk/liblwgeom/lwout_geojson.c
--- trunk/liblwgeom/lwout_geojson.c 2019-09-12 17:47:47 UTC (rev 17807)
+++ trunk/liblwgeom/lwout_geojson.c 2019-09-13 15:40:41 UTC (rev 17808)
@@ -752,8 +752,7 @@
for (i=0; i<pa->npoints; i++)
- const POINT3DZ *pt;
- pt = getPoint3dz_cp(pa, i);
+ const POINT3D *pt = getPoint3d_cp(pa, i);
lwprint_double(
pt->x, precision, x, OUT_DOUBLE_BUFFER_SIZE);
Modified: trunk/liblwgeom/lwout_gml.c
--- trunk/liblwgeom/lwout_gml.c 2019-09-12 17:47:47 UTC (rev 17807)
+++ trunk/liblwgeom/lwout_gml.c 2019-09-13 15:40:41 UTC (rev 17808)
@@ -689,8 +689,7 @@
lwprint_double(
lwprint_double(
@@ -1919,8 +1918,7 @@
lwprint_double(
