[postgis-tickets] r17830 - Prepare for PostGIS 3.0.0beta1
Regina Obe
lr at pcorp.us
Sat Sep 28 04:28:14 PDT 2019
Author: robe
Date: 2019-09-28 16:28:14 -0700 (Sat, 28 Sep 2019)
New Revision: 17830
trunk/ChangeLog
trunk/Version.config
trunk/extensions/upgradeable_versions.mk
Modified: trunk/ChangeLog
--- trunk/ChangeLog 2019-09-28 22:37:46 UTC (rev 17829)
+++ trunk/ChangeLog 2019-09-28 23:28:14 UTC (rev 17830)
@@ -1,3 +1,1582 @@
+2019-09-25 10:31 Raúl Marín Rodríguez <rmrodriguez at carto.com>
+ * [r17822] extensions/upgrade-paths-rules.mk:
+ upgrade-paths-rules.mk: Drop the -v flag
+ It's not available in some UNIX systems as it's not POSIX
+ standard
+2019-09-24 10:58 Raúl Marín Rodríguez <rmrodriguez at carto.com>
+ * [r17821] NEWS, liblwgeom/cunit/cu_misc.c,
+ liblwgeom/liblwgeom.h.in, liblwgeom/liblwgeom_internal.h,
+ liblwgeom/lwgeom.c, liblwgeom/lwgeom_geos_split.c,
+ liblwgeom/measures.c, liblwgeom/ptarray.c,
+ postgis/lwgeom_functions_analytic.c: Speed up ST_Simplify
+ Closes #4510
+ Closes https://github.com/postgis/postgis/pull/480
+2019-09-24 10:45 Raúl Marín Rodríguez <rmrodriguez at carto.com>
+ * [r17820] liblwgeom/lwgeom.c: ST_RemoveRepeatedPoints: Optimize
+ multipoints with single point
+ References #4491
+ Closes https://github.com/postgis/postgis/pull/481
+2019-09-24 10:44 Raúl Marín Rodríguez <rmrodriguez at carto.com>
+ * [r17819] ci/travis/run_usan_clang.sh: Travis: Fix clang ubsan
+ build
+ The latest build updated clang
+2019-09-23 09:20 Raúl Marín Rodríguez <rmrodriguez at carto.com>
+ * [r17818] doc/extras_topology.xml,
+ doc/po/templates/extras_topology.xml.pot: Fix several
+ documentation typos
+ Patch by François Bonzon
+ Closes https://github.com/postgis/postgis/pull/479/
+2019-09-17 20:00 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r17817] postgis/lwgeom_functions_analytic.c: Remove tolerance in
+ point-in-ring stabline tests
+ Closes #4506
+2019-09-17 14:36 Raúl Marín Rodríguez <rmrodriguez at carto.com>
+ * [r17813] raster/test/cunit/cu_raster_misc.c: Disable raster
+ failing tests
+ References #4379
+2019-09-16 12:32 Raúl Marín Rodríguez <rmrodriguez at carto.com>
+ * [r17812] NEWS, liblwgeom/cunit/cu_algorithm.c,
+ liblwgeom/liblwgeom.h.in, liblwgeom/lwgeom.c,
+ liblwgeom/ptarray.c, postgis/lwgeom_functions_basic.c: Speed up
+ ST_RemoveRepeatedPoints
+ Closes #4491
+ Closes https://github.com/postgis/postgis/pull/468
+2019-09-14 19:09 Daniel Baston <dbaston at gmail.com>
+ * [r17811] NEWS, fuzzers/geos_stub.h, liblwgeom/lwgeom_geos.c:
+ Speed up conversion of geometries to/from GEOS
+ GEOS 3.8 introduces multi-ordinate getters and setters that can
+ read and write
+ XY/XYZ in a single function call.
+ Fixes #4505
+ Closes https://github.com/postgis/postgis/pull/476
+2019-09-14 19:04 Daniel Baston <dbaston at gmail.com>
+ * [r17810] NEWS, liblwgeom/lwgeom_geos.c, liblwgeom/lwgeom_geos.h,
+ liblwgeom/lwgeom_geos_clean.c, postgis/mvt.c: Use GEOSMakeValid
+ and GEOSBuildArea for GEOS 3.8+
+ Fixes #4507
+ Closes https://github.com/postgis/postgis/pull/477
+2019-09-13 21:14 Regina Obe <lr at pcorp.us>
+ * [r17809] NEWS, loader/shp2pgsql-core.c: shp2pgsql -D not working
+ with schema qualified tables
+ Closes #4504
+2019-09-13 15:40 Raúl Marín Rodríguez <rmrodriguez at carto.com>
+ * [r17808] NEWS, liblwgeom/gbox.c, liblwgeom/liblwgeom.h.in,
+ liblwgeom/lwgeom_api.c, liblwgeom/lwgeom_geos.c,
+ liblwgeom/lwinline.h, liblwgeom/lwout_geojson.c,
+ liblwgeom/lwout_gml.c: Speed up the calculation of cartesian bbox
+ Closes https://github.com/postgis/postgis/pull/475
+ Closes https://trac.osgeo.org/postgis/ticket/4503
+2019-09-12 17:47 Daniel Baston <dbaston at gmail.com>
+ * [r17807] regress/core/oriented_envelope.sql: Reduce sensitivity
+ of ST_OrientedEnvelope test
+ GEOS master produces slightly different coordinate values, at
+ least for now.
+2019-09-07 18:43 Regina Obe <lr at pcorp.us>
+ * [r17806] NEWS,
+ extensions/postgis_tiger_geocoder/postgis_tiger_geocoder.control.in:
+ Mark tiger geocoder as superuser safe since it only has
+ plpgsql/sql and no c lib
+ References #4501 for PostGIS 3.0
+2019-09-05 17:10 Raúl Marín Rodríguez <rmrodriguez at carto.com>
+ * [r17804] NEWS, liblwgeom/lwgeom.c, regress/core/simplify.sql,
+ regress/core/simplify_expected: Make ST_Simplify(TRIANGLE)
+ collapse if requested
+ References #4496
+ Closes https://github.com/postgis/postgis/pull/474
+2019-09-05 15:27 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r17803] postgis/gserialized_estimate.c: Muck with stats message
+2019-09-02 11:55 Raúl Marín Rodríguez <rmrodriguez at carto.com>
+ * [r17798] NEWS, postgis/lwgeom_functions_analytic.c,
+ regress/core/chaikin.sql, regress/core/chaikin_expected,
+ regress/core/simplifyvw.sql, regress/core/simplifyvw_expected,
+ regress/core/snaptogrid.sql, regress/core/snaptogrid_expected:
+ Fix ST_SnapToGrid output having an outdated bbox
+ References #4495
+ Closes https://github.com/postgis/postgis/pull/473
+2019-08-30 14:58 Raúl Marín Rodríguez <rmrodriguez at carto.com>
+ * [r17797] postgis/postgis_before_upgrade.sql:
+ _postgis_drop_function_if_needed: Update ST_GeoJSON args
+ Related to #4483
+2019-08-30 13:31 Raúl Marín Rodríguez <rmrodriguez at carto.com>
+ * [r17793] NEWS, postgis/lwgeom_functions_basic.c,
+ regress/core/remove_repeated_points.sql,
+ regress/core/remove_repeated_points_expected: Fix
+ ST_RemoveRepeatedPoints output having an outdated bbox
+ References #4493
+ Closes https://github.com/postgis/postgis/pull/472
+2019-08-29 15:17 Raúl Marín Rodríguez <rmrodriguez at carto.com>
+ * [r17786] NEWS, postgis/lwgeom_functions_analytic.c,
+ regress/core/simplify.sql, regress/core/simplify_expected: Fix
+ ST_Simplify output having an outdated bbox
+ References #4494
+2019-08-29 11:51 Raúl Marín Rodríguez <rmrodriguez at carto.com>
+ * [r17782] NEWS, postgis/lwgeom_functions_analytic.c,
+ ST_Simplify ignoring the value of the 3rd parameter
+ References #4492
+ Closes https://github.com/postgis/postgis/pull/469
+2019-08-29 08:59 Sandro Santilli <strk at kbt.io>
+ * [r17781] postgis/gserialized_estimate.c: Be less assertive in
+ debug message printed when missing table stats
+ ... running ANALYZE won't always fix the missing stats
+2019-08-28 14:37 Sandro Santilli <strk at kbt.io>
+ * [r17780] NEWS: Expand info about polygon orientation functions in
+ 2.4 section
+2019-08-28 14:25 Sandro Santilli <strk at kbt.io>
+ * [r17779] doc/reference_accessor.xml, doc/reference_editor.xml:
+ Add availability info for orientation checking and forcing
+ functions
+ These are:
+ ST_IsPolygonCW
+ ST_IsPolygonCCW
+ ST_ForcePolygonCW
+ ST_ForcePolygonCCW
+2019-08-26 15:10 Raúl Marín Rodríguez <rmrodriguez at carto.com>
+ * [r17778] configure.ac: Configure: Fix --with-wagyu flag
+2019-08-26 11:44 Sandro Santilli <strk at kbt.io>
+ * [r17777] doc/extras_topology.xml: Link AddTopoGeometryColumn to
+ DropTopoGeometryColumn
+2019-08-23 15:58 Sandro Santilli <strk at kbt.io>
+ * [r17774] .drone-1.0.yml, ci/dronie, ci/dronie/postgis_regress.sh:
+ [drone] Reorganize configuration to use external script
+ Also add installcheck step
+2019-08-23 09:56 Darafei Praliaskouski <me at komzpa.net>
+ * [r17773] NEWS, liblwgeom/measures.c, liblwgeom/measures.h,
+ regress/core/measures.sql, regress/core/measures_expected:
+ Support 2D TINs in ST_3DIntersection
+ Brings TIN into dist2d calculation. Removes homebrew atan2.
