[postgis-tickets] r17827 - Update docs in prep for 3.0.0beta1 release
Regina Obe
lr at pcorp.us
Sat Sep 28 06:09:55 PDT 2019
Author: robe
Date: 2019-09-28 06:09:55 -0700 (Sat, 28 Sep 2019)
New Revision: 17827
trunk/NEWS
trunk/README.postgis
trunk/doc/release_notes.xml
Modified: trunk/NEWS
--- trunk/NEWS 2019-09-28 02:56:49 UTC (rev 17826)
+++ trunk/NEWS 2019-09-28 13:09:55 UTC (rev 17827)
@@ -1,5 +1,5 @@
PostGIS 3.0.0beta1
-2019/09/XX
+2019/09/28
For full changes and enhancements, refer to PostGIS 3.0.0.
This version requires PostgreSQL 9.5+-12 and GEOS >= 3.6+
Additional features enabled if you are running Proj6+ and PostgreSQL 12
@@ -12,7 +12,7 @@
- #4496, Make ST_Simplify(TRIANGLE) collapse if requested (Raúl Marín)
- #4501, Allow postgis_tiger_geocoder to be installable by non-super users (Regina Obe)
- #4503, Speed up the calculation of cartesian bbox (Raúl Marín)
- - #4504, shp2pgsql -D not working with schema qualified tables
+ - #4504, shp2pgsql -D not working with schema qualified tables (Regina Obe)
- #4505, Speed up conversion of geometries to/from GEOS (Dan Baston)
- #4507, Use GEOSMakeValid and GEOSBuildArea for GEOS 3.8+ (Dan Baston)
- #4491, Speed up ST_RemoveRepeatedPoints (Raúl Marín)
Modified: trunk/README.postgis
--- trunk/README.postgis 2019-09-28 02:56:49 UTC (rev 17826)
+++ trunk/README.postgis 2019-09-28 13:09:55 UTC (rev 17827)
@@ -1,8 +1,8 @@
PostGIS - Geographic Information Systems Extensions to PostgreSQL
-:Version: 3.0.0alpah2
-:Date: 2019-06-02
+:Version: 3.0.0beta1
+:Date: 2019-09-28
:Website: https://postgis.net
This distribution contains a module which implements GIS simple features, ties
Modified: trunk/doc/release_notes.xml
--- trunk/doc/release_notes.xml 2019-09-28 02:56:49 UTC (rev 17826)
+++ trunk/doc/release_notes.xml 2019-09-28 13:09:55 UTC (rev 17827)
@@ -3,6 +3,31 @@
<title>Appendix</title>
<subtitle>Release Notes</subtitle>
<sect1>
+ <title>Release 3.0.0beta1</title>
+ <para>Release date: 2019/09/28</para>
+ <para>If compiling with PostgreSQL+JIT, LLVM >= 6 is required</para>
+ <para>Supported PostgreSQL versions for this release are:
+ PostgreSQL 9.5 - PostgreSQL 12
+ GEOS >= 3.6. Additional features enabled if you running Proj6+ and/or PostgreSQL 12</para>
+ <simplesect>
+ <title>Major highlights</title>
+ <para>4492, Fix ST_Simplify ignoring the value of the 3rd parameter (Raúl Marín)</para>
+ <para>4494, Fix ST_Simplify output having an outdated bbox (Raúl Marín)</para>
+ <para>4493, Fix ST_RemoveRepeatedPoints output having an outdated bbox (Raúl Marín)</para>
+ <para>4495, Fix ST_SnapToGrid output having an outdated bbox (Raúl Marín)</para>
+ <para>4496, Make ST_Simplify(TRIANGLE) collapse if requested (Raúl Marín)</para>
+ <para>4501, Allow postgis_tiger_geocoder to be installable by non-super users (Regina Obe)</para>
+ <para>4503, Speed up the calculation of cartesian bbox (Raúl Marín)</para>
+ <para>4504, shp2pgsql -D not working with schema qualified tables (Regina Obe)</para>
+ <para>4505, Speed up conversion of geometries to/from GEOS (Dan Baston)</para>
+ <para>4507, Use GEOSMakeValid and GEOSBuildArea for GEOS 3.8+ (Dan Baston)</para>
+ <para>4491, Speed up ST_RemoveRepeatedPoints (Raúl Marín)</para>
+ <para>4509, Update geocoder for tiger 2019 (Regina Obe)</para>
+ <para>4338, Census block level data (tabblock table) not loading (Regina Obe)</para>
+ </simplesect>
+ </sect1>
+ <sect1>
<title>Release 3.0.0alpha4</title>
<para>Release date: 2019/08/11</para>
