[postgis-tickets] [PostGIS] #4514: GEOS master breaks topology tests
PostGIS trac at osgeo.org
Fri Sep 27 16:59:31 PDT 2019
  Reporter:  Algunenano  |      Owner:  pramsey
      Type:  defect      |     Status:  new
  Priority:  medium      |  Milestone:  PostGIS GEOS
 Component:  postgis     |    Version:  trunk
Resolution:              |   Keywords:
Comment (by robe):
 In [changeset:"17823" 17823]:
 #!CommitTicketReference repository="" revision="17823"
 Revise topology tests so they yield same results in GEOS 3.8 and lower
 References #4514 for PostGIS 3.0
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4514#comment:3>
