[postgis-tickets] [PostGIS] #4514: GEOS master breaks topology tests
trac at osgeo.org
Mon Sep 30 08:59:02 PDT 2019
Reporter: Algunenano | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS GEOS
Component: postgis | Version: trunk
Resolution: | Keywords:
Comment (by robe):
strk that was just one failure which was fixed upstream. The other ones
were jus tdifferent answers which can't be fixed based on what Paul told
me.
Here are the other failures for completeness - this is the output before I
revised the tests.
Note the above one was already passing.
PostgreSQL 12rc1 on x86_64-pc-linux-gnu, compiled by gcc (Debian 9.2.1-8)
9.2.1 20190909, 64-bit
Postgis 3.0.0alpha5dev - r17822 - 2019-09-27 19:34:14
scripts 3.0.0alpha5dev r17822
GEOS: 3.8.0dev-CAPI-1.12.0
PROJ: 6.2.0
Running tests
regress/legacy_validate .. ok
regress/legacy_predicate .. ok
regress/legacy_invalid .. ok
regress/sqlmm .. ok
regress/legacy_query .. ok
regress/addnode .. ok
regress/addedge .. ok
regress/addface .. ok
regress/addface2.5d .. ok
regress/addtopogeometrycolumn .. ok
regress/polygonize .. ok
regress/st_addisoedge .. ok
regress/st_addisonode .. ok
regress/st_addedgemodface .. ok
regress/st_addedgenewfaces .. ok
regress/st_changeedgegeom .. ok
regress/st_createtopogeo .. ok
regress/st_getfacegeometry .. ok
regress/st_getfaceedges .. ok
regress/st_modedgeheal .. ok
regress/st_modedgesplit .. ok
regress/st_newedgeheal .. ok
regress/st_newedgessplit .. ok
regress/st_remedgenewface .. ok
regress/st_remedgemodface .. ok
regress/st_simplify .. ok
regress/topoelement .. ok
regress/topoelementarray_agg .. ok
regress/topogeo_addlinestring .. failed (diff expected obtained:
/var/lib/jenkins/workspace/postgis/tmp/3_0_pg12w64/test_29_diff)
--- regress/topogeo_addlinestring_expected 2019-04-20
19:31:54.667900703 +0000
+++ /var/lib/jenkins/workspace/postgis/tmp/3_0_pg12w64/test_29_out
2019-09-27 19:44:03.576919878 +0000
@@ -54,36 +54,36 @@
snap_again|7
snap_again|36
snap_again|38
-crossover|40
crossover|41
+crossover|43
crossover|44
crossover|45
-crossover|N|37||POINT(21 10)
-crossover|N|38||POINT(21 7)
-crossover|N|39||POINT(9 18)
-crossover|N|40||POINT(9 20)
-crossover|N|41||POINT(16.2 14)
-crossover|E|9|sn15|en41
-crossover|E|20|sn9|en38
-crossover|E|21|sn15|en39
-crossover|E|39|sn37|en14
-crossover|E|40|sn38|en37
-crossover|E|41|sn39|en40
-crossover|E|42|sn40|en16
-crossover|E|43|sn41|en14
-crossover|E|44|sn41|en37
-crossover|E|45|sn40|en41
-crossover_again|40
+crossover|N|37||POINT(9 20)
+crossover|N|38||POINT(16.2 14)
+crossover|N|39||POINT(21 10)
+crossover|N|40||POINT(9 18)
+crossover|N|41||POINT(21 7)
+crossover|E|9|sn15|en38
+crossover|E|20|sn9|en41
+crossover|E|21|sn15|en40
+crossover|E|39|sn37|en16
+crossover|E|40|sn38|en14
+crossover|E|41|sn37|en38
+crossover|E|42|sn39|en14
+crossover|E|43|sn38|en39
+crossover|E|44|sn40|en37
+crossover|E|45|sn41|en39