+ Closes #4328
+ Closes https://github.com/postgis/postgis/pull/461
+2019-08-23 06:37 Sandro Santilli <strk at kbt.io>
+ * [r17772] ci/travis/run_coverage.sh, ci/travis/run_nowagyu.sh,
+ ci/travis/run_tests.sh, ci/travis/run_usan_clang.sh,
+ ci/travis/run_usan_gcc.sh: [travis] Revert travis recipes
+ modifications
+ This reverts commit dd601071c093c2233f3eeeba12af41373075bae8.
+ This reverts commit e8b5c3993e288e00a840b7a41f643901a280f5a9.
+ * [r17771] GNUmakefile.in: Reorder Makefile dependencies to avoid
+ duplicated build
+ Mark most check targets as dependent on "all" rule
+2019-08-22 18:56 Sandro Santilli <strk at kbt.io>
+ * [r17770] ci/travis/run_nowagyu.sh, ci/travis/run_tests.sh,
+ ci/travis/run_usan_clang.sh, ci/travis/run_usan_gcc.sh: [travis]
+ More "make" before "make check"
+2019-08-22 18:27 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r17768] postgis/Makefile.in: Move geobuf testing solely into
+ configure
+2019-08-22 18:07 Sandro Santilli <strk at kbt.io>
+ * [r17766] ci/travis/run_coverage.sh: [travis] don't assume "make
+ check" will work parallel w/out "make"
+2019-08-22 18:00 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r17765] topology/Makefile.in: Remove apparently unhelpful
+ dependency lines
+2019-08-22 17:33 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r17764] topology/Makefile.in: And return to original form
+2019-08-22 17:32 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r17763] topology/Makefile.in: Just note needed libraries, don't
+ be clever
+2019-08-22 17:23 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r17762] topology/Makefile.in: Be explicit about how to build
+ liblwgeom and libpgcommon libs
+2019-08-22 16:33 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r17761] configure.ac, postgis/Makefile.in,
+ regress/core/Makefile.in: Move geobuf version test into one place
+ and strip expr calls from makefiles
+2019-08-22 15:59 Sandro Santilli <strk at kbt.io>
+ * [r17760] postgis/Makefile.in, regress/core/Makefile.in: Quote
+ expr arguments, consistently use variables
+2019-08-22 14:59 Sandro Santilli <strk at kbt.io>
+ * [r17759] utils/create_unpackaged.pl: Add support for extension
+ sequences in create_unpackaged.pl
+ Should fix topology dump-restore
+ References #4488
+2019-08-22 13:36 Sandro Santilli <strk at kbt.io>
+ * [r17758] GNUmakefile.in, deps/Makefile.in, doc/Makefile.in,
+ extensions/Makefile.in, liblwgeom/Makefile.in,
+ libpgcommon/Makefile.in, loader/Makefile.in, postgis/Makefile.in,
+ raster/Makefile.in, raster/test/Makefile.in, regress/Makefile.in,
+ topology/Makefile.in, topology/test/Makefile.in,
+ utils/Makefile.in: Split "check" into "check-regress" and
+ "check-unit"
+ Makes "installcheck" only run "check-regress"
+ Closes #4487
+2019-08-22 12:13 Sandro Santilli <strk at kbt.io>
+ * [r17757] postgis/postgis.sql.in: Have postgis_extensions_upgrade
+ repackage topology as well
+ Closes #4486
+ References #2503
+ See failure here:
+ https://gitlab.com/postgis/postgis/-/jobs/277847404
+2019-08-22 11:44 Sandro Santilli <strk at kbt.io>
+ * [r17756] .gitlab-ci.yml: [gitlab-ci] Use env variable rather than
+ make parameter, for RUNTESTFLAGS
+ I suspect gitlab-ci provided make is not compatible with
+ parameter
+2019-08-22 09:21 Sandro Santilli <strk at kbt.io>
+ * [r17755] HOWTO_RELEASE: [HOWTO_RELEASE] Add note that bots need
+ to be all green for release
+2019-08-22 09:20 Sandro Santilli <strk at kbt.io>
+ * [r17754] utils/check_all_upgrades.sh: check-all-upgrades: stop
+ checking upgrades from latest unpackaged
+ ... as this is already done by 'make installcheck'
+ * [r17753] GNUmakefile.in: Have 'installcheck' also check with
+ upgrade-from-function
+ Closes #4485
+ Adds an installcheck-upgrade-byfunc target,
+ dependency of installcheck-upgrade
+ * [r17752] regress/run_test.pl: [run_test] Allow requesting
+ function upgrade also w/out :auto
+ Append an exlamation mark to any target version in upgrade-path
+ to request upgrade via function...
+2019-08-22 06:47 Sandro Santilli <strk at kbt.io>
+ * [r17751] utils/check_all_upgrades.sh: [check-all-upgrades] Fix
+ retrival of :auto version
+2019-08-21 08:57 Sandro Santilli <strk at kbt.io>
+ * [r17750] regress/run_test.pl: [run_test] Fix logic for use
+ postgis_extension_upgrade()
+ The version before 3.0.0 did not repackage extensions, so we
+ still
+ need to do the packaging ourselves.
+ * [r17749] NEWS: Document that postgis_extensions_upgrade
+ re-pakcages from 3.0.0
+2019-08-21 07:28 Sandro Santilli <strk at kbt.io>
+ * [r17748] regress/run_test.pl: [run_test.pl] Allow using
+ postgis_extensions_upgrade from unpackaged
+ And warn when it cannot be used due to too old source version.
+2019-08-20 22:02 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r17747] liblwgeom/gbox.c, liblwgeom/lwgeom.c: Remove 32-bit
+ build warnings
+2019-08-20 19:29 Sandro Santilli <strk at kbt.io>
+ * [r17745] regress/run_test.pl: run_test.pl: always repackage
+ raster when upgrading via function
+ This is because the upgrade function invoked may be coming from
+ the
+ a pre-split version and thus not know anything about repackaging.
+ See #4485
+2019-08-20 18:33 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r17744] liblwgeom/lwgeom.c: Replace aliasing with memcpy
+ References #4319
+ * [r17743] liblwgeom/lwgeom_geos.c,
+ liblwgeom/lwgeom_geos_cluster.c, postgis/gserialized_gist_nd.c:
+ Quiet warnings from centos 6 build
+2019-08-20 16:01 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r17740] loader/pgsql2shp-core.c, loader/pgsql2shp-core.h,
+ raster/rt_core/rt_serialize.c: Change run-time endianness checks
+ to compile-time
+ Leave 3rd party code unchanged
+ Closes #4439
+2019-08-20 15:17 Sandro Santilli <strk at kbt.io>
+ * [r17739] utils/check_all_upgrades.sh: [check_all_upgrades]
+ support :auto and :auto! upgrade targets
+ See #4485
+ * [r17738] regress/run_test.pl: Add support for :auto and :auto!
+ upgrade-path targets in run_test.pl
+ The former will request upgrading to default version, the latter
+ to do so using the postgis_extension_upgrade() function.
+ See #4485
+2019-08-20 14:03 Sandro Santilli <strk at kbt.io>
+ * [r17737] doc/reference_version.xml: Update
+ postgis_extensions_upgrade docs to reflect new return value
+2019-08-20 11:38 Sandro Santilli <strk at kbt.io>
+ * [r17736] regress/core/regress.sql: Add test for
+ postgis_full_version()
+ Closes #4485
+ NOTE: the test is only included in the core tests, might need to
+ be replicated for sfcgal/topology/raster
+2019-08-20 11:37 Sandro Santilli <strk at kbt.io>
+ * [r17735] regress/run_test.pl: Simplify perl code
+2019-08-20 11:06 Darafei Praliaskouski <me at komzpa.net>
+ * [r17734] fuzzers/geojson_import_fuzzer_seed_corpus.zip: oss-fuzz:
+ add geojson seed corpus.
+ Closes
+ https://bugs.chromium.org/p/oss-fuzz/issues/detail?id=16564
+2019-08-20 09:24 Sandro Santilli <strk at kbt.io>
+ * [r17733] regress/run_test.pl: Fix perl syntax
+ Can't "last" outside a loop block ...
