[postgis-tickets] [SCM] PostGIS Buildbots; Jenkins jobs and instructions for setting up winnie and debbie bots. branch master updated. 863c8e7d09f3fbdb1ff129f48392534cb88986b3
git at osgeo.org
git at osgeo.org
Mon Sep 30 09:25:30 PDT 2019
the project "PostGIS Buildbots; Jenkins jobs and instructions for setting up winnie and debbie bots.".
via 863c8e7d09f3fbdb1ff129f48392534cb88986b3 (commit)
from 5f2c48a32fa186696035408cfe3a05b0c9e2aa05 (commit)
revisions in full, below.
commit 863c8e7d09f3fbdb1ff129f48392534cb88986b3
Author: Regina Obe <lr at pcorp.us>
Date: Mon Sep 30 12:25:25 2019 -0400
Updated instructions for FreeBSD 12 64/32 bit
diff --git a/freebsd/bessie32_setup.txt b/freebsd/bessie32_setup.txt
index 2720504..0681bef 100644
--- a/freebsd/bessie32_setup.txt
+++ b/freebsd/bessie32_setup.txt
@@ -1,4 +1,6 @@
-Bessie32 currently setup on winnie's virtual box - ssh port 51023
+Bessie32-12 currently setup on winnie's virtual box - ssh port 51023
+Built from: https://download.freebsd.org/ftp/releases/VM-IMAGES/12.0-RELEASE/i386/Latest/FreeBSD-12.0-RELEASE-i386.vmdk.xz(date DEC 2018)
Built from: https://download.freebsd.org/ftp/releases/VM-IMAGES/11.1-RELEASE/i386/Latest/FreeBSD-11.1-RELEASE-i386.vmdk.xz (date July 2017)
(to do admin stuff)
@@ -18,21 +20,29 @@ vi /etc/rc.conf
add a lines:
-hostname="bessie32"
+hostname="bessie32-12"
sshd_enable="YES"
-pw groupadd sshusers
#then edit the sshd_config
vi /etc/ssh/sshd_config and a line
-AllowGroup wheel sshusers
+AllowGroup wheel
Then run:
-service sshd restart
+service sshd start
To add a user user robe
+#install keys for each and add to wheel
adduser robe
+su robe
+cd ~/
+mkdir .ssh
+#install keys
+#repeat process for each user
adduser komzpa
+adduser pramsey
+adduser strk
+adduser cvvergara
+adduser jenkins
repeat for all users (make sure to add admin users to wheel group)
@@ -50,18 +60,21 @@ without password.
#pkg install jed tcpdump
pkg install wget git proj geos gdal json-c
-pkg install cunit libxml2 bison libxslt imagemagick
+pkg install cunit libxml2 bison libxslt #imagemagick only needed for doco
pkg install gmake gdb subversion
-pkg install automake autoconf libtool curl
-pkg install openjdk8
-pkg install protobuf protobuf-c #needed for building mvt
+pkg install automake autoconf libtool curl bison #needed for configure/lex
+pkg install pkgconf #needed for PostGIS 3.0 which now using pkg-config
+pkg install protobuf protobuf-c #needed for building mvt
+pkg install sfcgal #for sfcgal will also install cgal
+pkg install openjdk11 #for jenkins
#add following lines to /etc/fstab
fdesc /dev/fd fdescfs rw 0 0
proc /proc procfs rw 0 0
-pkg install postgresql10-server
+pkg install postgresql11-server
#didn't install this yet
#pkg install iconv
@@ -75,6 +88,7 @@ service postgresql initdb
service postgresql start
psql -U postgres
create user jenkins;
+\q
pkg update #update available list
pkg upgrade #upgrades all packages
@@ -95,9 +109,9 @@ sudo gmake installcheck PGUSER=postgres
sudo cpan TAP::Parser::SourceHandler::pgTAP
-##upgrade to 11.2
+##upgrade to 12.1 (not yet done)
sudo -i
-freebsd-update upgrade -r 11.2-RELEASE
+freebsd-update upgrade -r 12.1-RELEASE
freebsd-update install
#reboot
diff --git a/freebsd/bessie_setup.txt b/freebsd/bessie_setup.txt
index 0f5ee6c..572f772 100644
--- a/freebsd/bessie_setup.txt
+++ b/freebsd/bessie_setup.txt
@@ -1,10 +1,11 @@
Bessie currently setup on winnie's virtual box - ssh port 51022
