[postgis-tickets] [PostGIS] #4500: ReprojectPts regression on FreeBSD 12 / Proj 6.1.0
trac at osgeo.org
Sat Sep 28 03:47:58 PDT 2019
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 3.0.0
Component: postgis | Version: 2.5.x
Resolution: | Keywords:
Comment (by robe):
Just a side note, this is not an issue on her 2.5 run.
See 2.5 run:
00:07:24 PostgreSQL 11.4 on amd64-portbld-freebsd12.0, compiled by FreeBSD
clang version 6.0.1 (tags/RELEASE_601/final 335540) (based on LLVM 6.0.1),
64-bit
00:07:24 Postgis 2.5.4dev - r17826 - 2019-09-27 23:32:22
00:07:24 scripts 2.5.4dev r17826
00:07:24 GEOS: 3.7.2-CAPI-1.11.2 b55d2125
00:07:24 PROJ: Rel. 6.1.0, May 15th, 2019
00:07:24 SFCGAL: 1.3.6
00:07:24
00:07:24 Running tests
00:07:24
00:07:24 loader/Point .............. ok
00:07:28 loader/PointM .............. ok
00:07:31 loader/PointZ .............. ok
00:07:40 loader/MultiPoint .............. ok
00:07:43 loader/MultiPointM .............. ok
00:07:50 loader/MultiPointZ .............. ok
00:07:53 loader/Arc .............. ok
00:07:58 loader/ArcM .............. ok
00:08:01 loader/ArcZ .............. ok
00:08:04 loader/Polygon .............. ok
00:08:08 loader/PolygonM .............. ok
00:08:11 loader/PolygonZ .............. ok
00:08:15 loader/TSTPolygon ......... ok
00:08:16 loader/TSIPolygon ......... ok
00:08:18 loader/TSTIPolygon ......... ok
00:08:20 loader/PointWithSchema ..... ok
00:08:21 loader/NoTransPoint ......... ok
00:08:23 loader/NotReallyMultiPoint ......... ok
00:08:25 loader/MultiToSinglePoint ......... ok
00:08:28 loader/ReprojectPts ........ ok
00:08:30 loader/ReprojectPtsGeog ........ ok
00:08:32 loader/Latin1 .... ok
00:08:32 loader/Latin1-implicit .... ok
00:08:33 loader/mfile .... ok
00:08:33 dumper/literalsrid ....... ok
00:08:34 dumper/realtable ....... ok
00:08:36 affine .. ok
00:08:37 bestsrid .. ok
00:08:37 binary .. ok
00:08:38 boundary .. ok
00:08:38 chaikin .. ok
00:08:38 filterm .. ok
00:08:39 cluster .. ok
00:08:39 concave_hull .. ok
00:08:41 concave_hull_hard .. ok
00:13:26 ctors .. ok
00:13:27 curvetoline .. ok
00:13:27 dump .. ok
00:13:27 dumppoints .. ok
00:13:27 empty .. ok
00:13:27 estimatedextent .. ok
00:13:27 forcecurve .. ok
00:13:28 geography .. ok
00:13:28 geometric_median .. ok
00:13:28 in_geohash .. ok
00:13:28 in_gml .. ok
00:13:29 in_kml .. ok
00:13:29 in_encodedpolyline .. ok
00:13:29 iscollection .. ok
00:13:29 legacy .. ok
00:13:36 long_xact .. ok
00:13:36 lwgeom_regress .. ok
00:13:36 measures .. ok
00:13:36 minimum_bounding_circle .. ok
00:13:36 normalize .. ok
00:13:37 operators .. ok
00:13:37 orientation .. ok
00:13:37 out_geometry .. ok
00:13:37 out_geography .. ok
00:13:37 polygonize .. ok
00:13:37 polyhedralsurface .. ok
00:13:38 postgis_type_name .. ok
00:13:38 quantize_coordinates .. ok
00:13:38 regress .. ok
00:13:39 regress_bdpoly .. ok
00:13:39 regress_gist_index_nd .. ok
00:13:46 regress_index .. ok
00:13:54 regress_index_nulls .. ok
00:13:55 regress_management .. ok
00:13:55 regress_selectivity .. ok
00:13:55 regress_lrs .. ok
00:13:56 regress_ogc .. ok
00:13:56 regress_ogc_cover .. ok
00:13:56 regress_ogc_prep .. ok
