[postgis-tickets] [PostGIS] #4518: Fix geometry_columns and other views
trac at osgeo.org
Mon Sep 30 13:53:33 PDT 2019
Reporter: pramsey | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.4.9
Component: postgis | Version: 2.4.x
Keywords: |
Both geometry_columns and raster_columns use SQL against pg_constraint
that makes no sense in Pg12, which is usually no problem since we don't
support PG12 in 2.4, but does bork up pg_upgrade processes, so those
changes and a handful of regression fixes are bundled here.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4518>
