[postgis-tickets] [PostGIS] #4474: bessie32 failing
PostGIS trac at osgeo.org
Sat Sep 28 15:37:47 PDT 2019
  Reporter:  robe       |      Owner:  robe
      Type:  defect     |     Status:  new
  Priority:  blocker    |  Milestone:  Management 2.0
 Component:  buildbots  |    Version:  2.5.x
Resolution:             |   Keywords:
Comment (by robe):
 In [changeset:"17829" 17829]:
 #!CommitTicketReference repository="" revision="17829"
 Turn off wagyu for now for 32-bit FreeBSD12.  For some reason it is
 deciding to use a higher gcc for wagyu building which causes the issue
 References #4474
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4474#comment:14>