+2019-08-20 09:03 Sandro Santilli <strk at kbt.io>
+ * [r17732] utils/check_all_upgrades.sh: [check_all_upgrades] Test
+ upgrades from old versions unpackaged
+ See #4485
+ * [r17731] regress/run_test.pl: [run_test] Add support for
+ upgrading from unpackaged<version>
+ See #4485
+2019-08-19 20:19 Sandro Santilli <strk at kbt.io>
+ * [r17730] postgis/postgis.sql.in: Fix typo
+2019-08-19 16:14 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r17729] configure.ac: Change 'protobuf version' to protobuf-c to
+ be more explicit
+2019-08-18 12:55 Darafei Praliaskouski <me at komzpa.net>
+ * [r17728] doc/reference_relationship.xml: [doc] geometry polygon
+ ST_Intersects example
+ Closes #4248
+2019-08-18 12:18 Darafei Praliaskouski <me at komzpa.net>
+ * [r17727] NEWS, postgis/lwgeom_sfcgal.c, postgis/sfcgal.sql.in,
+ regress/sfcgal/regress_sfcgal.sql,
+ regress/sfcgal/regress_sfcgal_expected: postgis_sfcgal_noop().
+ Patch by Lucas C. Villa Real <lucasvr at br.ibm.com>, tweaks by
+ Darafei Praliaskouski
+ Closes #3979
+2019-08-18 11:27 Darafei Praliaskouski <me at komzpa.net>
+ * [r17726] NEWS, fuzzers/build_google_oss_fuzzers.sh,
+ fuzzers/geojson_import_fuzzer.cpp,
+ fuzzers/geojson_import_fuzzer.dict,
+ fuzzers/geojson_import_fuzzer.options, fuzzers/geos_stub.h,
+ fuzzers/proj_stub.h, fuzzers/wkb_import_fuzzer.cpp,
+ fuzzers/wkt_import_fuzzer.cpp, liblwgeom/lwcollection.c,
+ liblwgeom/lwgeom.c, liblwgeom/lwin_geojson.c, liblwgeom/lwline.c,
+ liblwgeom/lwmline.c, liblwgeom/ptarray.c: OSS Fuzz for geojson.
+ Enable allocation testing for other fuzzers.
+ Closes #4387
+ Closes https://github.com/postgis/postgis/pull/462
+2019-08-16 21:26 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r17725] postgis/postgis_before_upgrade.sql: Try and harmonize
+ function parameter names for ST_AsGEoJSON(record)
+ References #4483
+2019-08-15 19:43 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r17719] raster/test/regress/bug_test_car5.sql,
+ raster/test/regress/bug_test_car5_expected: Remove SRID error
+ lines because that's a silly thing to test
+2019-08-15 17:00 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r17716] liblwgeom/gserialized1.c, liblwgeom/gserialized2.c:
+ Guard against reading into pointarrays when size of array == 0
+2019-08-14 22:29 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r17715] macros/ac_protobufc_version.m4: Add missing macro file
+2019-08-14 22:07 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r17711] configure.ac, postgis/Makefile.in,
+ postgis/postgis_libprotobuf.c, postgis_config.h.in,
+ regress/core/Makefile.in, regress/core/geobuf.sql,
+ regress/core/geobuf_expected, regress/core/mvt.sql,
+ regress/core/mvt_expected: Reorganize protobuf detection so that
+ separate directories can be specified, and make version detection
+ more robust over different protobuf installs.
+ References #4481
+2019-08-14 11:06 Sandro Santilli <strk at kbt.io>
+ * [r17710] utils/check_all_upgrades.sh: [check-all-upgrades] Fix
+ handling of bogus commandline
+ * [r17709] postgis/Makefile.in: Fix syntax error in expr line
+ Closes #4477
+2019-08-13 20:54 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r17708] doc/reference_output.xml: Update ST_AsGeoJSON doco to
+ harmonize number of digits default
+2019-08-13 18:00 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r17707] postgis/geography.sql.in, postgis/postgis.sql.in: Lower
+ default precision produced by ST_AsGeoJSON
+ References #4468
+2019-08-13 16:59 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r17706] liblwgeom/cunit/cu_geodetic.c, liblwgeom/gbox.c,
+ liblwgeom/liblwgeom.h.in, liblwgeom/lwgeodetic.c,
+ liblwgeom/lwgeodetic.h, liblwgeom/lwgeodetic_tree.c,
+ liblwgeom/lwgeodetic_tree.h,
+ postgis/geography_measurement_trees.c: Geography Distance
+ inconsistent with Intersects
+ Closes #4480
+2019-08-11 06:24 Regina Obe <lr at pcorp.us>
+ * [r17703] Version.config, extensions/upgradeable_versions.mk: flip
+ to 3.0.0alpha5dev
+2019-08-11 06:15 Regina Obe <lr at pcorp.us>
+ * [r17701] Version.config, doc/release_notes.xml: Prep for
+ 3.0.0alpha4 release
+2019-08-11 02:36 Regina Obe <lr at pcorp.us>
+ * [r17687] NEWS, doc/release_notes.xml,
+ extensions/address_standardizer/Makefile.in: Add upgrade install
+ paths for address_standardizer
+ Closese #4420 for PostGIS 3.0 (trunk)
+2019-08-09 23:51 Regina Obe <lr at pcorp.us>
+ * [r17684] NEWS, doc/release_notes.xml,
+ extensions/upgradeable_versions.mk: Prepping for release tomorrow
+2019-08-09 22:52 Regina Obe <lr at pcorp.us>
+ * [r17683] ci/bessie32/postgis_regress.sh: Put libiconv back
+ evidentally still need that one
+ References #4474
+2019-08-09 22:50 Regina Obe <lr at pcorp.us>
+ * [r17682] NEWS, regress/core/mvt.sql, regress/core/mvt_expected,
+ regress/core/tickets.sql, regress/core/tickets_expected: Move
+ protobuf specific ticket lines to mvt test
+ Closes #4472
+2019-08-09 22:44 Regina Obe <lr at pcorp.us>
+ * [r17681] ci/bessie32/postgis_regress.sh: Try to fix bessie32
+ Undefined symbol
+ "_ZNKSt8__detail20_Prime_rehash_policy11_M_next_bktEj" by getting
+ rid of redundant configure lines that should be pulled in via
+ pkg-config
+ References #4474 for PostGIS 3.0
+2019-08-09 22:21 Regina Obe <lr at pcorp.us>
+ * [r17680] ci/berrie/postgis_regress.sh: Try to get berrie to
+ return fail code if regress fails - try 2
+2019-08-09 21:55 Regina Obe <lr at pcorp.us>
+ * [r17679] ci/berrie/postgis_regress.sh: Try to get berrie to
+2019-08-06 19:15 Darafei Praliaskouski <me at komzpa.net>
+ * [r17678] NEWS, doc/reference_input.xml, doc/reference_output.xml,
+ extras/ogc_test_suite/3_cleanup.sql, liblwgeom/liblwgeom.h.in,
+ postgis/lwgeom_export.c, postgis/lwgeom_in_geojson.c,
+ postgis/postgis.sql.in, postgis/postgis_after_upgrade.sql,
+ raster/test/regress/loader/Projected-post.sql,
+ raster/test/regress/loader/Projected-pre.sql,
+ regress/core/geography.sql, regress/core/in_geojson.sql,
+ regress/core/in_geojson_expected, regress/core/in_gml.sql,
+ regress/core/in_kml.sql, regress/core/knn_recheck.sql,
+ regress/core/legacy.sql, regress/core/out_geography.sql,
+ regress/core/out_geography_expected,
+ regress/core/out_geometry.sql,
+ regress/core/out_geometry_expected,
+ regress/core/regress_management.sql,
+ regress/core/regress_proj.sql, regress/core/tickets.sql,
+ regress/loader/ReprojectPts-post.sql,
+ regress/loader/ReprojectPts-pre.sql,
+ regress/loader/ReprojectPtsD-post.sql,
+ regress/loader/ReprojectPtsD-pre.sql,
+ regress/loader/ReprojectPtsGeog-post.sql,
+ regress/loader/ReprojectPtsGeog-pre.sql,
+ regress/loader/ReprojectPtsGeogD-post.sql,
+ regress/loader/ReprojectPtsGeogD-pre.sql, regress/run_test.pl,
+ topology/test/regress/copytopology.sql,
+ topology/test/regress/gml.sql,
+ topology/test/regress/st_createtopogeo.sql,
+ topology/test/regress/st_modedgesplit.sql,
+ topology/test/regress/st_newedgessplit.sql,
+ topology/test/regress/st_remedgemodface.sql,
+ topology/test/regress/st_remedgenewface.sql,
+ topology/test/regress/topogeo_addlinestring.sql: Improve GeoJSON
+ SRID handling.
+ If SRID is not specified, set it to 4326 by default on parsing,
+ following RFC7946.
+ If SRID is not 4326 on serialization, it will be marked in JSON
+ unless disabled, making round trips almost lossless.