crossover_again|41
+crossover_again|43
crossover_again|44
crossover_again|45
contains|25
contains|46
contains|47
-contains|N|42||POINT(7 36)
-contains|N|43||POINT(14 34)
-contains|E|46|sn21|en42
-contains|E|47|sn43|en22
+contains|N|42||POINT(14 34)
+contains|N|43||POINT(7 36)
+contains|E|46|sn42|en22
+contains|E|47|sn21|en43
nodecross|48
nodecross|49
nodecross|N|44||POINT(18 37)
@@ -97,13 +97,13 @@
#1613.1|E|50|sn46|en47
#1613.2|52
#1613.2|53
-#1613.2|N|48||POINT(556267.6 144887)
-#1613.2|N|49||POINT(556310 144887)
-#1613.2|N|50||POINT(556250 144887)
-#1613.2|E|50|sn46|en48
-#1613.2|E|51|sn48|en47
+#1613.2|N|48||POINT(556250 144887)
+#1613.2|N|49||POINT(556267.6 144887)
+#1613.2|N|50||POINT(556310 144887)
+#1613.2|E|50|sn46|en49
+#1613.2|E|51|sn49|en47
#1613.2|E|52|sn48|en49
-#1613.2|E|53|sn50|en48
+#1613.2|E|53|sn49|en50
#1631.1|54
#1631.1|N|51||POINT(556267.6 144887)
#1631.1|N|52||POINT(556267.6 144888)
@@ -199,9 +199,9 @@
t3412.start|t
t3412.L1|1
t3412.L2|2
-t3412.L2|3
-t3412.L2|5
t3412.L2|4
+t3412.L2|5
+t3412.L2|3
t3412.end|Topology 'bug3412' dropped
t3371.start|t
t3371.L1|1
@@ -210,15 +210,15 @@
t3371.end|Topology 'bug3711' dropped
t3838.start|t
t3838.L1|1
-t3838.L2|1
+t3838.L2|2
t3838.L2|3
t3838.L2|4
t3838.L2|5
+t3838.L2|1
t3838.L2|6
t3838.L2|7
t3838.L2|8
t3838.L2|9
-t3838.L2|2
t3838.end|Topology 'bug3838' dropped
t1855_1.start|t
t1855_1.0|1
regress/topogeo_addpoint .. ok
regress/topogeo_addpolygon .. failed (diff expected obtained:
/var/lib/jenkins/workspace/postgis/tmp/3_0_pg12w64/test_31_diff)
--- regress/topogeo_addpolygon_expected 2019-04-20 19:31:54.667900703
+0000
+++ /var/lib/jenkins/workspace/postgis/tmp/3_0_pg12w64/test_31_out
2019-09-27 19:44:04.628910476 +0000
@@ -30,8 +30,8 @@
N|26||POINT(28 18)
E|30|sn14|en26
E|31|sn26|en18
-E|32|sn26|en13
-E|33|sn17|en26
+E|32|sn17|en26
+E|33|sn26|en13
F|14
F|15
ex_hole|3
@@ -58,5 +58,5 @@
t1946.start|t
t1946.0|1
t1946.1|2
-t1946.2|4
+t1946.2|3
t1946.end|Topology 'bug1946' dropped
regress/topogeom_edit .. ok
regress/topogeometry_type .. ok
regress/topojson .. ok
regress/topologysummary .. ok
regress/topo2.5d .. ok
regress/totopogeom .. ok
regress/droptopology .. ok
regress/droptopogeometrycolumn .. ok
regress/copytopology .. ok
regress/createtopogeom .. ok
regress/createtopology .. ok
regress/gml .. ok
regress/getnodebypoint .. ok
regress/getedgebypoint .. ok
regress/getfacebypoint .. ok
regress/getringedges .. ok
regress/gettopogeomelements .. ok
regress/layertrigger .. ok
regress/validatetopology .. ok
uninstall . /var/lib/jenkins/workspace/postgis/branches/3.0/regress/00
-regress-install/share/contrib/postgis/uninstall_topology.sql
/var/lib/jenkins/workspace/postgis/branches/3.0/regress/00-regress-
install/share/contrib/postgis/uninstall_postgis.sql
. ok (4725)
Run tests: 51
Failed: 2
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4514#comment:7>
