[postgis-tickets] [PostGIS] #4809: topogeom test failing on debbie
PostGIS trac at osgeo.org
Sat Dec 5 16:18:00 PST 2020
  Reporter:  robe      |      Owner:  robe
      Type:  defect    |     Status:  new
  Priority:  blocker   |  Milestone:  PostGIS 3.1.0
 Component:  topology  |    Version:  master
Resolution:            |   Keywords:
Comment (by robe):
 winnie has same issue and according to winnie started happening 11/28 this
 is the first commit that triggers the error
 Summary
     Add ST_ReducePrecision for GEOS 3.9+. (details)
 Commit d8fb00c553417d04860256ca5e2be2390248f7e2 by pramsey
 Uses GEOS setPrecision CAPI routine to round coordinates
 to grid while retaining a fully valid output.
 The file was modified   liblwgeom/lwgeom_geos.c
 The file was modified   postgis/postgis.sql.in
 The file was modified   regress/core/geos39.sql
 The file was modified   liblwgeom/lwkmeans.c
 The file was modified   regress/core/geos39_expected
 The file was modified   NEWS
 The file was modified   liblwgeom/liblwgeom.h.in
 The file was modified   postgis/lwgeom_geos.c
 The file was modified   doc/reference_processing.xml
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4809#comment:2>