+ Fixes spatial_ref_sys truncation in all the tests.
+ Closes #4377
+ Closes https://github.com/postgis/postgis/pull/455
+2019-08-06 15:59 Raúl Marín Rodríguez <rmrodriguez at carto.com>
+ * [r17677] NEWS, liblwgeom/lwstroke.c: lwarc_linearize: Iterate
+ over the number of segments
+ Closes https://github.com/postgis/postgis/pull/458
+ Closes #4407
+ References #3719
+2019-08-04 12:01 Darafei Praliaskouski <me at komzpa.net>
+ * [r17676] doc/reference_processing.xml, doc/reference_sfcgal.xml:
+ Link ST_Tesselate to ST_(Constrained)DelaunayTriangles
+ Closes #4458
+2019-08-04 11:52 Darafei Praliaskouski <me at komzpa.net>
+ * [r17675] doc/reference_processing.xml: [doc] Note about
+ mulitlinestring in ST_OffsetCurve
+ Closes #2553
+2019-08-04 11:43 Darafei Praliaskouski <me at komzpa.net>
+ * [r17674] NEWS, liblwgeom/lwgeom_median.c, liblwgeom/lwin_twkb.c,
+ liblwgeom/lwin_wkb.c, liblwgeom/lwiterator.c, liblwgeom/lwmval.c,
+ liblwgeom/lwout_geojson.c, liblwgeom/lwout_kml.c,
+ liblwgeom/lwout_twkb.c, liblwgeom/lwout_wkb.c,
+ liblwgeom/lwstroke.c, liblwgeom/measures.c,
+ liblwgeom/measures3d.c, postgis/geobuf.c,
+ postgis/lwgeom_out_geobuf.c, postgis/lwgeom_transform.c,
+ postgis/mvt.c, regress/core/geometric_median_expected,
+ regress/core/regress_proj_expected, regress/core/tickets.sql,
+ regress/core/tickets_expected: Triangle and TIN output support
+ Make all the "Unsupported geometry type" name themselves by
+ __func__.
+ In case output format doesn't know about TIN/Triangle, output
+ them as GeometryCollection/Polygon.
+ Closes #4399
+ Closes https://github.com/postgis/postgis/pull/454
+2019-08-04 11:37 Darafei Praliaskouski <me at komzpa.net>
+ * [r17673] NEWS, liblwgeom/gserialized.c, liblwgeom/gserialized.h,
+ liblwgeom/liblwgeom.h.in, liblwgeom/lwutil.c,
+ libpgcommon/lwgeom_pg.h, postgis/geography_measurement.c,
+ postgis/lwgeom_box.c, postgis/lwgeom_box3d.c,
+ postgis/lwgeom_functions_analytic.c,
+ postgis/lwgeom_functions_basic.c, postgis/lwgeom_functions_lrs.c,
+ postgis/lwgeom_geos.c, postgis/lwgeom_spheroid.c,
+ regress/core/ctors_expected, regress/core/split_expected: Better
+ error messages for SRID mismatch.
+ Closes #4110
+2019-08-04 07:45 Darafei Praliaskouski <me at komzpa.net>
+ * [r17672] NEWS, liblwgeom/lwin_geojson.c,
+ regress/core/in_geojson.sql, regress/core/in_geojson_expected:
+ ST_GeomFromGeoJSON crash on empty rings
+ Closes #4470
+ Closes https://github.com/postgis/postgis/pull/453
+2019-08-04 07:08 Darafei Praliaskouski <me at komzpa.net>
+ * [r17667] NEWS, liblwgeom/lwgeom.c: ST_Subdivide crash on
+ intermediate EMPTY fix.
+ Closes #4459
+ Closes https://github.com/postgis/postgis/pull/456
+2019-08-03 21:48 Darafei Praliaskouski <me at komzpa.net>
+ * [r17666] doc/po/de/extras.xml.po,
+ doc/po/de/extras_address_standardizer.xml.po,
+ doc/po/de/extras_historytable.xml.po,
+ doc/po/de/extras_tigergeocoder.xml.po,
+ doc/po/de/extras_topology.xml.po, doc/po/de/faq.xml.po,
+ doc/po/de/faq_raster.xml.po, doc/po/de/installation.xml.po,
+ doc/po/de/introduction.xml.po, doc/po/de/performance_tips.xml.po,
+ doc/po/de/postgis.xml.po, doc/po/de/reference.xml.po,
+ doc/po/de/reference_accessor.xml.po,
+ doc/po/de/reference_bbox.xml.po,
+ doc/po/de/reference_cluster.xml.po,
+ doc/po/de/reference_constructor.xml.po,
+ doc/po/de/reference_editor.xml.po,
+ doc/po/de/reference_exception.xml.po,
+ doc/po/de/reference_guc.xml.po, doc/po/de/reference_input.xml.po,
+ doc/po/de/reference_lrs.xml.po,
+ doc/po/de/reference_management.xml.po,
+ doc/po/de/reference_measure.xml.po,
+ doc/po/de/reference_misc.xml.po,
+ doc/po/de/reference_operator.xml.po,
+ doc/po/de/reference_output.xml.po,
+ doc/po/de/reference_processing.xml.po,
+ doc/po/de/reference_raster.xml.po,
+ doc/po/de/reference_relationship.xml.po,
+ doc/po/de/reference_sfcgal.xml.po,
+ doc/po/de/reference_srs.xml.po,
+ doc/po/de/reference_temporal.xml.po,
+ doc/po/de/reference_trajectory.xml.po,
+ doc/po/de/reference_transaction.xml.po,
+ doc/po/de/reference_transformation.xml.po,
+ doc/po/de/reference_troubleshooting.xml.po,
+ doc/po/de/reference_type.xml.po,
+ doc/po/de/reference_validation.xml.po,
+ doc/po/de/reference_version.xml.po,
+ doc/po/de/release_notes.xml.po, doc/po/de/reporting.xml.po,
+ doc/po/de/using_postgis_app.xml.po,
+ doc/po/de/using_postgis_dataman.xml.po,
+ doc/po/de/using_raster_dataman.xml.po, doc/po/es/extras.xml.po,
+ doc/po/es/extras_address_standardizer.xml.po,
+ doc/po/es/extras_historytable.xml.po,
+ doc/po/es/extras_tigergeocoder.xml.po,
+ doc/po/es/extras_topology.xml.po, doc/po/es/faq.xml.po,
+ doc/po/es/faq_raster.xml.po, doc/po/es/installation.xml.po,
+ doc/po/es/introduction.xml.po, doc/po/es/performance_tips.xml.po,
+ doc/po/es/postgis.xml.po, doc/po/es/reference.xml.po,
+ doc/po/es/reference_accessor.xml.po,
+ doc/po/es/reference_bbox.xml.po,
+ doc/po/es/reference_cluster.xml.po,
+ doc/po/es/reference_constructor.xml.po,
+ doc/po/es/reference_editor.xml.po,
+ doc/po/es/reference_guc.xml.po, doc/po/es/reference_input.xml.po,
+ doc/po/es/reference_lrs.xml.po,
+ doc/po/es/reference_management.xml.po,
+ doc/po/es/reference_measure.xml.po,
+ doc/po/es/reference_operator.xml.po,
+ doc/po/es/reference_output.xml.po,
+ doc/po/es/reference_processing.xml.po,
+ doc/po/es/reference_raster.xml.po,
+ doc/po/es/reference_relationship.xml.po,
+ doc/po/es/reference_sfcgal.xml.po,
+ doc/po/es/reference_srs.xml.po,
+ doc/po/es/reference_trajectory.xml.po,
+ doc/po/es/reference_transaction.xml.po,
+ doc/po/es/reference_transformation.xml.po,
+ doc/po/es/reference_troubleshooting.xml.po,
+ doc/po/es/reference_type.xml.po,
+ doc/po/es/reference_validation.xml.po,
+ doc/po/es/reference_version.xml.po,
+ doc/po/es/release_notes.xml.po, doc/po/es/reporting.xml.po,
+ doc/po/es/using_postgis_app.xml.po,
+ doc/po/es/using_postgis_dataman.xml.po,
+ doc/po/es/using_raster_dataman.xml.po, doc/po/fr/extras.xml.po,
+ doc/po/fr/extras_address_standardizer.xml.po,
+ doc/po/fr/extras_historytable.xml.po,
+ doc/po/fr/extras_tigergeocoder.xml.po,
+ doc/po/fr/extras_topology.xml.po, doc/po/fr/faq.xml.po,
+ doc/po/fr/faq_raster.xml.po, doc/po/fr/installation.xml.po,
+ doc/po/fr/introduction.xml.po, doc/po/fr/performance_tips.xml.po,
+ doc/po/fr/postgis.xml.po, doc/po/fr/reference.xml.po,
+ doc/po/fr/reference_accessor.xml.po,
+ doc/po/fr/reference_bbox.xml.po,
+ doc/po/fr/reference_cluster.xml.po,
+ doc/po/fr/reference_constructor.xml.po,
+ doc/po/fr/reference_editor.xml.po,
+ doc/po/fr/reference_guc.xml.po, doc/po/fr/reference_input.xml.po,
+ doc/po/fr/reference_lrs.xml.po,
