[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0alpha3-36-g76a849e
Mon Dec 7 15:42:54 PST 2020
the project "PostGIS".
       via  76a849ed6ca739d3abfbef8001fda23d4b652e90 (commit)
      from  561428ea62b10796c8846d48011f972eaeb37c43 (commit)
revisions in full, below.
commit 76a849ed6ca739d3abfbef8001fda23d4b652e90
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Mon Dec 7 15:42:45 2020 -0800
    Add EPSG:8857 to set of missing SRS for GML test, Closes #4810w
diff --git a/regress/core/in_gml.sql b/regress/core/in_gml.sql
index 6d05586..49c1c3f 100644
--- a/regress/core/in_gml.sql
+++ b/regress/core/in_gml.sql
@@ -644,6 +644,8 @@ INSERT INTO spatial_ref_sys VALUES (8360, 'EPSG', 8360, 'COMPD_CS["ETRS89 + Balt
 	ON CONFLICT DO NOTHING;
 INSERT INTO spatial_ref_sys VALUES (8433, 'EPSG', 8433, 'PROJCS["Macao 1920 / Macao Grid",GEOGCS["Macao 1920",DATUM["Macao_1920",SPHEROID["International 1924",6378388,297,AUTHORITY["EPSG","7022"]],AUTHORITY["EPSG","1207"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.0174532925199433,AUTHORITY["EPSG","9122"]],AUTHORITY["EPSG","8428"]],PROJECTION["Transverse_Mercator"],PARAMETER["latitude_of_origin",22.2123972222222],PARAMETER["central_meridian",113.536469444444],PARAMETER["scale_factor",1],PARAMETER["false_easting",20000],PARAMETER["false_northing",20000],UNIT["metre",1,AUTHORITY["EPSG","9001"]],AXIS["Northing",NORTH],AXIS["Easting",EAST],AUTHORITY["EPSG","8433"]]', '+proj=tmerc +lat_0=22.2123972222222 +lon_0=113.536469444444 +k=1 +x_0=20000 +y_0=20000 +ellps=intl +units=m +no_defs')
+INSERT INTO spatial_ref_sys VALUES (8857, 'EPSG', 8857, NULL, '+proj=eqearth +lon_0=0 +x_0=0 +y_0=0 +datum=WGS84 +units=m +no_defs')
+	ON CONFLICT DO NOTHING;
 -- Reverse axis with all kind of simples geometry types
 SELECT 'srs_17', ST_AsEWKT(ST_GeomFromGML('<gml:MultiGeometry srsName="urn:ogc:def:crs:EPSG::4326"><gml:geometryMember><gml:Point><gml:pos srsDimension="2">1 2</gml:pos></gml:Point></gml:geometryMember><gml:geometryMember><gml:LineString><gml:posList srsDimension="2">3 4 5 6</gml:posList></gml:LineString></gml:geometryMember><gml:geometryMember><gml:Curve><gml:segments><gml:LineStringSegment><gml:posList srsDimension="2">7 8 9 10</gml:posList></gml:LineStringSegment></gml:segments></gml:Curve></gml:geometryMember><gml:geometryMember><gml:Polygon><gml:exterior><gml:LinearRing><gml:posList srsDimension="2">11 12 13 14 15 16 11 12</gml:posList></gml:LinearRing></gml:exterior><gml:interior><gml:LinearRing><gml:posList srsDimension="2">17 18 19 20 21 22 17 18</gml:posList></gml:LinearRing></gml:interior></gml:Polygon></gml:geometryMember><gml:geometryMember><gml:Surface><gml:patches><gml:PolygonPatch><gml:exterior><gml:LinearRing><gml:posList srsDimension="2">23 24 25 26 27 28 23 24</gml
 :posList></gml:LinearRing></gml:exterior><gml:interior><gml:LinearRing><gml:posList srsDimension="2">25 26 27 28 29 30 25 26</gml:posList></gml:LinearRing></gml:interior></gml:PolygonPatch></gml:patches></gml:Surface></gml:geometryMember></gml:MultiGeometry>'));
Summary of changes:
 regress/core/in_gml.sql | 2 ++
 1 file changed, 2 insertions(+)
hooks/post-receive