-Built from https://download.freebsd.org/ftp/releases/VM-IMAGES/11.1-RELEASE/amd64/Latest/FreeBSD-11.1-RELEASE-amd64.vmdk.xz (dated Jul 21st 2017)
+Built from https://download.freebsd.org/ftp/releases/VM-IMAGES/12.0-RELEASE/amd64/Latest/FreeBSD-12.0-RELEASE-amd64.vmdk.xz dated (Dec 2018)
vi /etc/rc.conf
add to file
-hostname="bessie"
+hostname="bessie12"
sshd_enable="YES"
@@ -14,11 +15,20 @@ Add line
AllowGroups wheel
and add to AllowUsers list
+vi /etc/ssh/sshd_config #:g/AllowUsers/, :g/PermitRootLogin #change to yes so can configure - can change later to no
+#Make sure jenkins is in AllowUsers list of /sshd_config
+cat /etc/ssh/sshd_config | grep AllowUsers #if jenkins not listed add
Then run:
-To add a user user robe
+#if get host keys not found run
+ssh-keygen -A
+To create and add a user robe (repeat for jenkins, pramsey, strk, komzpa, cvvergara) and install relevant ssh keys in homedirs
adduser robe wheel
@@ -41,10 +51,6 @@ portsnap extract
portsnap fetch
portsnap update
-#I did this
-cd /usr/ports/security/sudo/ && make install clean
-#but could have saved some time by installing from binary
pkg install sudo
#choose LDAP protocol support in addition to default selected
@@ -53,26 +59,26 @@ Then run:
visudo
-and uncomment line allowing wheel to use sudo without password.
+and uncomment line wheel nopasswd allowing wheel to use sudo without password.
-pkg install jed bash tcpdump
-pkg install wget git proj geos
+pkg install jed bash tcpdump wget git proj geos
#had these installed, didn't work but worked with openjdk8
-#pkg install openjdk openjdk6
+mount -t fdescfs fdesc /dev/fd
+mount -t procfs proc /proc
-pkg install gmake gdb subversion
-pkg install autoconf libtool curl
-pkg install expect openjdk8
-pkg install libxslt imagemagick
-pkg install libxml2 bison
-pkg install proj gdal geos
+pkg install gmake gdb subversion autoconf libtool curl automake expect
+pkg install libxslt libxml2 bison
+pkg install imagemagick #if not found try imagemagick7 (was required for FreeBSD 12)
+pkg install gdal geos proj
pkg install sfcgal json-c
-pkg install cunit
+pkg install cunit iconv
#was going to install postgresql in jail but got lost quickly
@@ -90,8 +96,8 @@ jail_sysvipc_allow="YES"
#Enter your jail and install Postgres.
-pkg install iconv
+service postgresql initdb #create data cluster
edit the /etc/rc.conf
@@ -105,7 +111,7 @@ pkg info proj #get details of proj
pkg install cmake #install needed for building pgrouting and sfcgal in future
#for code coverage testing
-sudo pkg install lcov
+pkg install lcov
#for pgtap tests needed for pgrouting
git clone https://github.com/theory/pgtap.git
@@ -116,12 +122,23 @@ sudo gmake installcheck PGUSER=postgres
+#installing from ports
+#installed latest proj from ports by doing https://www.freebsd.org/doc/handbook/ports-using.html
+portsnap fetch #only needs to be done once
+portsnap extract #only needs to be done once
+portsnap fetch update #to keep up to date
+cd /usr/ports/graphics/proj
+make install
+#note you might be asked remove gdal and libgeotiff go ahead
+cd /usr/ports/graphics/gdal
+make install
-##upgrade to 11.2
+##upgrade to 12.1 - not done
sudo -i
freebsd-update fetch
#check version running
Summary of changes:
freebsd/bessie32_setup.txt | 40 ++++++++++++++++++----------
freebsd/bessie_setup.txt | 65 +++++++++++++++++++++++++++++-----------------
2 files changed, 68 insertions(+), 37 deletions(-)
hooks/post-receive