+ doc/po/fr/reference_management.xml.po,
+ doc/po/fr/reference_measure.xml.po,
+ doc/po/fr/reference_operator.xml.po,
+ doc/po/fr/reference_output.xml.po,
+ doc/po/fr/reference_processing.xml.po,
+ doc/po/fr/reference_raster.xml.po,
+ doc/po/fr/reference_relationship.xml.po,
+ doc/po/fr/reference_sfcgal.xml.po,
+ doc/po/fr/reference_srs.xml.po,
+ doc/po/fr/reference_trajectory.xml.po,
+ doc/po/fr/reference_transaction.xml.po,
+ doc/po/fr/reference_transformation.xml.po,
+ doc/po/fr/reference_troubleshooting.xml.po,
+ doc/po/fr/reference_type.xml.po,
+ doc/po/fr/reference_validation.xml.po,
+ doc/po/fr/reference_version.xml.po,
+ doc/po/fr/release_notes.xml.po, doc/po/fr/reporting.xml.po,
+ doc/po/fr/using_postgis_app.xml.po,
+ doc/po/fr/using_postgis_dataman.xml.po,
+ doc/po/fr/using_raster_dataman.xml.po,
+ doc/po/it_IT/extras.xml.po,
+ doc/po/it_IT/extras_address_standardizer.xml.po,
+ doc/po/it_IT/extras_historytable.xml.po,
+ doc/po/it_IT/extras_tigergeocoder.xml.po,
+ doc/po/it_IT/extras_topology.xml.po, doc/po/it_IT/faq.xml.po,
+ doc/po/it_IT/faq_raster.xml.po, doc/po/it_IT/installation.xml.po,
+ doc/po/it_IT/introduction.xml.po,
+ doc/po/it_IT/performance_tips.xml.po,
+ doc/po/it_IT/postgis.xml.po, doc/po/it_IT/reference.xml.po,
+ doc/po/it_IT/reference_accessor.xml.po,
+ doc/po/it_IT/reference_bbox.xml.po,
+ doc/po/it_IT/reference_cluster.xml.po,
+ doc/po/it_IT/reference_constructor.xml.po,
+ doc/po/it_IT/reference_editor.xml.po,
+ doc/po/it_IT/reference_guc.xml.po,
+ doc/po/it_IT/reference_input.xml.po,
+ doc/po/it_IT/reference_lrs.xml.po,
+ doc/po/it_IT/reference_management.xml.po,
+ doc/po/it_IT/reference_measure.xml.po,
+ doc/po/it_IT/reference_operator.xml.po,
+ doc/po/it_IT/reference_output.xml.po,
+ doc/po/it_IT/reference_processing.xml.po,
+ doc/po/it_IT/reference_raster.xml.po,
+ doc/po/it_IT/reference_relationship.xml.po,
+ doc/po/it_IT/reference_sfcgal.xml.po,
+ doc/po/it_IT/reference_srs.xml.po,
+ doc/po/it_IT/reference_trajectory.xml.po,
+ doc/po/it_IT/reference_transaction.xml.po,
+ doc/po/it_IT/reference_transformation.xml.po,
+ doc/po/it_IT/reference_troubleshooting.xml.po,
+ doc/po/it_IT/reference_type.xml.po,
+ doc/po/it_IT/reference_validation.xml.po,
+ doc/po/it_IT/reference_version.xml.po,
+ doc/po/it_IT/release_notes.xml.po, doc/po/it_IT/reporting.xml.po,
+ doc/po/it_IT/using_postgis_app.xml.po,
+ doc/po/it_IT/using_postgis_dataman.xml.po,
+ doc/po/it_IT/using_raster_dataman.xml.po,
+ doc/po/ja/extras.xml.po,
+ doc/po/ja/extras_address_standardizer.xml.po,
+ doc/po/ja/extras_historytable.xml.po,
+ doc/po/ja/extras_tigergeocoder.xml.po,
+ doc/po/ja/extras_topology.xml.po, doc/po/ja/faq.xml.po,
+ doc/po/ja/faq_raster.xml.po, doc/po/ja/installation.xml.po,
+ doc/po/ja/introduction.xml.po, doc/po/ja/performance_tips.xml.po,
+ doc/po/ja/postgis.xml.po, doc/po/ja/reference.xml.po,
+ doc/po/ja/reference_accessor.xml.po,
+ doc/po/ja/reference_bbox.xml.po,
+ doc/po/ja/reference_cluster.xml.po,
+ doc/po/ja/reference_constructor.xml.po,
+ doc/po/ja/reference_editor.xml.po,
+ doc/po/ja/reference_guc.xml.po, doc/po/ja/reference_input.xml.po,
+ doc/po/ja/reference_lrs.xml.po,
+ doc/po/ja/reference_management.xml.po,
+ doc/po/ja/reference_measure.xml.po,
+ doc/po/ja/reference_operator.xml.po,
+ doc/po/ja/reference_output.xml.po,
+ doc/po/ja/reference_processing.xml.po,
+ doc/po/ja/reference_raster.xml.po,
+ doc/po/ja/reference_relationship.xml.po,
+ doc/po/ja/reference_sfcgal.xml.po,
+ doc/po/ja/reference_srs.xml.po,
+ doc/po/ja/reference_trajectory.xml.po,
+ doc/po/ja/reference_transaction.xml.po,
+ doc/po/ja/reference_transformation.xml.po,
+ doc/po/ja/reference_troubleshooting.xml.po,
+ doc/po/ja/reference_type.xml.po,
+ doc/po/ja/reference_validation.xml.po,
+ doc/po/ja/reference_version.xml.po,
+ doc/po/ja/release_notes.xml.po, doc/po/ja/reporting.xml.po,
+ doc/po/ja/using_postgis_app.xml.po,
+ doc/po/ja/using_postgis_dataman.xml.po,
+ doc/po/ja/using_raster_dataman.xml.po,
+ doc/po/ko_KR/extras.xml.po,
+ doc/po/ko_KR/extras_address_standardizer.xml.po,
+ doc/po/ko_KR/extras_historytable.xml.po,
+ doc/po/ko_KR/extras_tigergeocoder.xml.po,
+ doc/po/ko_KR/extras_topology.xml.po, doc/po/ko_KR/faq.xml.po,
+ doc/po/ko_KR/faq_raster.xml.po, doc/po/ko_KR/installation.xml.po,
+ doc/po/ko_KR/introduction.xml.po,
+ doc/po/ko_KR/performance_tips.xml.po,
+ doc/po/ko_KR/postgis.xml.po, doc/po/ko_KR/reference.xml.po,
+ doc/po/ko_KR/reference_accessor.xml.po,
+ doc/po/ko_KR/reference_bbox.xml.po,
+ doc/po/ko_KR/reference_cluster.xml.po,
+ doc/po/ko_KR/reference_constructor.xml.po,
+ doc/po/ko_KR/reference_editor.xml.po,
+ doc/po/ko_KR/reference_guc.xml.po,
+ doc/po/ko_KR/reference_input.xml.po,
+ doc/po/ko_KR/reference_lrs.xml.po,
+ doc/po/ko_KR/reference_management.xml.po,
+ doc/po/ko_KR/reference_measure.xml.po,
+ doc/po/ko_KR/reference_operator.xml.po,
+ doc/po/ko_KR/reference_output.xml.po,
+ doc/po/ko_KR/reference_processing.xml.po,
+ doc/po/ko_KR/reference_raster.xml.po,
+ doc/po/ko_KR/reference_relationship.xml.po,
+ doc/po/ko_KR/reference_sfcgal.xml.po,
+ doc/po/ko_KR/reference_srs.xml.po,
+ doc/po/ko_KR/reference_trajectory.xml.po,
+ doc/po/ko_KR/reference_transaction.xml.po,
+ doc/po/ko_KR/reference_transformation.xml.po,
+ doc/po/ko_KR/reference_troubleshooting.xml.po,
+ doc/po/ko_KR/reference_type.xml.po,
+ doc/po/ko_KR/reference_validation.xml.po,
+ doc/po/ko_KR/reference_version.xml.po,
+ doc/po/ko_KR/release_notes.xml.po, doc/po/ko_KR/reporting.xml.po,
+ doc/po/ko_KR/using_postgis_app.xml.po,
+ doc/po/ko_KR/using_postgis_dataman.xml.po,
+ doc/po/ko_KR/using_raster_dataman.xml.po,
+ doc/po/pl/extras.xml.po,
+ doc/po/pl/extras_address_standardizer.xml.po,
+ doc/po/pl/extras_historytable.xml.po,
+ doc/po/pl/extras_tigergeocoder.xml.po,
+ doc/po/pl/extras_topology.xml.po, doc/po/pl/faq.xml.po,
+ doc/po/pl/faq_raster.xml.po, doc/po/pl/installation.xml.po,
+ doc/po/pl/introduction.xml.po, doc/po/pl/performance_tips.xml.po,
+ doc/po/pl/postgis.xml.po, doc/po/pl/reference.xml.po,
+ doc/po/pl/reference_accessor.xml.po,
+ doc/po/pl/reference_bbox.xml.po,
+ doc/po/pl/reference_cluster.xml.po,
+ doc/po/pl/reference_constructor.xml.po,
+ doc/po/pl/reference_editor.xml.po,
+ doc/po/pl/reference_guc.xml.po, doc/po/pl/reference_input.xml.po,
+ doc/po/pl/reference_lrs.xml.po,
+ doc/po/pl/reference_management.xml.po,
+ doc/po/pl/reference_measure.xml.po,
+ doc/po/pl/reference_operator.xml.po,
+ doc/po/pl/reference_output.xml.po,
+ doc/po/pl/reference_processing.xml.po,
+ doc/po/pl/reference_raster.xml.po,
+ doc/po/pl/reference_relationship.xml.po,
