[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0alpha3-21-g3645776
git at osgeo.org
git at osgeo.org
Thu Dec 3 13:49:55 PST 2020
the project "PostGIS".
via 3645776cfe3d75f6f4f4b9c5492b634fd8925062 (commit)
from 0a083db6c7399a94051cb8dbe156d79c52e50536 (commit)
revisions in full, below.
commit 3645776cfe3d75f6f4f4b9c5492b634fd8925062
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Thu Dec 3 12:16:18 2020 -0800
Remove "test" line that queries pg_stats, as it seems unlikely to
be stable from pgversion to pgversion
diff --git a/regress/core/regress_selectivity.sql b/regress/core/regress_selectivity.sql
index b5a23b7..bfcd429 100644
--- a/regress/core/regress_selectivity.sql
+++ b/regress/core/regress_selectivity.sql
@@ -2154,7 +2154,7 @@ create table regular_overdots as
-- Generate the stats
analyze regular_overdots;
-Select * from pg_stats where tablename = 'regular_overdots' ORDER BY attname;
+--Select * from pg_stats where tablename = 'regular_overdots' ORDER BY attname;
-- Baseline info
select 'selectivity_00', count(*) from regular_overdots;
diff --git a/regress/core/regress_selectivity_expected b/regress/core/regress_selectivity_expected
index 5a12f04..1ce2528 100644
--- a/regress/core/regress_selectivity_expected
+++ b/regress/core/regress_selectivity_expected
@@ -2,7 +2,6 @@ ERROR: stats for "no_stats.g" do not exist
ERROR: stats for "no_stats_join.g" do not exist
-public|regular_overdots|g|f|0|32|-1|{0101000000000000000000F03F000000000000F03F:010100000000000000000000400000000000000040:010100000000000000000008400000000000000840:0101000000000000000000F03F0000000000000840:01010000000000000000000840000000000000F03F:0101000000000000000000F03F0000000000000040:01010000000000000000000040000000000000F03F:010100000000000000000010400000000000001040:0101000000000000000000F03F0000000000001440:010100000000000000000000400000000000001040:010100000000000000000010400000000000000040:01010000000000000000001440000000000000F03F:0101000000000000000000F03F0000000000001040:01010000000000000000001040000000000000F03F:010100000000000000000008400000000000000040:010100000000000000000000400000000000000840:010100000000000000000014400000000000001440:010100000000000000000000400000000000001840:010100000000000000000008400000000000001440:010100000000000000000014400000000000000840:010100000000000000000018400000000000000040:0101000000000000000000F03F0000000000001C40:01010000000000
0000000000400000000000001440:010100000000000000000014400000000000000040:01010000000000000000001C40000000000000F03F:010100000000000000000008400000000000001040:010100000000000000000010400000000000000840:0101000000000000000000F03F0000000000001840:01010000000000000000001840000000000000F03F:010100000000000000000010400000000000001840:010100000000000000000018400000000000001040:010100000000000000000008400000000000001840:010100000000000000000008400000000000001C40:010100000000000000000018400000000000001840:01010000000000000000001C400000000000000840:010100000000000000000018400000000000000840:010100000000000000000014400000000000001040:010100000000000000000010400000000000001440:010100000000000000000000400000000000001C40:01010000000000000000001C400000000000000040:010100000000000000000020400000000000000040:010100000000000000000000400000000000002040:010100000000000000000014400000000000001C40:01010000000000000000001C400000000000001440:010100000000000000000010400000000000001C40:0101000000000000000000
1C400000000000001040:0101000000000000000000F03F0000000000002040:010100000000000000000014400000000000001840:01010000000000000000001C400000000000001C40:010100000000000000000018400000000000001440:010100000000000000000020400000000000001040:010100000000000000000010400000000000002040:01010000000000000000002040000000000000F03F:0101000000000000000000F03F0000000000002240:01010000000000000000002240000000000000F03F:010100000000000000000020400000000000000840:010100000000000000000022400000000000000840:010100000000000000000008400000000000002040:010100000000000000000008400000000000002240:010100000000000000000018400000000000001C40:01010000000000000000001C400000000000001840:010100000000000000000020400000000000001840:010100000000000000000018400000000000002040:010100000000000000000020400000000000001440:010100000000000000000014400000000000002040:010100000000000000000022400000000000000040:010100000000000000000020400000000000002040:010100000000000000000000400000000000002240:010100000000000000000022400000
000000001040:010100000000000000000022400000000000001440:010100000000000000000014400000000000002240:010100000000000000000010400000000000002240:010100000000000000000024400000000000000040:010100000000000000000020400000000000001C40:01010000000000000000001C400000000000002040:010100000000000000000000400000000000002440:010100000000000000000022400000000000001840:010100000000000000000022400000000000001C40:01010000000000000000001C400000000000002240:010100000000000000000018400000000000002240:010100000000000000000024400000000000001040:010100000000000000000010400000000000002440:0101000000000000000000F03F0000000000002440:010100000000000000000024400000000000001840:010100000000000000000022400000000000002240:010100000000000000000018400000000000002440:01010000000000000000002440000000000000F03F:010100000000000000000024400000000000000840:010100000000000000000024400000000000001440:010100000000000000000020400000000000002240:010100000000000000000022400000000000002040:01010000000000000000001440000000000000
2440:010100000000000000000008400000000000002440:010100000000000000000024400000000000001C40:010100000000000000000024400000000000002040:010100000000000000000020400000000000002440:01010000000000000000001C400000000000002440}|{0.0470146,0.0380818,0.0300893,0.029149,0.029149,0.0249177,0.0249177,0.0230371,0.022567,0.022567,0.022567,0.022567,0.0211566,0.0211566,0.0188058,0.0188058,0.0169252,0.0164551,0.0164551,0.0164551,0.0164551,0.015985,0.015985,0.015985,0.015985,0.0145745,0.0145745,0.0136342,0.0136342,0.0122238,0.0122238,0.0117536,0.0117536,0.0117536,0.0117536,0.0117536,0.0108134,0.0108134,0.0103432,0.0103432,0.0103432,0.0103432,0.00846262,0.00846262,0.00799248,0.00799248,0.00752233,0.00752233,0.00752233,0.00752233,0.00752233,0.00752233,0.00752233,0.00705219,0.00705219,0.00611189,0.00611189,0.00611189,0.00611189,0.0051716,0.0051716,0.0051716,0.0051716,0.00470146,0.00470146,0.00423131,0.00423131,0.00423131,0.00376117,0.00376117,0.00376117,0.00376117,0.00329102,0.00329102,0.00329102,0.0032
9102,0.00282087,0.00282087,0.00282087,0.00282087,0.00235073,0.00235073,0.00188058,0.00188058,0.00188058,0.00188058,0.00188058,0.00141044,0.00141044,0.00141044,0.00141044,0.00141044,0.00141044,0.000940292,0.000940292,0.000940292,0.000940292}|{010100000000000000000024400000000000002240:010100000000000000000024400000000000002440:010100000000000000000022400000000000002440}|0.321087|||
selectivity_00|2127
selectivity_01|1068
selectivity_02|actual|0.502
Summary of changes:
regress/core/regress_selectivity.sql | 2 +-
regress/core/regress_selectivity_expected | 1 -
2 files changed, 1 insertion(+), 2 deletions(-)
hooks/post-receive
