[postgis-tickets] r17819 - Travis: Fix clang ubsan build
Raul raul at rmr.ninja
Tue Sep 24 03:44:10 PDT 2019
Author: algunenano
Date: 2019-09-24 03:44:10 -0700 (Tue, 24 Sep 2019)
New Revision: 17819
   trunk/ci/travis/run_usan_clang.sh
The latest build updated clang
Modified: trunk/ci/travis/run_usan_clang.sh
--- trunk/ci/travis/run_usan_clang.sh	2019-09-23 09:20:32 UTC (rev 17818)
+++ trunk/ci/travis/run_usan_clang.sh	2019-09-24 10:44:10 UTC (rev 17819)
@@ -10,7 +10,7 @@
 export MSAN_OPTIONS=halt_on_error=false,leak_check_at_exit=false,exitcode=0
 #Run postgres preloading sanitizer libs
-LD_PRELOAD=/usr/lib/clang/7/lib/linux/libclang_rt.asan-x86_64.so /usr/local/pgsql/bin/pg_ctl -c -l /tmp/logfile start
+LD_PRELOAD=/usr/lib/clang/8/lib/linux/libclang_rt.asan-x86_64.so /usr/local/pgsql/bin/pg_ctl -c -l /tmp/logfile start
 # Build with Clang and usan flags