+ doc/po/pl/reference_sfcgal.xml.po,
+ doc/po/pl/reference_srs.xml.po,
+ doc/po/pl/reference_trajectory.xml.po,
+ doc/po/pl/reference_transaction.xml.po,
+ doc/po/pl/reference_transformation.xml.po,
+ doc/po/pl/reference_troubleshooting.xml.po,
+ doc/po/pl/reference_type.xml.po,
+ doc/po/pl/reference_validation.xml.po,
+ doc/po/pl/reference_version.xml.po,
+ doc/po/pl/release_notes.xml.po, doc/po/pl/reporting.xml.po,
+ doc/po/pl/using_postgis_app.xml.po,
+ doc/po/pl/using_postgis_dataman.xml.po,
+ doc/po/pl/using_raster_dataman.xml.po,
+ doc/po/pt_BR/extras.xml.po,
+ doc/po/pt_BR/extras_address_standardizer.xml.po,
+ doc/po/pt_BR/extras_historytable.xml.po,
+ doc/po/pt_BR/extras_tigergeocoder.xml.po,
+ doc/po/pt_BR/extras_topology.xml.po, doc/po/pt_BR/faq.xml.po,
+ doc/po/pt_BR/faq_raster.xml.po, doc/po/pt_BR/installation.xml.po,
+ doc/po/pt_BR/introduction.xml.po,
+ doc/po/pt_BR/performance_tips.xml.po,
+ doc/po/pt_BR/postgis.xml.po, doc/po/pt_BR/reference.xml.po,
+ doc/po/pt_BR/reference_accessor.xml.po,
+ doc/po/pt_BR/reference_bbox.xml.po,
+ doc/po/pt_BR/reference_cluster.xml.po,
+ doc/po/pt_BR/reference_constructor.xml.po,
+ doc/po/pt_BR/reference_editor.xml.po,
+ doc/po/pt_BR/reference_guc.xml.po,
+ doc/po/pt_BR/reference_input.xml.po,
+ doc/po/pt_BR/reference_lrs.xml.po,
+ doc/po/pt_BR/reference_management.xml.po,
+ doc/po/pt_BR/reference_measure.xml.po,
+ doc/po/pt_BR/reference_operator.xml.po,
+ doc/po/pt_BR/reference_output.xml.po,
+ doc/po/pt_BR/reference_processing.xml.po,
+ doc/po/pt_BR/reference_raster.xml.po,
+ doc/po/pt_BR/reference_relationship.xml.po,
+ doc/po/pt_BR/reference_sfcgal.xml.po,
+ doc/po/pt_BR/reference_srs.xml.po,
+ doc/po/pt_BR/reference_trajectory.xml.po,
+ doc/po/pt_BR/reference_transaction.xml.po,
+ doc/po/pt_BR/reference_transformation.xml.po,
+ doc/po/pt_BR/reference_troubleshooting.xml.po,
+ doc/po/pt_BR/reference_type.xml.po,
+ doc/po/pt_BR/reference_validation.xml.po,
+ doc/po/pt_BR/reference_version.xml.po,
+ doc/po/pt_BR/release_notes.xml.po, doc/po/pt_BR/reporting.xml.po,
+ doc/po/pt_BR/using_postgis_app.xml.po,
+ doc/po/pt_BR/using_postgis_dataman.xml.po,
+ doc/po/pt_BR/using_raster_dataman.xml.po: Update documentation
+ translations from transifex.
+2019-08-03 21:04 Darafei Praliaskouski <me at komzpa.net>
+ * [r17665] doc/po/templates/extras.xml.pot,
+ doc/po/templates/extras_address_standardizer.xml.pot,
+ doc/po/templates/extras_historytable.xml.pot,
+ doc/po/templates/extras_tigergeocoder.xml.pot,
+ doc/po/templates/extras_topology.xml.pot,
+ doc/po/templates/faq.xml.pot,
+ doc/po/templates/faq_raster.xml.pot,
+ doc/po/templates/installation.xml.pot,
+ doc/po/templates/introduction.xml.pot,
+ doc/po/templates/performance_tips.xml.pot,
+ doc/po/templates/postgis.xml.pot,
+ doc/po/templates/reference.xml.pot,
+ doc/po/templates/reference_accessor.xml.pot,
+ doc/po/templates/reference_bbox.xml.pot,
+ doc/po/templates/reference_cluster.xml.pot,
+ doc/po/templates/reference_constructor.xml.pot,
+ doc/po/templates/reference_editor.xml.pot,
+ doc/po/templates/reference_exception.xml.pot,
+ doc/po/templates/reference_guc.xml.pot,
+ doc/po/templates/reference_input.xml.pot,
+ doc/po/templates/reference_lrs.xml.pot,
+ doc/po/templates/reference_management.xml.pot,
+ doc/po/templates/reference_measure.xml.pot,
+ doc/po/templates/reference_misc.xml.pot,
+ doc/po/templates/reference_operator.xml.pot,
+ doc/po/templates/reference_output.xml.pot,
+ doc/po/templates/reference_processing.xml.pot,
+ doc/po/templates/reference_raster.xml.pot,
+ doc/po/templates/reference_relationship.xml.pot,
+ doc/po/templates/reference_sfcgal.xml.pot,
+ doc/po/templates/reference_srs.xml.pot,
+ doc/po/templates/reference_trajectory.xml.pot,
+ doc/po/templates/reference_transaction.xml.pot,
+ doc/po/templates/reference_transformation.xml.pot,
+ doc/po/templates/reference_troubleshooting.xml.pot,
+ doc/po/templates/reference_type.xml.pot,
+ doc/po/templates/reference_validation.xml.pot,
+ doc/po/templates/reference_version.xml.pot,
+ doc/po/templates/release_notes.xml.pot,
+ doc/po/templates/reporting.xml.pot,
+ doc/po/templates/using_postgis_app.xml.pot,
+ doc/po/templates/using_postgis_dataman.xml.pot,
+ doc/po/templates/using_raster_dataman.xml.pot: Update translation
+ templates.
+2019-08-02 20:06 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r17664] regress/core/Makefile.in, regress/core/geos38.sql,
+ regress/core/geos38_expected, regress/core/tickets.sql: Move out
+ GEOS 3.8 specific result into a version-tested file
+2019-08-01 20:31 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r17659] regress/core/estimatedextent.sql,
+ regress/core/estimatedextent_expected: Harmonize calls so tests
+ return same results on multiple Pg versions
+ References #4464
+2019-08-01 13:28 Nicklas Avén <nicklas.aven at jordogskog.no>
+ * [r17655] liblwgeom/lwout_twkb.c: bugfix to fix for #4461
+2019-08-01 08:20 Nicklas Avén <nicklas.aven at jordogskog.no>
+ * [r17654] liblwgeom/lwout_twkb.c, regress/core/twkb.sql,
+ regress/core/twkb_expected: Remove duplicate points with
+ ST_AsTWKB also when apearing before min npoints Closes #4461
+2019-07-31 21:42 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r17653] NEWS, loader/pgsql2shp-core.c, loader/shp2pgsql-core.c:
+ Handle POINT EMPTY in shape loader/dumper
+ Closes #4437
+2019-07-31 15:22 Raúl Marín Rodríguez <rmrodriguez at carto.com>
+ * [r17649] .travis.yml: Travis: Use PG12 image by default
+ Closes #4446
+2019-07-30 22:27 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r17648] NEWS, configure.ac, postgis/Makefile.in,
+ postgis/geobuf.c, postgis/geobuf.h, postgis/lwgeom_out_geobuf.c,
+ postgis_config.h.in, regress/core/Makefile.in: Use protobuf
+ version to enable/disable mvt/geobuf
+ Closes #4419
+2019-07-29 17:36 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r17645] regress/core/Makefile.in,
+ regress/dumper/null3d_expected.dbf,
+ regress/dumper/null3d_expected.shp,
+ regress/dumper/null3d_expected.shx,
+ regress/dumper/nullsintable-post.sql,
+ regress/dumper/nullsintable-pre.sql,
+ regress/dumper/nullsintable.dmp,
+ regress/dumper/nullsintable_expected.dbf,
+ regress/dumper/nullsintable_expected.prj,
+ regress/dumper/nullsintable_expected.shp,
+ regress/dumper/nullsintable_expected.shx: Add test case and
+ update test case for null-handling behaviour
+ References #4209
+2019-07-29 16:58 Regina Obe <lr at pcorp.us>
+ * [r17644] NEWS: add in -d transform into enhancements list, move
+ bug fixes into a separate section from enhancements.