00:13:56 regress_proj .. ok
00:13:56 relate .. ok
00:13:57 remove_repeated_points .. ok
00:13:57 removepoint .. ok
00:13:58 reverse .. ok
00:13:58 setpoint .. ok
00:13:58 simplify .. ok
00:13:58 simplifyvw .. ok
00:13:59 size .. ok
00:13:59 snaptogrid .. ok
00:13:59 split .. ok
00:13:59 sql-mm-serialize .. ok
00:14:01 sql-mm-circularstring .. ok
00:14:04 sql-mm-compoundcurve .. ok
00:14:09 sql-mm-curvepoly .. ok
00:14:09 sql-mm-general .. ok
00:14:09 sql-mm-multicurve .. ok
00:14:09 sql-mm-multisurface .. ok
00:14:10 swapordinates .. ok
00:14:10 summary .. ok
00:14:10 temporal .. ok
00:14:11 tickets .. ok
00:14:16 twkb .. ok
00:14:17 typmod .. ok
00:15:06 wkb .. ok
00:15:06 wkt .. ok
00:15:06 wmsservers .. ok
00:15:10 knn_recheck .. ok
00:15:22 temporal_knn .. ok
00:15:22 hausdorff .. ok
00:15:22 regress_buffer_params .. ok
00:15:22 frechet .. ok
00:15:22 offsetcurve .. ok
00:15:23 relatematch .. ok
00:15:23 isvaliddetail .. ok
00:15:23 sharedpaths .. ok
00:15:23 snap .. ok
00:15:23 node .. ok
00:15:23 unaryunion .. ok
00:15:24 clean .. ok
00:15:25 relate_bnr .. ok
00:15:26 delaunaytriangles .. ok
00:15:28 clipbybox2d .. ok
00:15:29 subdivide .. ok
00:17:38 voronoi .. ok
00:17:38 minimum_clearance .. ok
00:17:38 oriented_envelope .. ok
00:17:38 regress_brin_index .. ok
00:17:42 regress_brin_index_3d .. ok
00:17:44 regress_brin_index_geography .. ok
00:17:44 regress_spgist_index_2d .. ok
00:17:47 regress_spgist_index_3d .. ok
00:17:51 mvt .. ok
00:18:16 mvt_jsonb .. ok
00:18:16 regress_sfcgal .. ok
00:18:16 sfcgal/empty .. ok
00:18:16 sfcgal/geography .. ok
00:18:18 sfcgal/legacy .. ok
00:18:19 sfcgal/measures .. ok
00:18:19 sfcgal/regress_ogc_prep .. ok
00:18:19 sfcgal/regress_ogc .. ok
00:18:19 sfcgal/regress .. ok
00:18:19 sfcgal/tickets .. ok
00:18:20 sfcgal/concave_hull .. ok
00:18:27 sfcgal/wmsservers .. ok
00:18:36 sfcgal/approximatemedialaxis .. ok
00:18:36 uninstall .
/usr/home/jenkins/workspace/PostGIS_Worker_Run/label/bessie/f9cb01927fcc766886b938a5ab079811bf453a07/regress/00
-regress-install/share/contrib/postgis/uninstall_sfcgal.sql
00:18:36
-regress-install/share/contrib/postgis/uninstall_postgis.sql
00:18:37 . ok (4745)
00:18:38
00:18:38 Run tests: 141
00:18:38 Failed: 0
00:18:38 gmake[2]: Leaving directory
'/usr/home/jenkins/workspace/PostGIS_Worker_Run/label/bessie/f9cb01927fcc766886b938a5ab079811bf453a07/regress'
00:18:38 ---- Making check in raster
00:18:38 gmake[2]: Entering directory
'/usr/home/jenkins/workspace/PostGIS_Worker_Run/label/bessie/f9cb01927fcc766886b938a5ab079811bf453a07/raster'
00:18:38 /usr/local/bin/gmake -C test check
00:18:38 gmake[3]: Entering directory
'/usr/home/jenkins/workspace/PostGIS_Worker_Run/label/bessie/f9cb01927fcc766886b938a5ab079811bf453a07/raster/test'
00:18:38 /usr/local/bin/gmake -C cunit check
00:18:38 gmake[4]: Entering directory
'/usr/home/jenkins/workspace/PostGIS_Worker_Run/label/bessie/f9cb01927fcc766886b938a5ab079811bf453a07/raster/test/cunit'
00:18:38
Did we change 3.0 that much?
but that's the last run. Anyway I'll go ahead and upgrade her proj
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4500#comment:6>
