[postgis-tickets] [PostGIS] #4806: ST_GeogFromWKB crashes server with segfault
trac at osgeo.org
Tue Dec 1 07:33:15 PST 2020
Reporter: pimpaa | Owner: pramsey
Type: defect | Status: new
Priority: high | Milestone: PostGIS 3.2.0
Component: postgis | Version: 2.5.x
Keywords: |
Hello friends! Long time no see!
We started to see some problems on our database after we released a
specific feature and our team looked into it and we believe that the
culprit is a segfault in ST_GeogFromText.
Relevant info:
SELECT * FROM postgis_full_version();
POSTGIS="2.5.2 r17328" [EXTENSION] PGSQL="110" GEOS="3.7.0-CAPI-1.11.0
673b9939" PRO
J="Rel. 5.2.0, September 15th, 2018" GDAL="GDAL 2.3.1, released
2018/06/22" LIBXML="2
.9.1" LIBJSON="0.12" LIBPROTOBUF="1.3.0" (core procs from "2.5.1 r17027"
need upgrade
) RASTER (raster procs from "2.5.1 r17027" need upgrade)
(1 row)
select * from version();
version
PostgreSQL 11.8 on x86_64-pc-linux-gnu, compiled by gcc (GCC) 4.8.5
20150623 (Red Ha
t 4.8.5-11), 64-bit
(1 row)
We are using AWS RDS.
Due to a bug in our server side code we were, by mistake, sending a WKB
POINT to the ST_GeogFromText function. This caused the server to segfault
and restart.
While we can fix this on our backend code, my guess is that this should
not crash PostgreSQL.
This works:
mainproduction=> SELECT
ST_GeogFromWKB(ST_asBinary(ST_GeomFromText('MULTIPOINT ((10 40), (40 30),
(20 20), (30 10))')));
st_geogfromwkb
0104000020E6100000040000000101000000000000000000244000000000000044400101000000000000
00000044400000000000003E4001010000000000000000003440000000000000344001010000000000000
000003E400000000000002440
(1 row)
This causes the crash
ST_GeogFromWKB(ST_asBinary(ST_GeomFromText('POINT(1 1)')));
WARNING: terminating connection because of crash of another server
process
DETAIL: The postmaster has commanded this server process to roll back the
current transaction and exit, because another server process exited
abnormally and possibly corrupted shared memory.
HINT: In a moment you should be able to reconnect to the database and
repeat your command.
SSL SYSCALL error: EOF detected
The connection to the server was lost. Attempting reset: Succeeded.
psql (13.1 (Debian 13.1-1.pgdg100+1), server 11.8)
SSL connection (protocol: TLSv1.2, cipher: ECDHE-RSA-AES256-GCM-SHA384,
bits: 256, compression: off)
Further evidence:
2020-12-01 14:24:49 UTC::@:[26481]:LOG: server process (PID 19108) was
terminated by signal 11: Segmentation fault
2020-12-01 14:24:49 UTC::@:[26481]:DETAIL: Failed process was running:
UPDATE "my table" SET "updated_at" =
'2020-12-01T14:24:49.802406'::timestamp, "delivery_geometry" =
ST_GeogFromWKB('\x0104000020e6100000010000000101000000a661f888988f5dc0a0de8c9aaf064140'::bytea)
WHERE "my_table"."id" = 12149064
2020-12-01 14:24:49 UTC::@:[26481]:LOG: terminating any other active
server processes
2020-12-01 14:24:49 UTC::@:[14782]:WARNING: terminating connection
because of crash of another server process
2020-12-01 14:22:47 UTC::@:[26481]:LOG: server process (PID 14752) was
2020-12-01 14:22:47 UTC::@:[26481]:DETAIL: Failed process was running:
UPDATE "my_table" SET "updated_at" =
'2020-12-01T14:22:47.135840'::timestamp, "delivery_geometry" =
WHERE "my_table"."id" = 12148923
2020-12-01 14:22:47 UTC::@:[26481]:LOG: terminating any other active
server processes
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4806>