+ This is to make it easier to spot and drop bug fixes if they are
+ backported to older versions of PostGIS (as they won't be new
+ things in PostGIS 3.0)
+2019-07-29 16:33 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r17640] doc/reference_output.xml: Match JSON pretty print param
+ name to one used in pgsql
+2019-07-29 16:32 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r17639] NEWS, loader/pgsql2shp-core.c, postgis/postgis.sql.in:
+ Handle NULL geometry values in pgsql2shp
+ References #4209
+2019-07-29 15:34 Raúl Marín Rodríguez <rmrodriguez at carto.com>
+ * [r17635] NEWS, postgis/gserialized_estimate.c: Fix undefined
+ behaviour in _postgis_gserialized_stats
+ Closes #4466
+2019-07-29 14:00 Sandro Santilli <strk at kbt.io>
+ * [r17631] regress/run_test.pl: Have run_test include full
+ shp2pgsql commandline on failure
+ * [r17630] loader/shp2pgsql-core.c: Do not free state->geo_col, and
+ do not strdup when assigning defaults
+2019-07-29 13:59 Sandro Santilli <strk at kbt.io>
+ * [r17629] loader/shp2pgsql-cli.c, loader/shp2pgsql-core.c: Fix
+ memory leaks in shp2pgsql
+2019-07-29 13:35 Sandro Santilli <strk at kbt.io>
+ * [r17628] loader/shp2pgsql-core.h: Remove unused variable from
+ loader state
+2019-07-29 13:28 Sandro Santilli <strk at kbt.io>
+ * [r17627] loader/shp2pgsql-core.c: Use a single variable for
+ column names
+2019-07-29 02:01 Regina Obe <lr at pcorp.us>
+ * [r17626] loader/shp2pgsql-core.c: Missed a spot - get rid of
+ hard-coding of 4326 for geography srid
+ References #4466
+2019-07-29 01:47 Regina Obe <lr at pcorp.us>
+ * [r17625] loader/shp2pgsql-core.c: Take out restriction that
+ geography can only work with srid 4326
+ Geography supports any long-lat projection since 2.2
+ Closes #4465
+2019-07-29 01:11 Regina Obe <lr at pcorp.us>
+ * [r17624] regress/core/Makefile.in,
+ regress/loader/ReprojectPtsD.dbf,
+ regress/loader/ReprojectPtsD.opts,
+ regress/loader/ReprojectPtsD.select.expected,
+ regress/loader/ReprojectPtsD.select.sql,
+ regress/loader/ReprojectPtsD.shp,
+ regress/loader/ReprojectPtsD.shx,
+ regress/loader/ReprojectPtsGeogD-w.select.expected,
+ regress/loader/ReprojectPtsGeogD.dbf,
+ regress/loader/ReprojectPtsGeogD.opts,
+ regress/loader/ReprojectPtsGeogD.select.expected,
+ regress/loader/ReprojectPtsGeogD.select.sql,
+ regress/loader/ReprojectPtsGeogD.shp,
+ regress/loader/ReprojectPtsGeogD.shx: Add regression tests for
+ using -s from_srid:to_srid with -D (copy mode) for both geometry
+ and geography
+ Closes #4403
+2019-07-28 21:37 Regina Obe <lr at pcorp.us>
+ * [r17623] loader/shp2pgsql-core.c: Hoepfully last trailing space
+ References #4403
+2019-07-28 21:27 Regina Obe <lr at pcorp.us>
+ * [r17622] loader/shp2pgsql-core.c: Get rid of trailing spaces
+ References #4403
+2019-07-28 21:14 Regina Obe <lr at pcorp.us>
+ * [r17621] NEWS, doc/using_postgis_dataman.xml,
+ loader/README.shp2pgsql, loader/shp2pgsql-cli.c,
+ loader/shp2pgsql-core.c, loader/shp2pgsql-core.h: Support for
+ srid reprojection when using -D switch
+ References #4403
+ Tests forthcoming
+2019-07-22 13:27 Raúl Marín Rodríguez <rmrodriguez at carto.com>
+ * [r17620] NEWS, postgis/postgis.sql.in:
+ postgis_extensions_upgrade() also updates after pg_upgrade
+ Closes #4271
+ Closes https://github.com/postgis/postgis/pull/449
+2019-07-22 11:35 Raúl Marín Rodríguez <rmrodriguez at carto.com>
+ * [r17619] raster/test/regress/rt_gdalwarp.sql,
+ raster/test/regress/rt_gdalwarp_expected: Disable tests that give
+ different answer on Proj.5 vs. Proj.4
+ References #4104
+2019-07-19 14:49 Raúl Marín Rodríguez <rmrodriguez at carto.com>
+ * [r17618] liblwgeom/liblwgeom_topo.h, liblwgeom/lwgeom_topo.c,
+ topology/postgis_topology.c: Topology: Remove TODOs
+2019-07-19 14:21 Raúl Marín Rodríguez <rmrodriguez at carto.com>
+ * [r17617] liblwgeom/liblwgeom_internal.h, liblwgeom/lwstroke.c:
+ lwcompound_stroke: Remove unused function
+2019-07-19 13:02 Raúl Marín Rodríguez <rmrodriguez at carto.com>
+ * [r17616] raster/test/regress/rt_gdalwarp.sql,
+ raster/test/regress/rt_gdalwarp_expected: Re-enable gdal tests
+ Reverts r16688
+ Closes #4104
+ Closes https://github.com/postgis/postgis/pull/450
+2019-07-19 05:47 Regina Obe <lr at pcorp.us>
+ * [r17615] doc/installation.xml: Dealing with IGN SRIDs from Michel
+ Philippenko
+ closes https://github.com/postgis/postgis/pull/448
+ for PostGIS 23.0
+2019-07-18 16:29 Regina Obe <lr at pcorp.us>
+ * [r17613] doc/reference_raster.xml: Correct description of
+ ST_BandPixelType function
+ Closes https://github.com/postgis/postgis/pull/447
+ thanks Mateusz Łoskot
+2019-07-16 21:42 Regina Obe <lr at pcorp.us>
+ * [r17612] ci/berrie/pg_init_start.sh,
+ ci/berrie/postgis_regress.sh: Make berrie script a bit more
+ generic and add regular make check as well
+2019-07-16 15:28 Regina Obe <lr at pcorp.us>
+ * [r17611] ci/berrie/pg_init_start.sh,
+ ci/berrie/postgis_regress.sh: Change to test again PG 12 (instead
+ of 13)
+ Closes #4456
+2019-07-16 14:19 Regina Obe <lr at pcorp.us>
+ * [r17610] ci/berrie/pg_init_start.sh,
+ ci/berrie/postgis_regress.sh: Revise berrie to use her own custom
+ PostgreSQL build -- evidentally installing past the jenkins
+ workspace is a no no for some reason
+2019-07-16 08:58 Raúl Marín Rodríguez <rmrodriguez at carto.com>
+ * [r17609] libpgcommon/Makefile.in, loader/Makefile.in,
+ raster/loader/Makefile.in: Add CPPFLAGS where missing
+ Spotted by Debian's build log hardening checker, blhc.
+ https://salsa.debian.org/debian-gis-team/postgis/-/jobs/222378
+ Patch by Christoph Berg <myon -at- debian.org>
+ Closes https://github.com/postgis/postgis/pull/446
+2019-07-15 23:14 Regina Obe <lr at pcorp.us>
+ * [r17605] ci/berrie/postgis_regress.sh: Try to get berrie to use
+ workspace installed pg12 to get around make install installing in
+ wrong folder
+ References #4456
+2019-07-15 12:38 Regina Obe <lr at pcorp.us>
+ * [r17604] regress/run_test.pl: Stop trying to run createlang --
+ plpgsql is always installed
+ Closes #4457
+2019-07-15 10:13 Raúl Marín Rodríguez <rmrodriguez at carto.com>
+ * [r17603] NEWS, postgis/lwgeom_functions_basic.c: ST_IsEmpty:
+ Speed up by avoiding deserialization
+ Closes #4453
+ Closes https://github.com/postgis/postgis/pull/442
+2019-07-15 10:08 Raúl Marín Rodríguez <rmrodriguez at carto.com>
+ * [r17602] regress/core/regress_ogc.sql,
+ regress/core/regress_ogc_expected: ST_Startpoint: Improve tests
+ and documentation
+ Closes https://github.com/postgis/postgis/pull/443/
+2019-07-15 10:07 Raúl Marín Rodríguez <rmrodriguez at carto.com>
+ * [r17601] NEWS, postgis/lwgeom_functions_basic.c:
+ _ST_OrderingEquals: Avoid deserialization
+ Closes #4454
+ Closes https://github.com/postgis/postgis/pull/444
+2019-07-14 14:24 Darafei Praliaskouski <me at komzpa.net>
+ * [r17600] NEWS, liblwgeom/gbox.c, liblwgeom/gserialized.c,
+ liblwgeom/lwinline.h, liblwgeom/lwtree.c,
+ libpgcommon/gserialized_gist.h, postgis/lwgeom_btree.c,
+ postgis/postgis.sql.in: Fast Hilbert btree.
