[postgis-tickets] [PostGIS] #4515: 00-regress-install doesn't get created
trac at osgeo.org
Sat Sep 28 04:08:05 PDT 2019
Reporter: robe | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.0.0
Component: build/upgrade/install | Version: 2.5.x
Keywords: |
I think this might be just an issue local to me as winnie doesn't seem to
be having this issue and we should be configured the same way. Though I
might override variables a little differently since my pathing is
different
Issue is regress/00-regress-install folder doesn't get created anymore so
I can only do make check with extensions.
Even with that I get legacy regress failure:
+psql:legacy.sql:11: error: \cd: could not change directory to
"C:/ming64gcc81/projects/postgis/branches/3.0/regress/00-regress-
install/share/contrib/postgis": No such file or directory
because it tries to cd into the non-existing folder
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4515>
