[postgis-tickets] [PostGIS] #4810: upgrade tests failing on gml test and add NEWS (was: upgrade tests failing on gml test)
PostGIS trac at osgeo.org
Sun Dec 6 12:26:03 PST 2020
  Reporter:  robe     |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  blocker  |  Milestone:  PostGIS 3.1.0
 Component:  postgis  |    Version:  master
Resolution:           |   Keywords:
Description changed by robe:
Old description:
> Looks like the test introduced in
> [4cc9d7adb122726047646648bd75e2972cd6c7b4/git]
> Broke upgrade tests as dronie has been failing since
>  ./core/in_gml .. failed (diff expected obtained:
> /tmp/pgis_reg/test_20_diff)
> 221.OBT: ERROR:  unknown spatial reference system
> 221.EXP: srs_21|SRID=4979;POINT(2 49 3)
> 222.OBT: ERROR:  unknown spatial reference system
> 222.EXP: srs_22|SRID=4985;POINT(2 49)
> 223.OBT: ERROR:  unknown spatial reference system
> 223.EXP: srs_23|SRID=8857;POINT(1 2)
> 224.OBT: ERROR:  unknown spatial reference system
> 224.EXP: srs_24|SRID=8360;POINT(2 49 3)
> 225.OBT: ERROR:  unknown spatial reference system
> 225.EXP: srs_25|SRID=8433;POINT(1 2)
New description:
 I should also mention I do not see a NEWS notice for the GML fix. that
 should be put in place as well.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4810#comment:1>