+ Requires btree indexes to be recreated.
+ Closes https://github.com/postgis/postgis/pull/436
+ Closes #3883
+2019-07-14 05:06 Regina Obe <lr at pcorp.us>
+ * [r17599] ci/berrie/postgis_regress.sh: revise to install and test
+ extensions
+2019-07-14 04:43 Regina Obe <lr at pcorp.us>
+ * [r17598] ci/berrie/postgis_regress.sh: Just let postgis build put
+ wherever it wants the tmp files
+2019-07-14 04:15 Regina Obe <lr at pcorp.us>
+ * [r17597] ci/berrie/postgis_regress.sh: revise to have tmp folder
+ in code folder to try to get around issue can't create directory
+2019-07-14 02:57 Regina Obe <lr at pcorp.us>
+ * [r17596] README.md: Fix Berrie's badge link. Add badge links for
+ Bessie and Bessie32. revise to 3 bots per line
+2019-07-14 02:41 Regina Obe <lr at pcorp.us>
+ * [r17595] README.md, ci/berrie/postgis_regress.sh: Add berrie to
+ list of buildbots. revise berrie script to create ~tmp folder if
+ it doesn't exist
+ References #4456
+2019-07-14 01:14 Regina Obe <lr at pcorp.us>
+ * [r17594] NEWS, ci/berrie, ci/berrie/postgis_regress.sh: Add
+ berrie's ci script
+ berrie is a Rasberry Pi 32-bit system running Debian Buster (10),
+ graciously offered by Bruce Rindahl
+ References #4456
+2019-07-12 16:03 Raúl Marín Rodríguez <rmrodriguez at carto.com>
+ * [r17593] NEWS, liblwgeom/cunit/cu_gserialized1.c,
+ liblwgeom/cunit/cu_gserialized2.c, liblwgeom/gserialized.c,
+ liblwgeom/gserialized.h, liblwgeom/gserialized1.c,
+ liblwgeom/gserialized1.h, liblwgeom/gserialized2.c,
+ liblwgeom/gserialized2.h, liblwgeom/liblwgeom.h.in,
+ postgis/lwgeom_ogc.c, regress/core/Makefile.in,
+ regress/core/point_coordinates.sql,
+ regress/core/point_coordinates_expected: Speed up ST_X, ST_Y,
+ ST_Z and ST_M
+ Closes https://github.com/postgis/postgis/pull/435
+ Closes https://trac.osgeo.org/postgis/ticket/4449
+2019-07-12 16:00 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r17592] NEWS, libpgcommon/lwgeom_transform.c,
+ postgis/lwgeom_in_gml.c, spatial_ref_sys.sql: Add new entries to
+ spatial_ref_sys and handle non-EPSG authnames
+ Closes #4417
+2019-07-12 15:57 Raúl Marín Rodríguez <rmrodriguez at carto.com>
+ * [r17591] liblwgeom/gserialized.h, liblwgeom/gserialized1.c,
+ liblwgeom/gserialized2.c: gserialized: Style changes
+ References #4449
+2019-07-10 22:49 Sandro Santilli <strk at kbt.io>
+ * [r17590] topology/Makefile.in: Fix Makefile override warning
+ Fixes the following:
+ warning: overriding recipe for target 'check'
+ .../pgxs.mk:276: warning: ignoring old recipe for target 'check'
+ * [r17589] regress/Makefile.in: Don't leave .bak files in staged
+ install
+2019-07-10 21:34 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r17588] doc/reference_constructor.xml: Add example using
+ optional bounds
+2019-07-10 20:44 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r17587] NEWS, doc/reference_constructor.xml,
+ doc/reference_output.xml, postgis/lwgeom_functions_basic.c,
+ postgis/postgis.sql.in, regress/core/regress.sql,
+ regress/core/regress_expected: Add ST_TileEnvelope utility
+ function
+ Closes #4452
+2019-07-09 15:43 Raúl Marín Rodríguez <rmrodriguez at carto.com>
+ * [r17586] NEWS, postgis/lwgeom_ogc.c: Speed up ST_GeometryType
+ Closes https://github.com/postgis/postgis/pull/434
+ Closes #4450
+2019-07-09 15:33 Raúl Marín Rodríguez <rmrodriguez at carto.com>
+ * [r17585] NEWS, liblwgeom/gserialized1.c,
+ liblwgeom/gserialized2.c: Fix the calculation of
+ gserialized_max_header_size
+ Closes #4451
+ Closes https://github.com/postgis/postgis/pull/433
+2019-07-09 15:30 Raúl Marín Rodríguez <rmrodriguez at carto.com>
+ * [r17584] postgis/geobuf.c: Address compiler warning in 32b
+ systems
+2019-07-08 21:08 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r17583] .gitignore, raster/test/regress/loader: Ignore
+ TiledAutoSkipNoData.tif
+2019-07-02 19:47 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r17582] liblwgeom/liblwgeom_internal.h, liblwgeom/lookup3.c,
+ liblwgeom/lwin_wkb.c, liblwgeom/lwout_wkb.c, liblwgeom/lwutil.c:
+ Strip out getMachineEndian() in favour of configure-time check
+2019-07-02 09:00 Raúl Marín Rodríguez <rmrodriguez at carto.com>
+ * [r17580] NEWS, postgis/lwgeom_btree.c, regress/core/tickets.sql,
+ regress/core/tickets_expected: Fix bug in lwgeom_le
+ Closes #4445
+2019-07-02 08:44 Raúl Marín Rodríguez <rmrodriguez at carto.com>
+ * [r17577] NEWS: Improve hash changes NEWS
+ Since the output of the function has changed, any
+ index using it must be reindexed
+ References #4433
+2019-07-01 19:01 Regina Obe <lr at pcorp.us>
+ * [r17576] ci/winnie/build_postgis.sh,
+ ci/winnie/package_postgis.sh: get rid of -e in packaging (causing
+ error to be thrown if tries to remove zip not present), minor
+ adjustments to packaging.
+2019-07-01 18:15 Regina Obe <lr at pcorp.us>
+ * [r17575] NEWS, liblwgeom/gserialized.c, liblwgeom/gserialized.h,
+ liblwgeom/gserialized1.c, liblwgeom/gserialized1.h,
+ liblwgeom/gserialized2.c, liblwgeom/gserialized2.h,
+ liblwgeom/liblwgeom.h.in, postgis/lwgeom_btree.c: fix for 32-bit
+ hash
+ Closes #4433
+ Closes https://github.com/postgis/postgis/pull/429
+2019-07-01 14:03 Regina Obe <lr at pcorp.us>
+ * [r17574] NEWS, Version.config,
+ extensions/upgradeable_versions.mk: Flip to 3.0.0alpha4dev
+2019-07-01 07:31 Regina Obe <lr at pcorp.us>
+ * [r17572] ChangeLog, NEWS, Version.config, doc/release_notes.xml:
+ Prep for 3.0.0alpha3 release
+2019-07-01 03:37 Regina Obe <lr at pcorp.us>
+ * [r17571] ci/winnie/build_postgis.sh,
+ ci/winnie/package_postgis.sh, ci/winnie/regress_postgis.sh:
+ optional cgal version
2019-07-01 01:27 Regina Obe <lr at pcorp.us>
* [r17570] ci/winnie/build_postgis.sh,
Modified: trunk/Version.config
--- trunk/Version.config 2019-09-28 22:37:46 UTC (rev 17829)
+++ trunk/Version.config 2019-09-28 23:28:14 UTC (rev 17830)
@@ -5,7 +5,7 @@
POSTGIS_MAJOR_VERSION=3
POSTGIS_MINOR_VERSION=0
-POSTGIS_MICRO_VERSION=0alpha5dev
+POSTGIS_MICRO_VERSION=0beta1
# Liblwgeom interface versioning, reset to 0:0:0 (cur:age:rev)
# when changing POSTGIS_MINOR_VERSION
Modified: trunk/extensions/upgradeable_versions.mk
--- trunk/extensions/upgradeable_versions.mk 2019-09-28 22:37:46 UTC (rev 17829)
+++ trunk/extensions/upgradeable_versions.mk 2019-09-28 23:28:14 UTC (rev 17830)
@@ -53,4 +53,5 @@
3.0.0alpha1 \
3.0.0alpha2 \
3.0.0alpha3 \
- 3.0.0alpha4
+ 3.0.0alpha4 \
+ 3.0.0alpha5dev
